Show Us Your Iray Renders. Part II
Adding to Cart…
Thanks for the tips, I will have to experiment more...
I was responding to MJC's comment, to clarify the difference between the two scales. (Which makes a huge difference when looking to outside sources for PBR information.)
Some other charts for reference
Albedo http://www.sc0ttgames.com/?p=464
Specular http://www.sc0ttgames.com/?p=443
Pretty darn neat.
There has to be a reason.
What colors are used in that preset? I'm not at my render PC right now
The cube mirror I used in the image is .95 .91 .84 Base, 1, 1, 1 Glossy with Glossy Reflectivity 1 and Glossy Roughness 0.04. I started out with Iray Platinum, lightened the Base quite a bit, maxed the Reflectivity, and brought the roughness down as far as I could before things started going yellow.
Absolute NOT .. it was good you mentioned it
I actually checked the color profiles in my Photoshop what was not on sRGB as I used other profiles for editing photos half white 0.5 raised by the inverse of gamma 2.2 which equals 187 in Photoshop and not 186
it is very important to have good setting in PS before making any maps for PBR rendering, sRGB profile is used to avoid artifacts and for Grayscale with Gray Gamma 2.2
You need to rename it to have the zip extension and then extract it.
Thanks. Weird way to upload something but I got it.. Thanks for clarifying! lol
Yeah...why he didn't GoogleDrive or Dropbox it, I can't understand. That's what most other WordPress users I know of that want to put up files that WP won't allow do.
It's because Wordpress doesn't allow the upload of Zip archives. But as long as you make your stuff an accepted filetype, you can upload anything you want.
So, let's see if I'm grasping things.
Skin melanin is going to change albedo (more pigment, lower albedo)
It's going to also affect specular color, in that different pigments will add color (a range from yellow, red, dark brown, almost black)
Also translucency, as more pigment, more opaque.
These would entail fairly similar but not identical maps.
Is this roughly correct?
Albedo Cheat-Sheet for Physically-Based Rendering
I'm only going to comment on the specular here.. because I am pretty sure the answer there is no... it doesn't change the specular color. Only metals, if I recall correctly, tint their reflections which is what specular is (alright, alright, so is diffuse... but lets not get that deep into it).
I could be wrong, its happened before.
Hey there!
I wonder, is there a way how to make the light being emitted from an environment image stronger without the image being washed out?
and you are right 100% skin specular color is RGB 51 51 51 what is monochromatic
you don't plug specular color maps
you can control the glossiness level with a grayscale map
in my all renders I never used specular maps at all , as I control the micro surface with normal maps
and made specular catcher map for the hair and eyebrows the same as translucent shadow catcher
The pigment hue should go where, then? Base color?
The two characters that I primarily use for learning DS, with modified skin and hair textures. I've tried various settings for Glossy Roughness (with Glossy Reflectivity set to 1.0), but found that settings much lower than 0.30 made their skin too shiny, more shiny than I can recall ever having seen a pale-skinned person be IRL, other than in a sauna or when soaking wet.
Some people will probably feel that the colors in the image are too saturated, but I'm deliberately going for a look that simulates conventional 35 mm slide film such as Kodachrome and some films from Agfa, which delivered slides with very saturated colors.
I like glossy roughness at .4 or .5, and then use top coat roughness of .2 or .3 for sweat or water.
Tks, I'll try that.
Why did you choose to set your reflectivity so high?
I use much lower, 4.5-5. The descriptions says that it roughly corresponds to IOR and that .5 is a "good plastic base" so I am guessing that should be around an IOR of 1.5... a very good range for skin.
I also always use BOTH glossy base and top coat, not relegating top coat to effects. I find its necessary.
I'm new to DS, having used it for less than two months (other members of my immediate family have used it for several years, though, and have lots of content that I can play with, but I've never been interested in DAZ Studio before, preferring to spend my time on other things), so I haven't gotten around to changing the settings for the top coat yet... :)
Not on skin that is, only on car paint, chrome and shiny stuff like that, which is a totally different ball game.
Allow me to make a suggestion, tomtom.
You have a layered shader to accomplish what you are looking for. Build it in layers.
Strip off all the layered weights until all you have is the base, render that and see what it looks like. Then start adding in the other layers, mixing and matching.
Base is layered over transmission, which I am guessing includes both translucency and sss, Glossy is technically part of the base but is its own layer over the base, with Top Coat over the top of it all. And metallic flake in there some where but I haven't really touched it yet, though I did read someone suggesting they were using it with their skin set-up.
I thought about Cath's useful tips which prompted me to also try something in Photoshop. The best I can say is to try it out and see if it works for you
1: Load a face texture you like (Background layer) .
2: Duplicate the layer (Background copy).
3: Add a mid-grey Colour Fill layer sandwiched inbetween Background and Background Copy.
4: Change the top layer (Background Copy) blending mode to colour.
5: Duplicate the background layer again (Background Copy2), move it to the top of the stack, change its blending mode to Overlay and set its opacity to 50%.
5 Alternative: If you have the Flaming Pear PS free plugins, use Tachyon on another copy of the Background, place at the top of the stack, set to Overlay blending mode, reduce opacity to 50%.
Worked not too shabbily for me.
http://www.flamingpear.com/download.html
I loaded Michael6 skin map in Photoshop , reduced the Vibrance to -60 the effect is excellent nothing else to do with working great with my sss shader now .
Very nice, mec4d, very nice indeed.
Thanks, here test with different HDRI light maps
M6 with edited maps only diffuse and normal and my final SSS skin shader
each render took just 2 min
I want that jumper.
He looks fantastic.
I've heard them called sweaters, sweatshirts, and hoodies but never jumpers.. jumpers are little girls dresses, at least in Wisconsin where I learned to speak American.
Thanks :) the jumber is not finished yet it is a part of full set with shirt pants and shoes for my upcoming Buddy 3
just rigged it for my iray tests
I've heard them called sweaters, sweatshirts, and hoodies but never jumpers.. jumpers are little girls dresses, at least in Wisconsin where I learned to speak American.lol, same in the northeast.
I have to admit, the past several pages got me lost a few times, lol. I thought the sRGB scale in the computer was based similar to 'Perceived brightness'. A few other places seam to indicate as much, that 127.5 (127 or 128 RGB) is 0.5, is mid gray???
http://en.wikipedia.org/wiki/Gamma_correction#Power_law_for_video_display
So if I under stand the chat, 187 values of darker gray, and 68 values of lighter gray??? (When picking colors in that sRGB window thing)
From a British/American dictionary...
jumpers, pullovers and cardigans are family when hoodies and sweater having baby it is called Jumper lol
