• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1…16171819202122…49»
  • siocsioc Posts: 328
    August 2014 edited December 1969
    Isn't a weird white film/shadow on the upper lips ?
  • mCasualmCasual Posts: 4,607
    August 2014 edited August 2014
    it's hypergloss it will be back in fashion someday
    but the thing i wanted to show was the blonde-shadows and blonde hair tips
    compared to the old ones which were slightly black/gray/discolored
    recipe in Paintshop
    loaded the color map
    color/negative
    select all
    copy
    load black and white opacity map
    paste inverted color-map as a layer on top of the opacity map
    select the "color" layer overlay type
    merge the layers
    save as the new opacity map
    fig 3 when there's no opacity image map, AND the opacity strength is not 100%
    the inverse of the diffuse color tint ( saturation + hue ) supplies
    the transparency tint
    and the opacity strength supplies the transparency strength
    1000 x 1000 - 394K
    1920 x 1920 - 616K
    1920 x 1080 - 339K
    Post edited by mCasual on August 2014
    That I saw and it's interesting :)
    case where there is no opacity map but opacity strength is not 100%
    and there's a diffuse map
    fig 2 : thin veils
    fig 3 - for now if there is an opacity map, the diffuse color is not influencing the projected color shadows, but you could introduce it through the opacity map using a paint program
    if there's no opacity map and there's an opacity strength less than 100%, the diffuse color and/or color-map is the master of the projected shadows
    ( that made me think of "Les Mystérons" ... pretty scary stuff :) )
    fig 4 typical networks
    fig 5 when there's no opacity map and opacity strength is 100%
    1080 x 328 - 157K
    1920 x 1080 - 557K
    1280 x 720 - 151K
    1280 x 720 - 122K
    1280 x 1280 - 516K
    equivalent of Daz Studio/OpenGL's ambient channel, non-emissive
    well it's emissive for the camera rays and glossy/mirror rays and it's diffuse for the others
    ..oops i will re-design this
    1436 x 664 - 333K
    1264 x 624 - 195K
  • nakamuram002nakamuram002 Posts: 818
    Will there be an option to use the always use Mix Shader instead of the Add Shader for combining all nodes?
    yes in a recent version i accidentally removed the feature,
    but in teleblender there will be a checkbox to globally
    use a mix shader or an add shader to combine diffuse and specular
    the diffuse-to-glossy ratio for that mixer will also be set globally by teleblender
    the daz default materials also have a ''multiply specular through opacity'' switch, maybe this could be
    usedas a per-material mix/add selector
    ... i will see if it affects the .mtl file adversely
    ambient / emissive
    when in classic TeleBlender2 mode
    an emissive node is added to a material only if the material in DS has a token image map
    applied to the material's Ambient Color channel
    if there is one, the diffuse node is replaced by an emissive node
    so the ambient color/map is whatever the diffuse color/map was
    the specific ambient color map and ambient color is unceremoniously ignored
    the emission node intensity is set to 100
    it worked this way to allow the creation of object-lights / area-lights with an intensity of up to 100
    the requirement for the presence of a token ambient image map was there to, in a way,
    to reserve the ambient setting for object-lights and prevent other materials from becoming such strong lights
    when in Teleblender3 mode
    the ambient color map, the ambient color and the ambient strength will all be taken into account
    the diffuse node stays where it was
    the emissive node output is added to the diffuse-and-gloss output
    because when the ambient strength is weak, you still want to see the substantial diffuse shading
    an ambient strength of 100% in Daz Studio will result in an emissive node with a strength of 1 in Blender
    if you set the "limits off" in Daz Studio, you will be able to get Blender Emission strengths of 10, 100, 1000
    by using DS ambient strengths of 1000% 10000% and 100000%
    Fig 2 - no ambient map, no diffuse map, but the ambient color is blue with a strength of 40% ( 0.4 )
    the plane is red - so non-shadowed areas are red + blue and shadowd areas are blue
    Fig 3 - in Daz Studio i use this for Amy's skin because it looks good even in Hardware/Preview renders
    Fig 4 - so apparently i need to inject the skin color in the ambient/emissive color
    Fig 5 .... as you can see ... note that the beauty of ambient light is that skin in shadowy areas isnt grayish, it always keeps a minimum of color, it's vaguely also like subsurface , and if not exaggerated it gives the figure a 'glow'
    1280 x 720 - 340K
    1056 x 434 - 229K
    1718 x 608 - 303K
    480 x 480 - 14K
    1416 x 660 - 397K
    the corneas of Aiko 3 have (optionally) a fake-reflections transparency map
    here i discovered the ambient light must be added before the transparency nodes
    else the corneas would be totally while
    ( yes i know too much ambient light in the skin )
    Fig 2 - the gloss mix-or-add option set to mix
    1920 x 1080 - 568K
    720 x 720 - 96K
    Nice !!
