Show Us Your Iray Renders. Part III
12467…50
  • HoleHole Posts: 119
    edited May 2015
    no just Photoshop, haven't opened up Fusion yet
    the fog is the sss trick everyone else is using for fog in iray..Cheers!
    Hole said:
    finally getting a bit of time to look into Iray :)...first renders..
    *didn't notice the paint flakes on the car were too large 'till it was too late
    Did you use Fusion for the particles and fog in the Mustang scene?
    Give it a try, with Iray passes and fbx import you can do some pretty crazy stuff and I'm finding it easier and much more flexible than PS for comp.
    Here's what you can do with basically just 2 planes:
    https://www.youtube.com/watch?v=sIKkwNYojUs
    edit-just rewatched that, it's actually a single plane...
    Post edited by Hole on
  • tomtom.wtomtom.w Posts: 140
    edited May 2015
    *Deleted by poster*
    This was my last attempt to get some form of response, but I guess I'll have to accept that this is a private club where I'm not a member.
    So over and out.
    Post edited by tomtom.w on
  • StonemasonStonemason Posts: 1,259
    edited May 2015
    that's pretty cool,thanks
    Post edited by Stonemason on
  • MEC4DMEC4D Posts: 5,249
    edited May 2015
    Made for you HDRi map for face shots
    the scene is included also so just put the unzipped files in My Library folder and load the scene from the last Beta 0.44
    the scene is under : My Library\Light Presets\MEC4D\HDRI STUDIO
    you can change the Dome rotation , 45 degree is the front and 90 degree is the actual studio room with the light on the side .
    the base light shine at 9 o'clock with shadows
    The Draw Dome is set Off .. When you set it On you will get kind of scene set
    The Finite Sphere with ground is scaled to match the HDRI maps and light power
    you can add extra ISO under tone mapping for more light power no more than 200 ISO
    and change the white point for more cooler or warmer light
    Files (893 KB total)
    MEC4D_HDRI_STUDIO_LIGHT.zip
    Will be deleted on
    15 May, 2015
    Download link
    http://we.tl/78QcRSkXGs
    Four images removed by a mod
    350 x 450 - 75K
  • TimbalesTimbales Posts: 2,456
    thanks for sharing!
  • Oso3DOso3D Posts: 15,125
    Very nice of you, Mec4D!
    Always a fan.
    edited May 2015
    Thanks,
    here are example of changing the light in the scene, from cool to warm
    or any color you want See the Tone mapping Settings bellow
    it is small size and save the memory ..and produce less noises .
    I will make more soon with some outdoor simulation
    Images removed by mod
  • 8eos88eos8 Posts: 170
    tomtom.w said:
    I'm not at all happy with the hair, but I have given up on it after trying just about everything, so I'll just keep it as it is until someone releases good Iray hair...
    Have you tried Taigafaeri's settings: http://www.daz3d.com/forums/viewreply/801975/
    They've worked pretty well for a few of us around here.
    edited May 2015
    If you don't have cornea bulge morph you can use the cornea setting bellow
    works nice with the new HDRI map
    I am using 2.66 for cornea and liquid inside the eyes at once
    1920 x 1040 - 811K
    Post edited by MEC4D on
  • MusicplayerMusicplayer Posts: 515
    Leave it to Stonemason to make his first renders beautiful! Here is one I did the other day for my tabletop RPG group. It is lit only with an HDRI and I think it came out pretty well! I did notice however that it has some blurriness that makes me think of depth of field, but I didn't have depth of field active. I've seen this in some other renders as well and I'm thinking Iray may actually have some kind of auto-DOF for wide angle shots like this.
    Hi Riggswolfe,
    Very nice dramatic render.
    I have noticed that some of my renders do not appear to be as sharp as I would like. I have played about with DOF being on and off, but the results have been the same. I cannot say this is specific to Iray because I have had it happen with 3Delight renders too.
    I did see in a post on one of the forums, it was suggested to go into Render Settings - Filtering - Pixel Filter, and there is a selection of filters : Box, Triangle, Gaussian, Mitchell, and Lanczos, to use.
    The post suggested to try another filter, as the default Gaussian Filter may soften edges and be causing this. Something I am now going to try myself and see if it makes a difference.
    Kind regards,
    No private club here my dear..
    you should see this one, as that's what you need
    tomtom.w said:
    *Deleted by poster*
    So over and out.
  • none01ohonenone01ohone Posts: 862
    Thank you very much MEC4D for the HDRI scene. Appreciated.
  • TJohnTJohn Posts: 11,448
    edited May 2015
    NM.
