The precision in Fisio RB has embedded the substeps; precision 2 uses the same method as precision 1 but with ten times substeps.
Hi,
Thanks for the info.
How many substeps in precision 1?
100 substeps per frame (thus, higher FPS increases the total substeps of the simulation).
The 3 and 4 precision levels use other methods, each at 200 substeps per frame.
All the levels of Precision automatically increase the substeps if there are links in the scene. Precision 1, by 16 times, precision 2 and 4 by 10 times, and precision 3, two times.
So in a sim with links at precision 1, there will be 100 X 16 (1600) substeps. That is a lot.
I am attaching a scene file to show issue I am having. It is a simple rig. A main body with 8 cubes (4 blue, 4 red) and a ground see pic.
I ran a number of sims with different fixed links.
1. Body with 4 fixed links, one to each blue cube. P1 (precision 1) and P2(Precision 2) both failed (blue cubes moved)
2 each blue cube fixed link to body. P1 OK
3 I added fixed links from red cubes to blue cubes (as in scene file) P1 red cubes translated along X, failed. P2 red cubes translated along X just more slowly.
4 I changed the links of red to blue and made them blue to red, still failed.
The only way I found to get the fixed links to hold was to reduced the Density of the main body down to 10 (from default 1000), which IMHO should not be needed.
When running a sim on my main test rig, there are wheels connected to the main body via 4 links (suspension system). Reducing the main body density is not a solution, as the density of the other objects in the links are causing issue to the other links. I have attemted to balance out the density of the objects to get the rig stable. But not been able to.
Use the Precision 4, it's the more robust when using links. I tried your scene with P4 and it worked.
Hi,
I posted the simple rig to highlight the problem with materials. But you do not see that as an issue.
On the more complex rigs I am building, if simply changing to precision 4 was a solution to the instability in the rigs I see, then I would use it, but it is not.
As no one else has reported these problems, which is probably due to no one building complex types of RB rigs, I will stop taking up our time on this.
I'm having this same issue. CFF Explorer reports the same missing DLLs, so I tried installing the VC++ Redistributable you linked to. The installation failed, as I already have a more recent version installed (which I reinstalled, but that didn't solve the problem). Any advice?
Edit: One thing that might be worth noting is that, when I click "Run Simulation" a second time (after it fails the first time), Daz Studio crashes.
If the redistributable installation fails, it usually is because it's already installed.
Could you post a screenshot of the contents of the "/DazStudio4/libs/Fisio" folder? And a post of the report of CFF Explorer, please.
Also, not sure if this is relevant, but the non-softbody version of Fisio seems to run fine on my system. Only FisioSB is giving this error.
Is Filament working in your system? Check, please, "dzfilamentapi.dll" with CFF (it's directly inside "/DazStudio4/").
If with Filament you see the same missing, you can update your system with any (or both) of these Windows updates;
CFF Explorer seems to be showing the same files as missing for dzfilamentapi.dll, but, oddly, Filament runs fine. I tried updating with the files you linked to, but installation fails with the error, "Another version of this product is already installed." Very strange...
Yes, very strange: CFF and FisioSB both miss the files, but Filament doesn't. Let me see what I can find about it.
Have you found a solution to this? I am also having the same problem as described above and have went through the different steps as well.
Also, I've manually installed the api-ms-win-crt dlls such that there's no missing dependencies but the simulations are still failing in the same way as before unfortunately.
If I try to "Run Simulation" again after the error message, then daz studio crashes. A crash report snippet is attached.
Not yet, but your CFF report could help.
The "api-ms-win-crt-heap-l1-1-0.dll" in your computer is for a 32-bit machine (it says Portable Executable 32), but the requirement is a Portable Executable 64. So this file is not compatible. Could you install the 64-bit version?
See the following image from my computer:
I just purchased this and have the same issue, Filament works perfectly. but the moment i run simulation i get an error and the second time it just crashes daz for me all together.
Try the following. After each step, check if the plugin is working.
This may be not feasible, but is there any way to get some presets for characters, even if as a paid add-on? My computer is old enough that trial-and-error with a crash-prone DAZ is not an enjoyable prospect.
It could be a good idea. But, I'm just preparing an update to fix some bugs, adding a new, more stable, method to make the plugin more manageable, If after this update is necessary, I could try the presets you said.
