[Released] RSSY Clothing Converter from Genesis 8 to Genesis 9 [Commercial]
124
  • wildbillnash said:
    I have a problem with the RSSY clothing converter for gen 8- gen 9. Actually, several. I bought it today and came up with a problem similar to the RSSY Hair conversion (haven't tackel that one yet).
    First, thanks to a Dutch made video (I don't speak Dutch) I was able to figure out to assign the destination folder. Again, thanks to the video, I "think" I found out how to get to the source folder. I did find the folder with my Gen 8 clothing. I went through the process (I won't go into the shoes/posing problem yet) and the program stopped at 90% done. That was close to 45 minutes before it froze up. Daz worked fine. And I could easily close out of the program. But it refused to convert around 20-25 of the last items.
    So, I went to my smart content and found only a small percent of the items made it under 'wardrobe'. If I go into my "Content Library" folder under the "Content Library" tab I find all of them there. Why don't they show up in the folders in the wardrobe folder?
    I check the Dress folder and saw only 30 out of 60 had made it. Any ideas?
    Oh, I forgot to mention. I was doing a batch conversion of all my clothes.
    It is hard to diagnose a batch run as errors can build up.  If you post a Daz log (not the log shown in the script dialog), I can try and tell you what might be happening.  For Smart Content, it is usually something wrong with the metadata of the original clothing.
    I hate to ask this, but where will I get that log? I"m not a programmer and know enough to be dangerous with Daz.
    BTW, something I would like to point out as well. In your instructions you mentioned about assigning the destination folder and the source folder. I had NO idea how to find the source folder. Your instructions assumed everyone knows how to do it. For those who don't are left behind. I had to watch that Dutch video to figure out all I had to do is click on an item in my content folder to browse to the folder's location. That helped a lot once I saw it. You might want to add that little tip to the instructions.
  • Help>Troubleshooting>View Log File.
    %appdata%/daz 3d/studio4/
  • wildbillnashwildbillnash Posts: 784
    edited February 2024
    Thanks for the path, Richard.
    RiverSoft Art, I'm also having the same trouble with your hair conversion. You need to tell us 'how' to find the source files and make sure we are in the correct output folder. Also, is there a way to add your hair conversion add-on into the Favorite's in the menu bar? There's no video for it online.
    Post edited by wildbillnash on
  • Richard, after clicking the "View Log File" in that path you gave, all I got were text files in different tabs. The second line you gave, what's that for?
  • The first opens the log, the second gives its location - paste it into a file browser adderss bar (e.g. the one for Attach a File here ) and it will then show the right folder, from which you can select log.txt.
  • RiverSoft ArtRiverSoft Art Posts: 6,826
    The problem is that people configure DS how they want so it is difficult.  ****IF**** you used the defaults for installation, there is a My Library folder for your content (as opposed to a My Daz 3D Library where all the Daz installed content is stored).  The My Library folder SHOULD be the first directory listed in the Daz Studio Formats section of the Content Directory Manager:
    If that is all true, you would create a My Library/People/Genesis 9/Clothing (My Library/People/Genesis 9/Hair for hair) directory.  That should be the output folder selected in the script and where all the user facing (visible to the user) files will be located. The DATA files created for each item by the script will end up in My Library/data/VENDOR NAME/PRODUCT NAME.
    Post edited by RiverSoft Art on
  • vwranglervwrangler Posts: 4,988
    I think there might be some sort of incompatibility between this clothing converter and Studio 4.22.0.16 (Windows 10)
    i was trying to convert Operation Arrowhead to G9. https://www.daz3d.com/operation-arrowhead-spy-kit-for-genesis-8-female
    i tried at first with Execute and it failed because it decided that nothing in there was clothing of type follower/wardrobe, which seems to happen somewhat frequently.
    I then tried using Force Convert Clothing and it seemed like nothing happened. It put the clothing converter into the scene, put the clothing item into the scene, and then just ... stopped. It didn't stop responding -- I was able to cancel and close the converter window -- but it didn't do the conversion. It created the drectory for the clothing to go into, but did nothing else.
    Even weirder, the Clothing Converter logfile is empty. Absolutely and completely empty, as if it hadn't even started running.
