• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1…43444546474849»
  • Robert FreiseRobert Freise Posts: 4,703
    October 2019
    surprisesurprise
  • Silver DolphinSilver Dolphin Posts: 1,652
    October 2019
    Wow, that is really mesmerizing MCasual !!! That butt is really wiggling. hahahaha
  • HibernatusHibernatus Posts: 19
    October 2019
    mCasual said:
    i dont know if it helps or not to install them using Blender
    It doesn't.
  • SadRobotSadRobot Posts: 116
    October 2019
    Does this work on Mac? It doesn't seem to run for me.
  • mCasualmCasual Posts: 4,607
    October 2019
    mcjteleblender 3 worked on macs up to blender 2.79 and mcjteleblenderfbx is for blender 2.8 note that in both cases you have to install the mcjblendbot kit of blender python script in blender's addons folder. I didnt have a mac for a long time but i think i tested mcjteleblender3 on it and mac users did use it too.
  • wolf359wolf359 Posts: 3,955
    November 2019
    Is there an update for this My blender add on says " need to upgrade to 2.8" Thus does not work.
    November 2019
    for older cersions of blender it's https://sites.google.com/site/mcasualsdazscripts4/mcjteleblender3 but it tranfers "frozen" scenes as .ovj files, not rigged FBX
    November 2019
    I am using blender 2.8 I need the FBX version ????
    November 2019 edited November 2019
    for blender 2.8 you can use t my beta/unfinished teleblender4 which exports scenes as frozen .obj files https://sites.google.com/site/mcasualsdazscripts9/mcjteleblender4temprelease or teleblenderFbx which exports scenes as animated and rigged figures. note that both versions cant coexist in the blender 2.8 addons folder
    Post edited by mCasual on November 2019
  • s-s_37fc177103s-s_37fc177103 Posts: 3
    November 2019
    mCasual, please, add to the script export for octane renderer.
  • KoolapzKoolapz Posts: 3
    November 2019
    Hi, I've been playing with mcjTeleBlenderFBX and noticed that some shaders are wrongly connected :
    I made some search on the topic but didn't found anything like this, is this something known ?
    January 2020
    January 10th 2020 - i disabled the EdgeSplit modifier on props because i had a hair prop with morphs that prevented the blender-side script to complete ... so the figure was all messed up
    only the Daz script was modified not the blendbot kit of blender script
    https://sites.google.com/site/mcasualsdazscripts9/mcjteleblenderfbx
    https://www.tiktok.com/@mcasualjacques/video/6780470687552294149
    January 2020
    You know can use octane for daz free tier. You don't need to export anything. I have used it. Load and pose scene.Then after installing Octaine plugin login and download shaders from Otoy from within plugin. Daz render tab>Otaine render main or f12. Next scroll down and click Live DB update now! Warning this will take time!!!  Bring up click open viewport texture under default setting should have converted. You have to remember that Iray textures are not designed for Otoy Iray so you going to get some issues. But you can't argue with free! One other issue on free tier just one card is used to render but if you run out of video memory Octaine will use your system memory for render so you are golden for large scenes that daz iray can not handle. Here are some examples of same figure render in Daz Iray and Otoy daz plugin. Good luck
    720 x 480 - 40K
    1266 x 882 - 72K
  • KitsumoKitsumo Posts: 1,222
    January 2020 edited January 2020
    Anybody else getting this? When I convert a figure to Blender with textures it comes out distorted. If I erase all the textures it converts ok. Even if I clear the model but still have textures on the clothing, it distorts. Scenery and props seem to be fine.
