Buy Something That Doesn't Work in Carrara? Post your Questions and Workarounds here. (please)
1323335373852
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,136
    edited October 2020
    Say, do you think this FBX-only thingy would import properly into Carrara? I've never used FBX for anything yet.
    https://www.daz3d.com/fbx--studded-jeans-outfit
    I myself would use the transfer utility on it in DAZ studio and save a support asset
    dunno otherwise how well it would import
    at that price I grabbed it so can test
  • DartanbeckDartanbeck Posts: 21,959
    Convinced me. I'm buying it too. Not for myself, mind you... for Rosie! :)
    edited October 2020
    after fitting to G8F refit down 'till you get to Genesis 2 and save that one enlightened
    I don't need to to conform to anyone. I just need to get it into Carrara is all ;)
    But I might do as you suggest anyways, just to have it! Thanks so much, Wendy!
    So... you tried it on? Is it comfy?
    you need to manually download it, DIM fails and no Carrara cannot load it but anything that loads FBX and exports as obj should
    I will try DAZ studio itself soon otherwise are lots of free options besides Blender
    I'm just going to do as you suggested above. Then I'll just remove the rig in Carrara. Thank you So Much for the Amazing customer support, Wendy! You ROCK!!!
    edited October 2020
    yes it imports into DAZ studio
    need to hide bones under visability
    on my old PC in D|S4.7 and I haven't got all my clones there
    1300 x 1000 - 266K
    1300 x 1000 - 112K
    Yep. I got that far, but my conversion down to Genesis failed. I'll get it though! :)
    edited October 2020
    I will try in a few hours on my Win10 with my clones
    Catherine made some free ones you can grab
    I find converting to prop after dialing up the lower figure clone shape then using TU again actually better than autofit
    you get triax that way too
    I do use TU, but you lost me on the rest of that sentence. Like, how would I convert it to a prop (in DS), and then dial up lower figure clone shape? I'm definitely missing a lot of this.
    in parameters show hidden checked clone shapes
    under tab edit/rigging/convert to prop
    Wow. Thanks!
  • UnifiedBrainUnifiedBrain Posts: 3,588
    oh btw not tried it with later DAZ studio so hopefully still works
    they broke it a few times back in the day they had Carrara 8.5  in active development
    otherwise use DAZcollada
    if unanimated of course an obj export will do
    Thanks, Wendy!
    I've had this in my wishlist for a while as well, not knowing if it would work in Carrara.  Too busy to try it at the moment, but thanks for the advice again, Wendy!
  • I'm getting the big October windows update tonight.  Has anyone had any issues with it so far?
  • if it was the 2004 one it made my Computer laggy but disabling indexing on all my drives has helped enormously
  • Thanks.  I think it is called 20H2.
    meh not another oneangry
  • I apparently don't have 2004 yet, which is strange because I have my computer set to automatic updates, as per instructions from my computer tech.
    So, I'm currently updating to 2004, as an interim before even thinking about 20H2.
    edited November 2020
    that took me 15 hours to download and install
    You will have to enter all your serials again too
  • Well, it took my computer about 20 minutes.  And I haven't found any products yet that require a serial number reset.  All are working fine, including Carrara.
    Maybe I got lucky. :)
    it reinstalled Windows for me
    it said it had to as my version was out of date
    Yes, windows was trying to force me to install as well.  But I am not out of the woods yet.  It is possible that I STILL haven't installed the whole 2004 update, as it apparently has more components that did not download.
    482 x 584 - 52K
    Post edited by UnifiedBrain on
  • StezzaStezza Posts: 8,758
    I've had no problems but then again I keep my system up to date cool
    446 x 181 - 18K
    Post edited by Stezza on
    well I bought mine last year assuming it was
    and had updates enabled
    that 2004 still popped up a month ago and told me my operating system was out of date
    Same here. My Ryzen just fashes through those updates - done before I get up to go get a cup of coffee, so I just stay seated.
    I am so sorry to hear this. :(
    I also wish that I could make it better for you heart
  • DiomedeDiomede Posts: 15,391
    edited December 2020
    Dog 8 - remember to convert to blended weight.
    The figure loads in Carrara and has a convenient shading domain of 'coat' as a base for Carrara hair.  However, it needs to be converted to blended weight else the model 'skinning' will not follow the skeleton.  Does work once converted to from triax to blended weight in Studio and 'saved as'.
    1532 x 971 - 232K
    1577 x 980 - 305K
    Post edited by Diomede on
    That's great to know!
    edited January 2021
    anyone tried the streets of steampunk?  https://www.daz3d.com/the-streets-of-steampunk
    any problems like gatwyck or ravenskull had?
    seeing it on steep sale.  awfully tempted.
    its a stonemason set so prolly has uwrap gimmicks.
    i might get this instead  https://www.daz3d.com/mediterranean-seashore
    looks nice and warm
    Post edited by Mistara on
    edited January 2021
    looks nice and warm
    the streetworkers are Carrara (rest Twinmotion) a lot of alpha map chasing up and did use Sparrowhawk's UV unwrap but I do on most duf files
    edited January 2021
    thanks.  i guess i'm being seduced by the sale price.  showing like 11 bux
    cant help but notice none of the doors open in the vid