    When I exit Studio after trying to run the converter, instead Studio crashes with the message:
    - DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\QtCore4.dll" at 0033:000000007654C8FC, QEventLoop::exit()+12 byte(s)
    Unfortunately, it's not a "clean" crash -- I then have to go into Task Manager and kill another eight processes that are lingering.
    I have no idea what to try next.
    I need the Daz Log File.  I recommend:
    1. Load the log file (Help->Troubleshooting->View Log File) into Notepad++
    2. Run the conversion
    3. Switch back to Notepad++.  It will say the file has changed, reload?  Click yes
    4. Copy the part of the log file about the conversion run
    5. Paste it here smiley
    Thanks.
    edited March 2024
    Well ... I'll try to get this to you at some point later today or early tomorrow, but at this point, the forum server isn't letting me paste in the log text, and if I try to upload it as either a TXT or a zip file, I get "failed to write file to disk". Is there's some other way you'd like me to try to get the information to you?
    For what it's worth, it failed again in exactly the same way. Weird thing is, if I'm understanding the log file correctly, it seems to think it's worked. And in fact it seems to have partially worked, I think; in the data directory, under Sixus1, there's an "Operation Arrowhead (Cv)" directory that seems to have been created yesterday and was updated today. There are subdirectories, and DSF files in those directories. It's created the user-facing directory in the Content Library side as well, but it's completely failed to make any front-facing DUFs or icons.
    EDIT, 3/11, 1:05AM: The forum finally let me upload the zip file with the log.
    zip
    zip
    log.zip
    5K
    Post edited by vwrangler on
    The script definitely crashed:
    2024-03-10 15:51:23.080 [WARNING] :: \src\sdksource\general\dzscript.cpp(1189): Unhandled error while executing script.
    2024-03-10 15:51:23.080 [WARNING] :: QScriptEngine::popContext() doesn't match with pushContext()
    Unfortunately, that is not telling me what crashed.  The good news is that I do have the "Operation Arrowhead Spy Kit for Genesis 8 Female" so I can see if I can reproduce the error on my system.
  • lou_harperlou_harper Posts: 1,163
    Converted clothing no longer shows up in Smart Content for me anymore. It used to with a (cv) tag. Now it doesn't.
    Are you saying that converting anything does not make Smart Content entries or that all the stuff you converted and used to show up in SC is gone now?  If the second, it sounds like you did something to the Daz database.
    The older ones I converted still show up in Smart Content, but not new ones. I can find them in the Content Library, so they exist.
    That is strange.  I have not had that happen.  Do you happen to have a log of when you were converting one of these hidden clothes?
    I just did a quick convert and saved the log, but apperently it's too long to copy-paste and it's not an allowed file type for attachment.
    I don't need the complete Daz log... just from when CC starts through processing the clothing.  You can copy them out of the log and paste them into a TXT file
    That's whar I did and it was too long. Here is the end part only:
    2024-06-02 15:40:03.002 [DEBUG] :: setting root node presentation /Beach Caftan for Genesis 8 and 8.1 Females/Beach Caftan
    2024-06-02 15:40:03.012 [DEBUG] :: Defaults: {    "RootLabel" : "Beach Caftan",    "BaseDataPath" : "F:/DAZ CONTENT/DAZ Main",    "VendorName" : "esha",    "ProductName" : "BeachDresses (Cv)",    "ItemName" : "Caftan",    "ContentType" : "Follower/Wardrobe/Dress",    "Category" : "",    "CompatibilityBase" : "/Beach Caftan for Genesis 8 and 8.1 Females/Beach Caftan",    "CompatibleWith" : "/Genesis 9/Base",    "SmartParentProp" : false,    "WriteGeometryDef" : true,    "WriteParameterDefs" : true,    "WriteUVDefs" : true,    "ForceUniqueIDs" : false,    "CompressOutput" : true,    "RunSilent" : false}
    2024-06-02 15:40:03.012 [DEBUG] :: Get: {    "RootLabel" : "Beach Caftan",    "BaseDataPath" : "F:/DAZ CONTENT/DAZ Main",    "VendorName" : "esha",    "ProductName" : "BeachDresses (Cv)",    "ItemName" : "Caftan",    "ContentType" : "Follower/Wardrobe/Dress",    "Category" : "",    "CompatibilityBase" : "/Beach Caftan for Genesis 8 and 8.1 Females/Beach Caftan",    "CompatibleWith" : "/Genesis 9/Base",    "SmartParentProp" : false,    "WriteGeometryDef" : true,    "WriteParameterDefs" : true,    "WriteUVDefs" : true,    "ForceUniqueIDs" : false,    "CompressOutput" : true,    "RunSilent" : false}