    Edit:
    using
    DS 4.12.0.86
    mcjBlendBotForBlender280_2019_10_06.zip Oct 6, 2019, 4:54 PM
    & mcjTeleBlenderFBX.zip Jan 10, 2020, 8:28 PM
    733 x 457 - 34K
    733 x 457 - 30K
    Post edited by Kitsumo on January 2020
    i updated the script recently  because hard-edging props (ex:cubes) seemed to make the blender-import process fail, so the processes that fix the figure didnt get done
    in the export folder where the FBX file resides, you will see a .bat file
    if you close blender, then run that .bat file (double-left-click for windows) then blender will open and import the fbx and fix materials and fix animation/poses
    the advantage here is that you can make Blender show the "Console"
    you get a listing of all operations that went on while importing/fixing the fbx scene
    so you can see if, for example, a prop or a material caused the process to fail
    Edit:
    using
    DS 4.12.0.86
    570 x 364 - 85K
    Post edited by mCasual on January 2020
    mCasual, thanks for the response. Sorry, I was busy for a few days. I deleted all the scripts and re-installed. I'm still getting the same result.
    Here's my console log:
    Traceback (most recent call last):  File "<string>", line 1, in <module>  File "F:/Users/Homer Simpson/Documents/MCJteleblend/scene.py", line 15, in <module>    import scene_fixFbxMats  File "F:\Users\Homer Simpson\Documents\MCJteleblend\scene_fixFbxMats.py", line 52, in <module>    setTiling('Genesis3Female', 'Arms', 1, 0, 1, 0 )  File "C:\Program Files\Blender Foundation\Blender 2.81\2.81\scripts\addons\mcjBlendBot.py", line 189, in setTiling    mcjMakeCyclesNodes.setTexTiling( mat, horizontalTiles, horizontalOffset, verticalTiles, 1 - verticalOffset )  File "C:\Program Files\Blender Foundation\Blender 2.81\2.81\scripts\addons\mcjMakeCyclesNodes.py", line 73, in setTexTiling    coord.scale.x = horizontalTilesAttributeError: 'ShaderNodeMapping' object has no attribute 'scale'
    The only error I see is the last line about scale, so I guess that's where my problem is.
    Also, I just tried it in a virtual machine, fresh Daz 4.12 install, fresh Blender 2.81 and the MCJTeleblend from here:https://sites.google.com/site/mcasualsdazscripts9/mcjteleblenderfbx. The result I got is even worse.sad I don't know if I'm installing it wrong or if it's something in my settings. Maybe I'll try again this weekend with different versions of Blender.
    1377 x 842 - 143K
    this looks like a problem due to changes from Blender <= 2.80 and Blender 2.81
    they possibly changed the name of the "Scale" input of the shader tiling node
    for now i cant get Blender 2.81, because Blender.org site is frozen
    but later today ( after the dentist arrrrgh ) i will check again
    since the tiling for your figure would have no effect anyway
    if you really want to see what it will look like
    you could open the file with a name like doma_fixFbxMats.py ( in the same folder as the .fbx ) with a text editor
    and replace all the lines that start with
    setTiling('Genesis8Female', 'Ears', 1, 0, 1, 0 )
    with
    #setTiling('Genesis8Female', 'Ears', 1, 0, 1, 0 )
    this has the effect of not performing the setTiling actions
    then you start blender and the fbx import by running the batch file with aname like doma.bat ( in the same folder as the .fbx )
    or you could target Blender 2.80 instead of 2.81
    Traceback (most recent call last):  File "&lt;string&gt;", line 1, in &lt;module&gt;  File "F:/Users/Homer Simpson/Documents/MCJteleblend/scene.py", line 15, in &lt;module&gt;    import scene_fixFbxMats  File "F:\Users\Homer Simpson\Documents\MCJteleblend\scene_fixFbxMats.py", line 52, in &lt;module&gt;    setTiling('Genesis3Female', 'Arms', 1, 0, 1, 0 )  File "C:\Program Files\Blender Foundation\Blender 2.81\2.81\scripts\addons\mcjBlendBot.py", line 189, in setTiling    mcjMakeCyclesNodes.setTexTiling( mat, horizontalTiles, horizontalOffset, verticalTiles, 1 - verticalOffset )  File "C:\Program Files\Blender Foundation\Blender 2.81\2.81\scripts\addons\mcjMakeCyclesNodes.py", line 73, in setTexTiling    coord.scale.x = horizontalTilesAttributeError: 'ShaderNodeMapping' object has no attribute 'scale'
    1156 x 544 - 218K
    Yes, that fixed it. I'll still download 2.8 whenever the site comes back up. Thanks!