    Post edited by TJohn on
    rendered using MEC4D's lighting rig
    I've been working on eye settings and i think I've hit on some that look nice. Here they are for whoever is interested:
    EyeReflection: default Glass-Thin-Clear shader
    Cornea: Glass - Solid - Clear - Dispersive (rainbow) shader, cut-out opacity set to .25
    Sclera:
    Base color - White + V5BreeEyesM
    Translucency weight: 0.25
    Base color effect - scatter and transmit
    Translucency Color: 212-61-215 + V5BreeEyesM
    SSS Reflectance Tint - white
    BaseBump : 0.35 + V5BreeEyesB
    Thin Walled: off
    Transmitted measurement distance: 2.5
    Transmitted Color: 204-24-255
    scattered measurement distance: 0.1
    SSS Amount: 1.0
    SSS Direction: -0.5
    Iris & Pupil
    Diffuse Roughness: .5
    Glossy Layer weight: 0.5
    Share glossy inputs - off
    Glossy Color: White + V5BreeEyesM
    Glossy color effect: scatter only
    BaseBump : 1.0 + V5BreeEyesB
    Top Coat Weight: 0.5
    Top Coat Color: White + V5BreeEyesM
    Top Coat Color Effect: Scatter and Transmit
    Thin Walled: off
    scattered measurement distance: 1.0
    SSS Amount: 1.0
    SSS Direction: -.5
    800 x 800 - 966K
    TimG said:
    thanks for sharing!
    +1
    "Those Left To Mourn"
    1250 x 1500 - 401K
  • RAMWolffRAMWolff Posts: 10,393
    It's really really nice to see such a natural face morph. She looks very realistic. Great lighting on her as well. Breath of fresh air from all those perfectly pretty faces out there. That's one thing I miss is Surrealities work.
    pearbear said:
    Thanks for pointing out that new little HDRI included in the latest update. (mentioned by a few people in the previous thread) It's a great one. Here are a couple of renders using it as the only light source. There are some palm trees and other props added in the background of this scene too, very out of focus. The figure is a custom G2F morph wearing Hongyu's Bikini for V6.
  • EdheldilEdheldil Posts: 41
    I like the translucency effekt on her nose! I only add the G2F-Iray shader to the skin!
    Skin: Belle 6
    Char: Belle 6 with some shapes/morphs
    Light: 1x meshlight
    no postwork
    With postwork look here: http://fav.me/d8revcq
    1500 x 2000 - 250K
    edited May 2015
    Nice one Tim
    here is one more HDRI map for you to use with the preview scene from the other ZIP
    Day light
    Files (368 KB total)
    MEC4D_HDRI_STUDIO_LIGHT (2).zip
    Will be deleted on
    15 May, 2015
    Download link
    http://we.tl/CcNaIOyU1m
    Image removed by mod
    Mec4d, do you suggest the 2.66 with 'corneal bulge 1,' or is that strictly for lacking it?
    Works in both but if you don't have the corneal bulge you need to adjust the glossy as in the shot I posted moments ago
  • RiggswolfeRiggswolfe Posts: 916
    Hi Riggswolfe,
    Kind regards,
    Did it mention which filter? Unfortunately I don't know much about that aspect of 3d...
    edited May 2015
    Continuing my series of Benders...
    I'm not thrilled with the ground, but this is more of an idea sketch than my 'real' stuff, so whatever.
    And again, I'm making creative use of Soldiers of Magic Serpio.
    (I also need to get some martial arts pose sets at some point)
    2000 x 2000 - 2M
    Post edited by Oso3D on
    Hi Riggswolfe,
    Kind regards,
    No, it just suggested picking another filter and trying the same render scene again. I too have no knowledge about how these different filters work or, if they will make any difference. I think the poster of the article just said to try a different filter type and see.
    Hope this helps, and I am going to try the same, and see if there is any noticeable difference to focus clarity of my renders. Sadly I have searched endless forums and cannot find the original post again. :-/
    Cheers. :-)
  • ToyenToyen Posts: 2,080
    Victoria posing.
    HDR Dome Lighting only.
    No Post-work
    556 x 897 - 537K
    Cath, that HDR is simply amazing.
    I'm doing a 3DL render with that exr file (get to a Iray render later...maybe...one of the downsides of using my HTPC for my Iray test box) and well...(yeah, sort of heretical to post a 3DL render in this thread) but...
    800 x 800 - 690K
  • Richard HaseltineRichard Haseltine Posts: 111,751
    Please bear in mind, when posting images, that we cannot allow nudes - even if they lack details on nipples (for females) and genitals. Images should be cropped, posed or clothed to cover.
    I see it produce some shadows too in 3DL , little light intensity up and would be just fine
    actually I did manually added the right light curve
    bellow also tested my dragon eye with the last HDRI map
    1920 x 1080 - 3M
    800 x 800 - 289K
    Oh she was wearing skin colored body suit .. lol j/k I will remember next time
  • j cadej cade Posts: 2,310
    I am never going back to not using caustics. So much fun!
    Some minor postwork, mostly just defireflying. Also originally the signature was going to be postworked, but I changed my mind and re-rendered the bottom corner. Thank you to whomever in this thread mentioned that you could spotrender to a new window.
    I really like the hands also the light on the knee.
    Pose was shamelessly stolen off a Sargent painting.
    As ever, larger version in my gallery
    1333 x 2000 - 1M