    2024-06-02 15:40:03.013 [DEBUG] :: Required: {    "RootLabel" : "Beach Caftan",    "BaseDataPath" : "F:/DAZ CONTENT/DAZ Main",    "VendorName" : "esha",    "ProductName" : "BeachDresses (Cv)",    "ItemName" : "Caftan",    "ContentType" : "Follower/Wardrobe/Dress",    "Category" : "",    "CompatibilityBase" : "/Beach Caftan for Genesis 8 and 8.1 Females/Beach Caftan",    "CompatibleWith" : "/Genesis 9/Base",    "SmartParentProp" : false,    "WriteGeometryDef" : true,    "WriteParameterDefs" : true,    "WriteUVDefs" : true,    "ForceUniqueIDs" : false,    "CompressOutput" : true,    "RunSilent" : true}
    2024-06-02 15:40:03.015 [DEBUG] :: Compatibility Base /Beach Caftan for Genesis 8 and 8.1 Females/Beach Caftan
    2024-06-02 15:40:03.125 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Widen Waist.dsf
    2024-06-02 15:40:03.128 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Widen Chest.dsf
    2024-06-02 15:40:03.130 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Widen Breasts Side.dsf
    2024-06-02 15:40:03.132 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Widen Breasts Front.dsf
    2024-06-02 15:40:03.135 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Widen Back Bottom.dsf
    2024-06-02 15:40:03.139 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Skirt Wide.dsf
    2024-06-02 15:40:03.143 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Skirt Short.dsf
    2024-06-02 15:40:03.147 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Skirt Long.dsf
    2024-06-02 15:40:03.151 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMThighSide_85_R.dsf
    2024-06-02 15:40:03.155 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMThighSide_85_L.dsf
    2024-06-02 15:40:03.159 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMThighFwd_57_R.dsf
    2024-06-02 15:40:03.163 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMThighFwd_57_L.dsf
    2024-06-02 15:40:03.167 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMThighFwd_115_R.dsf
    2024-06-02 15:40:03.172 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMThighFwd_115_L.dsf
    2024-06-02 15:40:03.175 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMThighBack_35_R.dsf
    2024-06-02 15:40:03.179 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMThighBack_35_L.dsf
    2024-06-02 15:40:03.181 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrUp_90_R.dsf
    2024-06-02 15:40:03.183 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrUp_90_L.dsf
    2024-06-02 15:40:03.186 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrTwistFw_80_R.dsf
    2024-06-02 15:40:03.188 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrTwistFw_80_L.dsf
    2024-06-02 15:40:03.191 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrTwistBk_95_R.dsf
    2024-06-02 15:40:03.194 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrTwistBk_95_L.dsf
    2024-06-02 15:40:03.197 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrFwd_110_R.dsf
    2024-06-02 15:40:03.199 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrFwd_110_L.dsf
    2024-06-02 15:40:03.202 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrDown_40_R.dsf
    2024-06-02 15:40:03.205 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrDown_40_L.dsf
    2024-06-02 15:40:03.207 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrBack_40_R.dsf
    2024-06-02 15:40:03.209 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMShldrBack_40_L.dsf
    2024-06-02 15:40:03.212 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMCollarUp_55_R.dsf
    2024-06-02 15:40:03.215 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMCollarUp_55_L.dsf
    2024-06-02 15:40:03.219 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMChestSide_20_R.dsf
    2024-06-02 15:40:03.223 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/pJCMChestSide_20_L.dsf
    2024-06-02 15:40:03.226 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsSmall.dsf
    2024-06-02 15:40:03.229 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsSize.dsf
    2024-06-02 15:40:03.231 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsShape08.dsf