    Will you do a specific to import AoA ambient lightning ? And will the script recognized his others lights ?
    sioc said:
    Nice !!
    i was not aware of the existence of AoA's ambient lights
    in Blender-cycles, there's Ambient occlusion but i only tried it once
    mcjTeleblender is designed to look at the channels of the Daz Studio Default shader
    it doesnt inspect Shader properties
    though someday it may! do a search by label or by name of ambient occlusion settings
    and replicate them in Blender
    for now in fact, it's better if all objects in a scene use the daz default shader
    because mcjTeleBlender expects to find the standard material channels
    ambient/opacity/diffuse
    Fig 1 tests 0 to 7 of 32
    Fig 2 tests 8 to 15 of 32
    2000 x 1250 - 823K
    2000 x 1250 - 831K
  • KW001KW001 Posts: 14
    This is looking great so far. Can't wait to try it out.
    I have tried to sort it out from the shader trees, but the pictures are a little hard to read, so: does this handle DS's displacement maps at all?
    (also do you have a tip jar or a store page or something to be compensated for all this work?) :P
    I got an idea: Daz Gift cards !
    He'll have some once released but not before else he'll play with the new things he'll buy with and don't work on the script :-P ;)
    I am so impatient to have it...
    Thanks to the waiting I can watch/read some tuto about Blender.
    PS: I see daily the amount of work you do for us, it's just amazing. Thanks again
    Post edited by sioc on August 2014
    Daz Studio/3Delight do the displacements in the Render engine
    Blender can do it only on "real" geometry, so you have to subdivide the surfaces
    "manually" then Blender can take an image map and move the vertices
    mote that long ago i wrote a script named mcjElevate which creates a morph from a displacement map, in Daz Studio 1, 2, 3, 4, 4.5
    https://sites.google.com/site/mcasualsdazscripts/mcjelevate ( there's a movie ! )
    Blender-Cycles does have bump and normal maps
    i think some Blender users did experiments with render-time real-time "parallax" displacements
    but maybe it's only for GLSL/OpenGL renders https://www.youtube.com/watch?v=_1uhy_vrUFo
    if you really want to, you could give me gift coupons through the Daz3D store and improve Amy's wardrobe :)
    here's a close-up of one of the 32 test trees, mostly to test opacity and ambient light
    most materials only have a diffuse map, a glossy node and a mix or add node
    with this material you could have hair with its opacity map diffuse map. glossiness and some ambient light to add glow
    a map for the ambient channel is rarely needed, you could set an ambient color, strength, and the diffuse map would supply the colors
    1738 x 618 - 442K
    once i'm sure those cases work, we're closer to the release ( yeah i said that a few weeks ago )
    Figure 2 us the daz studio 3delight render
    i guess i may tweak my design again ! will it ever end? :)
    well actually it's mostly the 8 panels in the lower left corner that have a discolored transparency map problem
    Fig 3 Cycles without the environment sphere and with a sharper sun
    Fig 4 - looks like it was important to inject the diffuse color in the opacity and ambient channels
    to get closer to the way the DS-Default shader does it
    Fig 5 - competition for the last mixing node was fierce and transparency had become disconnected
    960 x 540 - 319K
    963 x 1080 - 665K
    960 x 540 - 252K
    1920 x 1080 - 2M
    1920 x 1080 - 1M
    there seems to be a need for a square-root of the opacity strength extracted from the opacity color map, could be one of them "gamma" settings
    when compared to Daz Studio/3Delight
    1902 x 568 - 443K
    1920 x 1080 - 795K
    next weekend next weekend we'll ...try again :)
    960 x 540 - 121K
    1080 x 1080 - 171K
    1440 x 810 - 311K
    the final version of teleblender 2 will have the glossMix checkbox too
    there may also be a global setting for the glossMix ratio ( 50% by default )
    ( fig 2 coming soon, mcjA3TippyToes, scarpin props for Aiko3-base
    1280 x 1080 - 93K
    540 x 1080 - 88K
    800 x 800 - 82K
    1920 x 1080 - 758K
  • RoygeeRoygee Posts: 2,247
    Hi Casual :)
    Firstly, thank you so much for making this script available.
