UltraScenery - new territory [Commercial]
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
https://www.daz3d.com/ultratrees--arboretum-volume-2
https://www.daz3d.com/ultratrees--realistic-tree-system
https://www.daz3d.com/ultratrees--arboretum-volume-1
OK, so you are here, and don't see trees other than the Oak?
Yep had them all. ;-)
I have all these too.
That is correct.
(And by the way, this topic is misplaced. UltraTree is not part of UltraScenery.)
When I get home I'll see where I can move this topic.
I tried a search in Props by 'Ultra' and along with UltraScenery the UltraTree products showed up.
I looked at the only other main forum post, which was on The Commons. There doesn't seems to have been a Commercial thread. The product was mentioned here, in Novica's thread and a couple others. Just pull up the promo in the store for the latest links.
I searched for a place to move the topic but nothing. Hopefully this is solved soon.
C:\Users\Public\Documents\My DAZ 3D Library\data\HowieFarkes\UltraTrees\UT Birch 01 is not a Daz Studio content library. It is a subfolder nested several layers deep inside a content library. Other than that, things look correct. Is C:\Users\Public\Documents\My DAZ 3D Library\data\HowieFarkes\UltraTrees\UT Birch 01 REALLY what you have set in DIM as the library to install into? I imagine it should be just C:\Users\Public\Documents\My DAZ 3D Library.
Locate UltraTreeCreator script file in your Content Library. Right click on it and select Browse to File Location. What is the full path of the folder that opens? (Please post the path here.) Is that the same folder that contains the Trees folder with the tree subfolders you listed above? Or is the Trees folder you looked in before, in some other path hierarchy?
C:\Users\Public\Documents\My DAZ 3D Library\Environments\Landscapes\UltraTrees
I don't see anything that hints at why it is not working. When you run UltraTreeCreator script, are there any errors reported in the Daz Studio log file?
When I made this winter scene I use snow shader on the grass, except the tufts. I'm not sure but I think they were from Iray Snow, Ice and Ash. But the trees were from Winterland Trees. Not a perfect solution but worked in a pinch. Imo, for a winter pack of Ultrascenery the trees should be doable, but snow on the ground is probably pretty difficult generate dynamically.
For what it's worth, unless the snow is really deep, grass tufts will stick out at first. As the snow continues, the tips finally disappear and then get squashed down. Or later in the season, grass is dormat and gold/brown/grey and flat so the next snowfall may lay flat right away.
Our big snow in December hadn't fully disappeared, when this last on arrived on Wednesday, so we have added to it. Another due tonight into tomorrow. Normally we melt fully between hits. This year it is accumulating. Good for ground water.
@lou_harper, that is a lovely, happy render. I love the overall blue effect. Makes me feel the cold. It helps that this morning was in the teens.
Thank you.
Playing with upcoming Octane VDB, The clouds are made from a VDB version of the terrain. Not bad at all.
More practice with snow. This is a highly modified Pacific NW 4, with a mix of Materia Meshmaker and DA Let It Snow (which, after testing, I like better for trees than MARSA), with a little Ivar thrown in, as I bought the Ivar bundle recently and was testing stuff from it anyway. Where I used to live, last night's snow would usually look something like this the next day, leaving only what I called the "shady side snow" by a day or two later.
Nice winter images and great tips from @lou_harper
I have to try the other shaders/solutions for snow on the trees.
For the ground, I am satisfied with the DA Let it snow solution.
there was a list of what has been included within USC, but now I can't find it. It was a different one than what Howie has listed. Were any new features added with Britain module?
I think @barbult made a list.
I don't recall making a list like that. The only list I know of is the one in the first forum message, but it is out of date. There are new plants and ecologies in Britain, but no new features that I know of.
OK thanks. Someone else had a list with all the ecologies, features, etc etc. Yeah, I was trying to find new features and didnt see any. There are wider paths, double paths, etc in the product photos, and I was trying to find them. Do they just add automatically to some whatever terrain?
Maybe you are looking for Landscape Features Volume 2. But even the base UltraScenery package has a double path (Dirt Track 1).
like this. Is this an optical illusion or is it wider? The double paths in this Britain product look wider as well
I had a list, I tried to update it this morning. But I want to note that the product page for the UltraScenery Landscape System has the main products that use it at the bottom. But not the required products for it. This is a Word .doc and I may have missed something since it is not in A - Z. I keep all products for UltraScenery in one folder to keep from going crazy.
Mary
If anyone finds something I missed, please let me know, I will be back online later today.
Richard,
This is definately not correct. USBritain is an ecology, it can be used on any landscape feature.
Cheers,
Alex.
