Genesis 9 we are back in the game Carrara users
edit rigging blended weight
save as character preset
now I better do the eyes etc
«1345
  • ProPoseProPose Posts: 551
    edited October 2022
    You beat me to it Wendy!!!!  But I didn't convert anything, loaded it all right out of the box
    Post edited by ProPose on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,960
    I cannot get the eyes to work
    the other bits converted and saved as character presets do
  • Bunyip02Bunyip02 Posts: 9,345
    Expressions ?
    Bunyip02 said:
    Expressions ?
     all morphs seem to work
    I will look into eyes later, I need to cook my dinner
    edited October 2022
    Eyes, Eyebrows & Eyelashes appear to have problems.
    2278 x 1035 - 625K
    Post edited by Bunyip02 on
    I saved each as a character preset separately, they fit to it in Carrara and make sure not parented
    the eyes just won't load converted but I guess one could parent those unconverted if needed
  • DiomedeDiomede Posts: 15,474
    Disappointing about the eyes, but more successful than I thought it would be.  This is promising.
    edited October 2022
    Eyes and eyelashes saved as presets and loaded.
    2288 x 1033 - 802K
    mmm eyes work for you
    did you save as character preset or something else?
    did you convert to blended weight first?
    edited October 2022
    Workflow for the eyes:-
    Unparented from Genesis 9
    Converted to Blended weight.
    Saved as a Character Preset.
    Forgot the Eyebrows in my previous render.
    2278 x 1040 - 871K
    edited October 2022
    mmm wonder why mine fail to import, shall try my other computer Win10, was my Win 7
    same thing i/0 error
    maybe upload your eye duf (it's just a character preset so OK)
  • 0oseven0oseven Posts: 626
    If only Carrara could be provided with updated FBX import/export  - maybe that would fix things. Seems to be the default transfer method these days.
    Here you go, was for the female morph applied to one - also shaders need some work to get to operate okay.
    zip
    zip
    G9Fem4 Eyes bw.zip
    31K
    We want Carrara 9 !!!!!!!!!!!!
  • StezzaStezza Posts: 9,329
    I guess that's why Daz sent me a 'we miss you' email today! cool
    works yes
    I wonder why mine doesn't though, 2 computers, 2 installs, 2 libraries
    mmm D|S4.21?
    me too
    think everyone got one
    works yes
    mmm D|S4.21?
    Good to hear that it works for you !!!
    Am running DAZ Studio 4.10
    edited October 2022
    works yes
    mmm D|S4.21?
    AHa
    that could be the secret sauce, I have 4.11 on my Win7 but used the 4.21 beta
    same error basic wear but autofitted stuffs saved as support assets work
    and grew a nice mane of dynamic hair on him (simulated animation ) Mimic plugin works with 8.1 configuration dmc too!
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    WendyLuvsCatz said:
    me too
    I got one too, and then they closed my the thread I started on G9.
    edited October 2022
    ProPose said:
    WendyLuvsCatz said:
    me too
    I think I was a tad faster, sorry, really they should have merged them but not doing that in the other forums either
    If I had seen your thead I certainly would have posted in it rather than starting a new one blush we may have crossposted, no timestamps, I did repjy to yours when I saw it broken heart
    video
    edited October 2022
    Eyes - error then success
    I got the same error as Wendy when I tried to convert eyes that had loaded with the Genesis 9 default load.  I was able to convert and use eyes that I loaded separately from the anatomy folder.
    The error I got from the default load looks like the below.
    My successful eye conversion was loaded in Daz Studio without the G9 figure.  I found the eyes in the anatomy folder.
    The independently converted eyes load in Carrara for me without error and then fit to, follow, and morph with the head.
    1881 x 1090 - 188K
    988 x 798 - 90K
    1795 x 1189 - 277K
    1468 x 585 - 102K
    Post edited by Diomede on
    edited October 2022
    Basic Wear TShirt - Error
    I tried converting the TShirt from Daz Original Basic Wear.  Got an input error.  Still have not solved the TShirt error.
    1645 x 1140 - 195K
    I did notice the things that error get the dialogue in D|S that they are already blended weight
    edited October 2022
    I created my own simple TShirt and used the transfer utility to make it conforming for base G9.  Converted it to blended in Daz Studio.  During the conversion in Daz Studio I was given the warning that a blend map already existed but I just ignored it and did not replace.  I saved as a character preset.  Opened the blended TShirt in Carrara.  Conformed to a G9 base figure that was blended and saved to character preset.  The TShirt does conform to the G9.  The TShirt does morph when the G9 morph dials are changed (eg., base male or base female).  The TShirt follows when the G9 limbs are rotated.
    Very promising.
    1663 x 1186 - 206K
    edited October 2022
    Simple TShirt Freebie for Genesis 9 Base
    See zip attached.  Let me know if this works.  Note - it is just the TShirt for G9.  You will have to convert it to blended and save as a character preset to use in Carrara.  Let me know if there are any problems, such as bad data file mapping.  No shaders but the collar and sleeves are separate shading domains.
    zip
    zip
    Dio G9 Base TShirt ZIP.zip
    361K
    edited October 2022
    Repetition.  Simple dress by extending mesh of the TShirt.
    Same workflow.  Import to Studio, transfer utility to support asset conforming figure, convert to blended, save as character asset,
    Note - when I tried to use Studio's template for dress in the transfer utility it caused Studio to crash.  Not a Carrara issue though.  Transfer utility worked fine not using any template.
    1975 x 1308 - 290K
    1975 x 1308 - 290K
    nice to see things are happening with G9
    I also had trouble with the Tee but didn't bother to look any further... the Male poses folder was enough for me after controlling my laughter at the lame attempt of just filling the folder with what they filled it with. no
    edited October 2022
    ok.. loaded up with a G9 masculine pose supplied by Daz laugh
    thanks for the eye tips... loading from the anatomy did the trick..
    800 x 600 - 966K
    Post edited by Stezza on
    edited October 2022
    G9 at the Beach
    1600 x 1200 - 5M