    Hopefully you can help me - when I first tried a few weeks ago, it worked fine, but I realized I'd have to do some studying up on cycles nodes to get the best effect. Did that and came back for another go; Blender opened, but with the splash screen and no figure. When I ran the script, I got a "Python failed" error.
    The .obj and materials exported perfectly, because I can import into both Carrara and Blender with the materials fine - although, of course, the materials are not correct for Cycles - simply white.
    I'm on Win 7 64 bit, using DS 4.6.4.52, Blender 2.71.
    Roygee said:
    Hi Casual :)
    could you post the complete error message and where it was displayed?
    also if your mcjBlendBot kit is older than Jul 12, 2014, there was an update for changes that happened in Blender 2.7 ( related to the "collect maps" option )
    when you upgraded to Blender 2.71, it's important to install the mcjBlendBot files in the new 2.71 folder .... like you did when you installed mcbBlendBot
    325 x 508 - 57K
    .... in other News
    for the xth time i expect to release TelebBlender 3 this weekend :)
    I made sure the daz scripts mcjTeleBlender2
    and mcjTeleBlender 3 working in "TB2 mode"
    will still work with older versions and mods of mcjBlendBot
    Fig. 1 some notes about the diffuse/specular mix/add nodes
    contrary to what is said here, if there's a specular image map, it doesn't plug directly into the glossy color input
    instead a Color-mixer node is added, the specular color is therefore not thrown away
    its important since the specular color may also be the carrying the "Glossy Factor"
    Fig 2 the rarely observed issue of faulty UV Tiling vertical offsets
    Fig 3 - Blender 2.63a compatibility test : yes ! ( backward compatibility is the purpose of the calls to trad() in mcjBlendBot )
    1280 x 960 - 217K
    1280 x 720 - 236K
    1920 x 1080 - 645K
    Thank you so much for your fast response - got it working brilliantly by installing the update and copying the files into Blender 2.71.
    It was by watching a video of your script which got me into trying this - in the video, the author mentioned that in the next video he would show how to animate the figure sent over from Studio in his next video, but never got around to making the second one.
    I imagine this would involve rigging in Blender - I take it your script does not involve sending over rigging?
    In any case, thanks again for everything - so good of you to share your expertise with us - looking forward to the next version :)
    when teleblender sends over animations, it exports the scene in a frozen state, as one obj file per animation frame
    then a batch file automates the import/render of those frozen scenes
    somewhere on the net there was/is someone working on importing rigged Poser figures in Blender,
    daz studio can export in FBX format, which does include rigging, but last time i checked, importing that in Blender was not working
    i did some tests with Carrara too but objects in the scene were all over the place
    in the distant future i may make "live"connections between Studio and Blender, don't know how practical this will be, it involves a lot of data transfer
    see here http://maddieman.wordpress.com/2012/04/23/exporting-daz-studio-4-figures-to-blender/
    it uses Collada
    that method does work actually !