    2024-06-02 15:40:03.233 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsShape07.dsf
    2024-06-02 15:40:03.236 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsShape06.dsf
    2024-06-02 15:40:03.239 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsShape05.dsf
    2024-06-02 15:40:03.241 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsShape04.dsf
    2024-06-02 15:40:03.243 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsShape03.dsf
    2024-06-02 15:40:03.247 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsShape02.dsf
    2024-06-02 15:40:03.249 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsShape01.dsf
    2024-06-02 15:40:03.251 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsPerkSide.dsf
    2024-06-02 15:40:03.253 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsHeavy.dsf
    2024-06-02 15:40:03.256 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsGone.dsf
    2024-06-02 15:40:03.258 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/PBMBreastsDiameter.dsf
    2024-06-02 15:40:03.261 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Fit Over Clothing Top.dsf
    2024-06-02 15:40:03.265 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/Fit Over Clothing Bottom.dsf
    2024-06-02 15:40:03.272 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMZelara8.dsf
    2024-06-02 15:40:03.278 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMVoluptuous.dsf
    2024-06-02 15:40:03.285 [INFO] :: Loaded morph deltas: 0m 0.4s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMVictoria8_1.dsf
    2024-06-02 15:40:03.285 [INFO] :: Processing morph projection queue: Genesis 9 << Beach Caftan
    2024-06-02 15:40:03.295 [INFO] :: Morph projection queue processed: Genesis 9 << Beach Caftan
    2024-06-02 15:40:03.302 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMVictoria8.dsf
    2024-06-02 15:40:03.310 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMThin.dsf
    2024-06-02 15:40:03.316 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMTeenJosie8Body.dsf
    2024-06-02 15:40:03.322 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMSahira8.dsf
    2024-06-02 15:40:03.330 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMPearFigure.dsf
    2024-06-02 15:40:03.338 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMOlympia8.dsf
    2024-06-02 15:40:03.344 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMMeiLin8.dsf
    2024-06-02 15:40:03.351 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMLatonya8.dsf
    2024-06-02 15:40:03.361 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMGirl8.dsf
    2024-06-02 15:40:03.368 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMFreja8.dsf
    2024-06-02 15:40:03.375 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMFitnessSize.dsf
    2024-06-02 15:40:03.381 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMFitnessDetails.dsf
    2024-06-02 15:40:03.388 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMEmaciated.dsf
    2024-06-02 15:40:03.394 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMEllithia8.dsf
    2024-06-02 15:40:03.401 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMBrooke8_1.dsf
    2024-06-02 15:40:03.407 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMBodyTone.dsf
    2024-06-02 15:40:03.414 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMBodySize.dsf
    2024-06-02 15:40:03.421 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMBodybuilderSize.dsf
    2024-06-02 15:40:03.427 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMBodybuilderDetails.dsf
    2024-06-02 15:40:03.434 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMBabina8.dsf
    2024-06-02 15:40:03.440 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMAngharad8.dsf
    2024-06-02 15:40:03.448 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMAlexandra8.dsf
    2024-06-02 15:40:03.454 [INFO] :: Loaded morph deltas: 0m 0.4s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/FBMAiko8.dsf
    2024-06-02 15:40:03.456 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/CTRLBreastsNatural.dsf
    2024-06-02 15:40:03.459 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/CTRLBreastsImplants.dsf
    2024-06-02 15:40:03.462 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/CTRLBodybuilder.dsf