Please, run the attached script in Daz Studio to see if the library is inside the proper folder so the plugin can access it. It will show a message saying if the engine can be located.
Can Fisio be used to create an animation of a human figure with limbs that have lost their strength and fall over?
Would Fisio be able to represent a scene such as a human figure falling down a flight of stairs?
Like a ragdoll?, no it canoot.
An update, soon to be available, could partially animate skeletons (e.g., selected limbs) using the cable model type.
I appreciate your response.
I am eagerly awaiting your update.
It's quite challenging to create the effect of people falling over by hand.
I believe the updated features will be beneficial.
I am also looking forward to seeing “Mopat for Daz Studio”.
I think it will be an indispensable tool for animation work in Daz Studio without “Path Constraint”.
Will this work to properly animate breasts or male anatomical elements?
Thanks.
Came here to ask this, so I'll second it.
I already bought it and have been trying to do a simple animation with a G8F figure moving up and down, I'm using springs with the active facets only option to select only the mesh for the breasts. Sadly, they deflate completely. I tried using the skin young presets and same results. I did notice increasing density helps a bit in keeping the shape but then gravity affects them even worse. Also, the selected mesh now doesn't seem to follow the figure at all. Turning off the gravity stops the breasts from deflating but then the breasts just stayed in the same place while the figure moved up and down. Then I tried doing a collision with a rigid body and I just couldn't get any bouncing back effect, it almost just feels like a regular dforce sim.
So I'd like to ask if you could show how to do it like in the nose press promo picture and if this can actually be used for bouncy animations with figures (and how)
Thanks!
Use Shell instead of Spring. There are some presets for the Fisio Materials (in Smart Content - Props - Fisio SB - Materials (they're not surface material for renders, but properties preset applicable to the Fisio Materials.
If you use Spring, use the Stiffness of the Spring property to control the stiffness.
You can't animate with keyframes the Soft bodies, but you can transform the simulation into morphs and then disable the soft body (or unsign it as a soft body) to use the morphs.
The soft bodies and the rigid bodies can collide, but when using the Non Smooth contacts System type, the objects tend to stick. What are the settings of the bodies and the system you used?
Thanks.
Thanks!
How do I transform the simulation into morphs?
Click on the button Create a morph... in the Pane, and select the initial and last frame for the calculation of the transformation.
This may have been asked before but does this work for different poses in G8 characters? I'm looking to animate one such character passing out on the floor.
It works with any figure. The requirement is that the geometry is closed or nearly closed. G8 characters are nearly closed.
Hey this plugin is amazing. I'm trying to use it to make gen 8 or 9 figures able to interact with one another as well as furniture. I want to be able to have skin depression on both figures as well as depression in a couch. Is there a way that a figure or object can be set up as both soft and rigid and is there a way to add "jiggle" (for lack of a better word) to the fatty bits of a mesh?
Hi! Thank you.
Any object should be either rigid or soft, not both.
It's difficult, but there are some options, for example:
You could try to simulate the object as a soft body using selected facets to generate the deformations, then use create a morph. The morph can be used in a subsequent simulation setting the object as a rigid body (enabling updating shapes).
Or you could simulate it as a soft body using a proper material node (i.e., some not too elastic).
Or you could use separate objects, one rigid, the other soft (ie, a hand as soft, and a body without a hand as rigid.
Hi,
Thanks for the reply.
Hi,
Regards,
See this also: https://helpdeskgeek.com/help-desk/how-to-fix-program-cant-start-because-api-ms-win-crt-runtime-l1-1-0-dll-is-missing/
Let me know if the problem persists.
Hey, thanks for even thinking about it! It's also great to hear you're still improving the plugin.
FISIO SB Engine will not start MacO when I click RUN SIMULATION
Files are installed in /Applications/DAZ 3D/DAZStudio4 64-bit/libs
Help???????
Did Fisio, the main plugin, work?
Yes. Main Plugin works just Soft Body plugin giving error when I hit 'run simulation'.
OK. Let me know, please:
I believe I have the latest. It was installed with DIM.
First, let's see if it was correctly installed.
Alvin, I appreciate the help. Here is the output I get from the script with MacOS Sonoma.
I forgot to mention that I AM able to get the plug in to load and work, run simulations, on my WINDOWS machine.
I sent you a PM.
Thank you!
Hi! Thank you.
