Skin Builder 8 Merchant Resource for Genesis 8 Female (Commercial)
1192022242529
  • SquishySquishy Posts: 719
    Thanks a lot for the update, will give it a try :)
    Used most features, multiple undo/redo, came out OK!
    728 x 1200 - 294K
  • Zev0Zev0 Posts: 7,123
    Thanks for confirmingyes
  • SpookieLilOneSpookieLilOne Posts: 192
    edited March 2021
    So can this not be used at all for 8.1 even if we convert it ourselves?
    Post edited by SpookieLilOne on
    edited March 2021
    It works fine on 8.1, every render I've been showing is on 8.1. The only difference that matters in any way is 8.1 supports an alternate UV map but the geometry is the same, and Skin Builder automatically sets its materials to use the original UV map.
    e: to make it really clear, you don't have to do anything at all to make your Skin Builder materials work the same between 8.0 and 8.1, they work on both with no manual changes required.
    e: small correction, the lash is also different but you can easily use the original G8.0 lash
    Post edited by Squishy on
    edited March 2021
    I mean, I know exactly where to look and I can't really see a difference. Can you tell which is 8.0. and which is 8.1?
    (that's a trick question because they're both using the same UV map and textures, so they're really exactly the same even though they have different figure IDs)
    714 x 830 - 155K
    913 x 573 - 185K
    878 x 700 - 188K
    You can convert it yourself if you wish.
    What I should have asked is can it be used a Merchant Resource for 8.1 if we convert it ourselves.
    Yes. But the script won't do it for you. The rules are stated in the MR Agreement.
  • bf2011bf2011 Posts: 155
    It turns out Skin Builder 8 does not recognase Gen 8.1 Female. Can we get an upgrade/update? Or is it going to be SB 8.1 that we have to pay for again?
    edited March 2021
    Not updating it for 8.1. Build skins on Genesis 8 Female and apply it to 8.1. The different UV on 8.1 causes all sorts of issues building skin natively on 8.1. You can still use normal Genesis 8 Female UV (which Skin Builder is designed for) on 8.1.
    Post edited by Zev0 on
    yes, it works perfectly fine on the 8.1 mesh using the 8.0 legacy UV, such a tremendous value for the price!
  • nusaw316nusaw316 Posts: 0
    Hello, I uploaded the genesis 8 female base and the skin builder 8 gives an error; genesis 8 female has not been selected
    What's going on?
    I have Daz 4.15
    Make sure genesis 8 female is selected not genesis 8.1 before attempting to run the script.
  • I know this is a silly question, but the documentation for 1.0 shows a Save Skin and Material Presets tab. I don't see how to get to it in V 1.2. Can you point me to it? Thanks
    edited April 2021
    Version 1.3 is available if you re-download. I don't really update guides or promo material just to reflect latest update number change.
  • davesodaveso Posts: 7,894
    What are the changes? I just installed it. Thanks
    edited April 2021
    Fixed issues from version 1.1 and 1.2 which broke overlay options when saving material presets.
    1576 x 879 - 100K
  • peter_4031821peter_4031821 Posts: 2
    edited April 2021
    Using Skin Builder 8 on Genesis 8 models in Daz Studio 4.15 Pro.  Then exporting the model via Daz to 3DS Max Bridge and getting an error in 3DS Max when attempting "Auto Import"
    Have tried this using 3Delight shaders in Genesis 8 with corresponding 3Delight option in SB8, and also using iRay shaders in Genesis 8 with corresponding iRay option in SB8, gives the same error.
    Please advise on how to achieve proper settings to work with Daz to 3DS Max Bridge.  Or is there another necessary step (e.g. save materials to a file etc.)
    Thanks!
    Pete
    409 x 159 - 35K
    Post edited by peter_4031821 on
  • emotionaldreams2emotionaldreams2 Posts: 141
    edited April 2021
    im still getting this seams. only happens with PALE skin ccreations
    300 x 350 - 104K
    300 x 350 - 109K
    300 x 350 - 118K
    Post edited by emotionaldreams2 on
    Looks like your figure is at base resolution. Does that still appear when resolution is set to high?
    yes. still shwoing on high resolution. no idea why it only hapens with white skin
    edited April 2021
    tried to use that trick someone mention before (change transmitted color .99 .99 .99 mode to chromatic) but still seams on pale texstures
    Ok I will have a look when I get home.
    ok thanks :)
    I applied a pale skin. I'm not gettings seams. Can you tell me the process you used so I can emulate?
    1771 x 1283 - 119K
    edited April 2021
    i simply loaded g8. loaded skin builder 8. chose pale skin option. left everything at default. and clicked build skin button. and got seams. tried tinkering wiht the sliders. but still got seams. dark skin and light skin works fine. im only have the white skin semas problem. im goi ng to try repvious ver of Sb8 to see  if it happens
    edited April 2021
    I did the same and no seams. Version 1.3 is the most stable version. I wouldn't use version 1.1 or 1.2.
    edited April 2021
    tried previous ver. . still seams with pale skin. guess ill stick with ligh/dark skin for the time being. til i figured it out. this the first time i treid pale skin(with SB8 anyway). perhaps more pratice needed. probably soemthing on my end. not SB8 fault
  • there is a error appered on my PC like "no eyelash are loaded!" when using skin builder 8.
    what this error means? and what can i do?
    is there solution?
