Adding to Cart…
My new clarinet is modeled in Hex, like all my stuff.
https://www.daz3d.com/clarinet-and-poses-for-genesis-8-and-81
Thank you for the info FirstBaston
You're welcome. I picked up the perpetual license version before they went to the subscription only option. Well worth the investment.
I think you got a great deal, it looks very expensive
I will say that the time saving is worth it. Even if the output is not always what you want. There is a bit of trial and error involved and learning curve too to figure out the best masking options for the layers.
For example, the red painted metal that I used on this donation bin looked kind of boring on its own, I added all the signage, the water damage and the rust to the textures in the traditional art program way to give it a more aged look.
Made with Hexagon 3D
Very nicely done FirstBastion.
I wonder how many PA's still use Hexagon, I know of at least half a dozen.
Very nice indeed!
I know of FirstBastion, DzFire and myself using Hex.
Concept for more display areas of textures, the model will be integrated on existing platforms.
Stairs or staircase is still being built, we are not yet decided.
Nova, looks great
Great bastion
"even the output isn't always what you want"
Some discoveries and inventions started this way
Thank you mach25,
we always like to look at the models from all of you and are happy that you share them.
Parallax cube
The cube currently has 3 levels.
Two are used, mannequins and back wall.
INFO ______________________ https://wparallax.com/
wParallax Free Scene
_______________________ https://wparallax.gumroad.com/l/YyRmU
011-00_ Parallax Cube_ 000-00_ JPG 000-03 / mit 3 Ebenen (siehe INFO unten)
INFO Parallax Cube
https://www.youtube.com/watch?v=KVxVeWvxE2A
_
_________________ Serie_ MOMO
Great texture work Nova, I really like your futuristic designs
Thanks John old friend, sure, did you notice that we made a small call so that Hexagon is not forgotten, do you have any idea what the future holds? The moderators haven't gotten back to us yet. What does the rumor mill say? We often advertise Hexagon, many people don't even know about it, that this program exists.. ^^
Great nova
After I found I was more compatible to hexagon interface than other 3d modeller, First challenge myself, after each video describing function had experimenting it,especially exercise creating flowers with those similar to clay modelling functions
Now I got inspired and gonna try new kind of challenge : set x hours deadline to improve productivity speed
@ Now I got inspired and gonna try new kind of challenge : set x hours deadline to improve productivity speed
We always set ourselves times by which a model must be completed. However, to follow this path should be well familiar with Hexagon, there are many tricks. We spent days at the beginning of Hexagon trying to avoid mistakes, because when you make them, it becomes very difficult to correct them later. These mistakes happen when you export the models to other platforms like Lumion or Twinmotion. Also the export, meanwhile from Hexagon to Blender version_ 3-2-2 makes problems.
Please do not put yourself under pressure, good things take time in the beginning.
Work should be carried out to scale.
Everything has a DIN standard with us. Thus, they can connect all models without changing anything.
The objective should never be making money, but passion and joy in building.
There is no better hobby for us to relax and forget the world around you for a short time, which is becoming more and more stressful.
There will be a constant update here.
Just check back often if you like.
The whole thing will be expanded and developed from day to day.
Made with Hexagon
Building for modules.
Inner courtyard open.
Time limit 4 hours
@Nova...
wow +++
--ms
Nova great work
one of the photos is a girl with vrglasses,now got curious if you use such to test experience in mall is walking around with help of Unreal engine?
@ one of the photos is a girl with vrglasses,now got curious if you use such to test experience in mall is walking around with help of Unreal engine?
Thank you both,
I guess it must be an older work. __ ^^ __
Well, we really hope that Lumion 2023 will support VR and we won't have to switch to Unreal. Man is a creature of habit.
Update_
Google Maps
3-D map of Worms, you can plan buildings to see how they fit into the cityscape.
Love your renders Nova
Thanks John, these sketches are always good when it comes to illustrating the models. I also like the line drawing myself. The model is now placed in the other scene. There we found the Comicsysle for DAZ figures.
A small project in between, we were looking for a fir tree that should look a little more modern, when we saw the cat, the decision was clear. ^^
We used room 001-00, as there was still a corner of space here.
We are using the model for a group of islands and are expanding the landscape.
We are still experimenting a lot.
Especially with alpha textures, beautiful surfaces can be realised. Everything still needs to be optimised.
Nevertheless, we show it so that you can see where it's going.
The time limit was 5 hours, the model was created from a curved surface. Now follows the elaboration.
3-fold textured windows.
Here the glass panes consist of three texture layers.
Glass / PNG / Glass.
We will convert all windows.
Hexagon
Nice :)
Thanks John
Villa with pool_ slope _________ 80% Completed
Current work _ Villa 000-00 & 001-00
Modern / White / Southern Region
Villas with a slope, the time limit here was 7 hours with planning. I had to start again because I had to cut out the section for the conservatory from the model.
Update 28.12.2022
The model gets an update.
Two modules are put together.
Each module has its own textures and can be varied independently of the other.