    Edit: Nope, I spoke too soon. 2.81 still gives me problems, but 2.80 is working. Thanks again.
    February 2020 edited February 2020
    February 2nd 2020 - Blender made changes in version 2.81 - so i fixed an issue with UV mapping,
    MCJBLENDBOTFORBLENDER281_2020_02_02 is my new kit of Blender scripts,
    it will detect if you use 2.80 or 2.81, so you can use both Blender versions.
    Note that in one of my test scenes i had a Hair Figure parented but not fitted to Aiko3's head and this prevented  the FBX import to complete.
    So it would be better to convert that hair figure into a prop ( export/import .obj in Daz Studio then delete the hair figure )
    it's a good idea to install 2.80 for example in c:\blender280   and install 2.81 in the ususal location c:\program files\blender
    this way if something doesnt work with 2.81 you can use 2.80 instead
    800 x 800 - 96K
    Post edited by mCasual on February 2020
  • RoygeeRoygee Posts: 2,247
    April 2020
    Good day all
    I've not used Studio for a while, so please bear with me.  I guess to start the export, I need to call up the exporter by double-clicking on the mcjTeleBlenderFBX.dsa icon?  Second question - where/how in the Studio interface do I find it?
    Studio was installed by install manager and I don't have a C:\Program files\Daz\Studio\Content folder, as per the instructions.  Ended up installing where the other, older scripts were - C:\users\public\public documents\myDaz3D Library\scripts\scripts\mcasual\scripts\
    This surely can't be correct?
    Another query - I use Blender 2.82 - when installing the plugin, got a warning "upgrade to 2.8x required" - how significant is this?  Won't know if it works for me until I can find the icon to launch the export!
    Cheers:)
    April 2020
    normally the mcjTeleBlenderFBX.dsa file should be in
    C:\users\public\public documents\myDaz3D Library\scripts\mcasual
    this way it would appear in your daz studio content tab under Daz Format/myDaz3D Library/mcasual/
    but you can also run the script by doing ( from Daz Studio's Top Menu bar ) a File / Merge / .... browse to mcjTeleBlenderFBX.dsa
    April 2020
    i dont recall adding code to the script that detects the version of Blender  and asks for updates
    unless it's a version modified by someone else
    Roygee said:
    Good day all
    Cheers:)
    April 2020 edited April 2020
    Roygee said:
    Good day all
    Cheers:)
    800 x 800 - 51K
    Post edited by mCasual on April 2020
    April 2020
    Thanks for the explnation - and all your great work on the plugin.  It does seem that something has changed in Blender 2.82 - the FBX exporter doesn't seem to work.
    I guess I'll have to try to get hold of a copy of 2.8
    April 2020
    I'll get Blender 2.82 and see what's up
  • madsergiomadsergio Posts: 8
    July 2020
    I checked how mcjTeleBlender4temprelease (June 25th 2020 version) works in latest Blender 2.83.1 - everything is fine, there are no errors. Thanks!
  • DigiDotzDigiDotz Posts: 515
    July 2020 edited July 2020
    Yes! pretty cool yes  I'm having some sort of issue with rendering. The figure, hair and clothes show as using 11gb during gpu render befor crashing.  CPU works of course. I'll do some more tests as it's probably something I've changed in Blender + updating gpu driver today.
    *Blender 2.83 Cycles render  mcjTeleBlender4temprelease
    732 x 770 - 141K
    Post edited by DigiDotz on July 2020
    July 2020
    Oh Scrub that.. Restarted blender and all's good!! laugh  stuff happens
  • Eustace ScrubbEustace Scrubb Posts: 2,742
    July 2020
    Glad to see the Admins ported this thread over to the Blender forum.
  • brainmuffinbrainmuffin Posts: 1,331
    July 2020
    Anyone get this to work on a Mac? The Exporter isn't case sensitive, so it see things named the same that aren't. I also can't get it to write  file Blender can open.
«1…43444546474849»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