    2024-06-02 15:40:03.465 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/esha/BeachDresses/Caftan/Morphs/esha/Base/! Caftan Base sm 12.dsf
    2024-06-02 15:40:11.456 [DEBUG] :: Saved Clothing Item: F:/DAZ CONTENT/DAZ Main/People/Genesis 9/Converted Clothing/Beach Caftan/BC Beach Caftan.duf
    2024-06-02 15:40:11.494 [DEBUG] ::      Copy Icons from F:/DAZ CONTENT/DAZ Main/People/Genesis 8 Female/Clothing/Beach Caftan/BC Beach Caftan.duf to F:/DAZ CONTENT/DAZ Main/People/Genesis 9/Converted Clothing/Beach Caftan/BC Beach Caftan.duf
    2024-06-02 15:40:34.223 [INFO] ::      Copy Icons from F:/DAZ CONTENT/DAZ Main/People/Genesis 8 Female/Clothing/Beach Caftan/BC Beach Caftan.duf to F:/DAZ CONTENT/DAZ Main/People/Genesis 9/Converted Clothing/Beach Caftan/BC Beach Caftan.duf
    2024-06-02 15:40:34.367 [DEBUG] ::      Copy Categories from F:/DAZ CONTENT/DAZ Main/People/Genesis 8 Female/Clothing/Beach Caftan/BC Beach Caftan.duf to F:/DAZ CONTENT/DAZ Main/People/Genesis 9/Converted Clothing/Beach Caftan/BC Beach Caftan.duf
    2024-06-02 15:40:34.437 [INFO] ::      Copy Categories from F:/DAZ CONTENT/DAZ Main/People/Genesis 8 Female/Clothing/Beach Caftan/BC Beach Caftan.duf to F:/DAZ CONTENT/DAZ Main/People/Genesis 9/Converted Clothing/Beach Caftan/BC Beach Caftan.duf
    2024-06-02 15:40:34.493 [DEBUG] :: END Conversion of F:/DAZ CONTENT/DAZ Main/People/Genesis 8 Female/Clothing/Beach Caftan/BC Beach Caftan.duf
    2024-06-02 15:40:34.493 [DEBUG] :: RemoveExtraSkeletons Genesis 9
    2024-06-02 15:40:37.392 [INFO] :: Stop following: Genesis 9 << Beach Caftan
    2024-06-02 15:40:37.419 [INFO] :: Following stopped: Genesis 9 << Beach Caftan
    2024-06-02 15:40:39.096 [INFO] :: Stop following: Genesis 9 << G9 Eyebrows Card Style 06
    2024-06-02 15:40:39.120 [INFO] :: Following stopped: Genesis 9 << G9 Eyebrows Card Style 06
    2024-06-02 15:40:40.039 [INFO] :: Stop following: Genesis 9 << Genesis 9 Mouth
    2024-06-02 15:40:40.063 [INFO] :: Following stopped: Genesis 9 << Genesis 9 Mouth
    2024-06-02 15:40:41.029 [INFO] :: Stop following: Genesis 9 << Genesis 9 Eyes
    2024-06-02 15:40:41.053 [INFO] :: Following stopped: Genesis 9 << Genesis 9 Eyes
    2024-06-02 15:40:41.394 [INFO] :: Stop following: Genesis 9 << Genesis 9 Tear
    2024-06-02 15:40:41.418 [INFO] :: Following stopped: Genesis 9 << Genesis 9 Tear
    2024-06-02 15:40:42.262 [INFO] :: Stop following: Genesis 9 << Genesis 9 Eyelashes
    2024-06-02 15:40:42.287 [INFO] :: Following stopped: Genesis 9 << Genesis 9 Eyelashes
    2024-06-02 15:40:43.102 [DEBUG] :: Execution Complete.
    2024-06-02 15:40:43.293 [INFO] :: Execution Complete.
    2024-06-02 15:40:53.300 [INFO] :: Script executed successfully: F:/DAZ CONTENT/DAZ Main/scripts/riversoft art/clothing converter/rssy clothing converter g8f to g9.dse
    This is the log for part of the process of saving a prop (clothing).  Nothing you posted shows about the smart content.
    However, it did make me wonder if you were talking about creating the product or the clothing names.  That is all defined in the Options tab.  There is a "Create Converted Product" option that should be checked.  There are also Name Prefix/Suffix but those are for the clothing items ONLY.  The template for the name of the PRODUCT is defined in data/RiverSoft Art/Common/RSG9CCConstants.dsa.  It contains a line like
    var CONVERTED_PRODUCT_NAME  = '%1 (Cv)';
    That is where the (Cv) is defined for the product.  Unless you put (Cv) in the Name Prefix/Suffix for the converted clothing items, they won't have (Cv).
    That was it! I don't know how that got unchecked. /facepalm
    Awesome!  I am glad we worked it out.
  • jardinejardine Posts: 1,218
    RiverSoft Art said:
    Submitted update today:
    • Fixed code to set product name to NOT include gender
    • Fixed error where Auto-Fit dialog would show during conversion
    • Fixed Activate/Deactivate All buttons not working
    hi...
    i had the autofit dialogue pop up during a conversion today.  and as far as DIM shows, i am using the latest version of the script.  (04-11-2024.)
    what course of action would you recommend if this happens?  if the .pdf manual had a suggestion, i couldn't find it.
    i just clicked 'cancel' and reckoned i'd try converting that hair item again later, when i was better informed.
    thanks!
    j
    hi...
    thanks!
    j
    That should not be happening.  What is the hair that causes it?