    there's a few quirks but
    using Daz Studio 3 ii made everything invisible except Aiko3
    i zeroed the figure
    i exported in Collada, i used the "Generic Collada" preset
    i specified i didnt want morphs exported, but should probably at least export "bend" morphs
    i imported this in Blender 2.63
    i tried using mcjBlendBot to recover the materials but it didnt work
    one could export a frozen Aiko using mcjTeleblender
    and apply her materials to the collada-imported one
    160 x 120 - 325K
    1600 x 800 - 247K
    960 x 540 - 1011K
    Very interesting - thank you for the clarification :)
    teleblender 3 when there's an image map on the Glossiness channel applied in Daz Studio
    see the cloth and cream pot, the glossiness varies
    this image is relayed through python , not the obj / mtl, if there's no image, the per-material glossiness/roughness is applied
    Fig 3 : bump map strength is also transfered via python, not the obj
    here the strength in Daz Studio was 100% and the "max" was 0.1 which means 1 mm
    Once in Blender this became a 0.01 multiplier between the image map color and the output node's "displacement" input
    fig 4 - the render in Daz Studio looks quite different
    note that this is an AO map and should normally not be used as a height/bump map
    in fig 3 i had manually set the strength to 0.2 that's why it was so pronounced
    fig 5 - with the correct 0.01 multiplier
    fig 2 - 2 mm / 0.02
    arrrrGH ! the forum program changed the order of the images !!!
    960 x 1080 - 165K
    512 x 384 - 33K
    512 x 384 - 81K
    512 x 384 - 41K
    720 x 540 - 57K
    Fig 1 - bump map
    in Daz Studio strength 100% min = 0 max = 2
    in Blender image-map-color-multiplier = 2
    Fig 2 - transparencies without the need for image maps ( i wonder why i didnt make this before, the blender material did include the opacity strength
    transparencies with Darcie
    "From fearful trip, the victor ship, comes in with object won" -- Walt Whitman
    This is Aiko4 with the "anime" maps, the ambient strength of the skin was reduced from 15% to 7%
    the clothes had no ambient, so i added a 7% white ambient
    the eye-whites were using an image map, but looked a bit gray
    so i removed the image map, making them plain white
    it would probably look better with the image map, but a 7% white ambient added
    teeth are the other surfaces that would benefit from some ambient light
    the very glossy materials on the telescope are probably the cause of the 'fireflies'
    i didn't read much about Cycle's de-speckle options !
    Fig 3 - monkey see , making sure the light gets through transparencies
    note - Darcie wears http://www.daz3d.com/casual-outfit-for-v4-a4-g4
    see the shoulder straps? i there's a finely detailed bump map on them, looks great
    Fig 4, 5 - normal maps
    960 x 240 - 44K
    960 x 960 - 216K
    960 x 960 - 166K
    960 x 960 - 202K
    960 x 540 - 88K
    starting with teleblender 3, when a MIX node is used to combine the diffuse and the glossy
    Daz Studio's specular strength value will be transmitted to Blender ( through the python script )
    and will be applied to the MIX node's diffuse/glossy ratio slider
    1646 x 940 - 502K
  • SzarkSzark Posts: 10,634
    Nice I was about to mention that a MixRGB is better than an Add Shader node when mixing Diffuse and Glossy.. Been a while since I used it but here is my latest piece using your script http://www.daz3d.com/forums/discussion/19223/P195/#662870 thank you for a very cool tool.
    Also I am not sure if it has been mentioned or you know but you don't need the Texture Coordinate and Mapping nodes as Blender reads UV's as Standard.
    Post edited by Szark on August 2014
    welcome
    the choice of Mix-Shader vs Add-Shader to combine the diffuse and specular will remain
    in part in case people want to get the exact same renders as when they rendered a given scene in the past
    but also because there's probably materials that do need the Add Shader, maybe like varnished materials or something
    i only recently noticed the coordinates node wasn't needed, but on the other hand, it probably doesn't slow down render to leave it there, and it can be useful when the uv map is unusable, so you can quickly switch to the other generated/camera/object mappings
    ( it's ok to post renders in this thread too ! )
    oh interesting render !
    i actually saw this early stages of that render last week i forget where though!
    someday i'll address the issue of the other shader nodes like velvet, anisotropic, subsuface etc
    though when someone uses those they usually are tweaking the node trees "manually"
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