  • barbultbarbult Posts: 26,448
    This is the Clothing Converter thread. Why is anyone converting hair with a clothing converter? Or is the message just posted in the wrong thread?
    hi...
    thanks!
    j
    @Barbult had a good point.  This should go in one of the hair threads.
    G8 to G9: https://www.daz3d.com/forums/discussion/636311/released-rssy-hair-converter-from-genesis-8-to-genesis-9-commercial#latest
    G3 to G9: https://www.daz3d.com/forums/discussion/673486/released-rssy-hair-converter-from-genesis-3-to-genesis-9-commercial#latest
    G3 to G8: https://www.daz3d.com/forums/discussion/295951/released-hair-converter-from-genesis-3-female-to-genesis-8-female-commercial#latest
    There are others but you get the idea smiley
  • ravenhope23ravenhope23 Posts: 3
    edited October 2024
    hello i was hoping to get a little help with the clothing convertor i had run the convertor a day ago but due to a HD issue the file path i had set was lost as in Deleted along with everything else on it, was a new drive so nothing major was lost but now when i try to run the convertor and add the directory it just skips everything and doesnt add any of the items at all i do get the pop up about checking the options to allow overwrites and ingnoring existing files but even after checking the boxes i still wont load the directory and looking at the log it just says skipping every item any help would be apprieciated
    Edit: Never mind i figured out what i was doing wrong i didnt realize i was in the g9 directory...
    Post edited by ravenhope23 on
  • Should converting a converted item be possible?
    I have a G3 item I've used your G3F to G8F converter on.  Trying to go to G9 and goes through the process until it freezes leaving the G9 figure, the conversion follower and clothing item in the scene (exiting Daz then causes a crash).
    I get the same if I try to go G8F to G8M with your cross gender clothing util too.
    It leaves a duf.tmp file where it is converting the item to.
    Not sure if it will work.  I need to see the Daz log.  Load the daz log in a text editor like Notepad++, run the converter again.  When it crashes, go back to Notepad++ and it will say an external program changed the log file, have it load the changes.  That is the part of the Daz log I would like to see.
  • rejemyrejemy Posts: 0
    I was excited to get this clothing converter because it opens up many more options for getting clothing for Genesis 9 characters. I must be doing something totally wrong though, because so far the results seem pretty wonky. I tried testing it on a simple piece of clothing, the "Basic Wear Sports Bra" from Genesis 8 Starter Essentials. It came out looking pretty warped, as you can see in the first screenshot. I tried loading the uncoverted original on the same Genesis 9 figure without using the converter, just using the built-in autofit, and it came out way better (second screenshot). In both cases it was using the "Bodysuit (tight)" template. Any ideas?
    1424 x 1382 - 2M
    1650 x 1646 - 2M
  • Similar to one of the other commenters in this thread, I also am unable to convert any shoes successfully with the G8-to-G9 Batch Converter. None of them. All will come out with warped appearances.  Attached is an example of the log file when an attempt was made to just convert one shoe product. I have tried with and without the Foot Converter.  All shoes come out a mess.  I don't understand what that Foot Converter is really supposed to be doing.  Is it somehow supposed to affect the shape of the shoes or just how they get attached to the character?
    Notice that I also get this message when executing the program:
    'data/RiverSoft Art/Common/RSClothingConversionFunctions.dse' could not be found in a mapped content directory. Check the installation and try again
    Attached also is a Content Directory Manager screenshot.  I have uninstalled and then reloaded the program using Daz Installation Manager just in case something initially went wrong.
    Please advise.
    Please understand that I know very little of the inner-workings of Daz Studio.  I have had no experience creating clothing, so my knowledge of clothing only consists of clicking on it to make it appear on my characters.  So any explanations of a solution have to be VERY precise and concise, avoiding any terminology that could be confusing.  For example, when you refer to a conversion "mesh" in the instructions, I don't understand what you mean.  When you talk about applying "conformers", I don't know how to do that.  I think I see what you mean when I click on a G8 clothing object and try to fit it to a G9 character, but I don't know what you mean when you say applying a conformer to a clothing item using this batch program.
    txt
    txt
    log.txt
    52K
    1005 x 670 - 134K
