• Shop
    • NFT
    • Technology
    • Community
      • Gallery
      • Forums
      • Blog
    • Help
    • Download Studio
  • Shop
  • NFT
  • Technology
  • Community
  • Help
  • Download Studio
  • Our Community
  • Gallery
  • Forums
  • Blog
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1…43444546474849»
  • Silver DolphinSilver Dolphin Posts: 1,403
    August 2019
    That is great. Thank you
  • mCasualmCasual Posts: 4,308
    August 2019
    https://www.youtube.com/watch?v=9WvIIuQpvU8
    sneak preview mcjTeleBlender 4 for Blender 2.8 - FBX pipeline
    This scene was exported
    from Daz Studio using
    the FBX file format.
    Unfortunately the animation
    transfer is horrible, so ...
    ... i wrote a Daz Script
    which exports the animation
    as a blender python script.
    Then in Blender i imported
    the FBX scene-file.
    Then i applied the blender script
    which fixed the animation.
    This will be part of
    which used to transfer static
    scenes through the .obj/.mtl format
    The most important feature of
    mcjTeleBlender ( since 2011 )
    is that it builds the node-tree-materials.
    It also re-creates lights and cameras,
    something that the obj/mtl format doesn't
    If all goes well,
    will be ready before August ends
    Beta Releases: https://sites.google.com/…/mcasu…/mcjteleblender4temprelease
    August 2019 edited August 2019
    in local news
    the standalone daz script that exports figure animations as blender python scripts is almost ready. It is used to heal/replace the animations transferred through FBX export
    and i will also add an option to mcjTeleBlender4 Beta, so it can produce a blender python script to fix the materials transferred through FBX export
    interesting to note that eevee velvet materals do look velvety
    though this is a blender cycles render
    618 x 1000 - 1M
    Post edited by mCasual on August 2019
  • MiloMilo Posts: 509
    August 2019
    Looking awsome!  What your doing is fantastic, thank you!
    I saw the 16th release on the page as the latest?
    August 2019
    The daz script was updated on the 18th if your scene has shader materials with normal maps, this update is important the next release should be a few hours from now and include fbx related functions
    August 2019
    https://www.youtube.com/watch?v=0CvSKsqo1rw&feature=youtu.be
    August 2019
    Thank you this will be a boon to all animators that pull their hair out using daz studio slow renders.
    remember it's still in Beta and a stable release may have to wait til September
    https://sites.google.com/site/mcasualsdazscripts9/mcjteleblender4temprelease
    https://sites.google.com/site/mcasualsdazscripts9/mcjexportfigureanimtoblender
    VIDEO -->
    transferring animations from daz studio to blender, using FBX and my scripts works quite well but it didn't pass the acid test of animated root-node rotations ... so i'll work on that. also i don't like the cameras and lights created by blender's FBX importer - so eventually my scripts will also export camera animations and lights
    VIDEO -->
    August 2019
    today or tomorrow we should have a new improved version of the animation export/import system Daz Studio--> Blender. In the meantime, avoid parenting figures to something else, because it messes the clothes. And avoid animating the root node of figures, animate the hip
    August 2019
    daz studio to blender via fbx, progress
    still a few odds and ends to fix
    for example, fbx creates blank normal maps and it sets materials as metallic
    that's an old-school Aiko3 figure so i have to see if Genesis 3 and 8 behave correctly with the new changes i made
    August 2019 edited September 2019
    It would be nice if everyone would use one standard in 3D but that means someone loses money and nothing can overcome human greed. Thanks for you hard work.
    Post edited by Silver Dolphin on September 2019
    August 2019
    in FBX news, i (re?)discovered that if the root node of a prop or figure (something with a shape) is rotated, the position of said node gets corrupted during its FBX-trip from Daz Studio to Blender .... most likely because the order in which the node is rotated and positioned is not the same in DS vs Blender . Case in point the position of the corner walls ... which i was able to correct by parenting them to a null node ... and doing other stuff ... Maybe the trick will be to parent everything in the scene to a null node ... or have scripts re-locate everything
    August 2019
    technical note : the trouble arises when the origin of the node differs from the position of the node
    so for the mcjFrenchWall prop
    when i do
    node = Scene.findNodeByLabel("mcjFrenchPaneledWall")
    print( node.getOrigin() )
    i get ( 0, 0, -65.04 )
    if i do
    node.setOrigin( DzVec3( 0, 0, 0 ) )
    the wall jumps back 65 cm, that's normal
    i reposition the wall
    now it's position is correctly transfered through FBX
    990 x 618 - 64K
    August 2019
    August 31st 12:34PM
    mcjTeleBlender 4 Beta
    ( FBX pose-animation issues )
    ( FBX material issues )
    and
    mcjExportFigureAnimToBlender
    i plan to release many other updates
    notably, one that fixes position ( location ) issues of rotated props
    so come back soon
    September 2019
    I don't know enought of underling mechanics of blender of daz studio to help, maybe in script forum.
    September 2019 edited September 2019
    No new version but but progress report concerning transfer of scenes via FBX progress ... the daz fbx exporter or the blender fbx importer messes the location of rotated props, and i was able to write code that writes scripts that fix this issue Though the hat prop and the hair prop when parented to the Aiko figure were mis-located so there's still work https://www.daz3d.com/forums/uploads/FileUpload/5b/550c426eeede350c918cb524af4de1.jpg
    800 x 800 - 165K
    Post edited by mCasual on September 2019
    ( Update soon but not right now )
    daz studio - FBX - Blender ... we'll cross that bridge when that bridge will be safe and there will be a snack-bar near the bridge with $3 hot-dogs, big hot-dogs
    this was an acid-test for rotated props
    now i have to see about Gabrielle's hair-prop and hat-prop positions which have a small offset problem
    oops looks like my latest code fixed the hat and hair offset --- it's relative to prop origins which are not 0,0,0
  • RAMWolffRAMWolff Posts: 9,647
    September 2019
    Looking good.  Mmmm, HOT DOGS!  LOL
    September 2019
    Daz Studio -- FBX -- Blender 2.8 -- NEWS
    September 2019
    Ooooh hotdogs and bar-b-que. hahaha Thanks for your hard work.
    and to make it a complete balanced and nutritious meal, ice cream
    welcome
    here's the current test scene, before it's long voyage from Daz Studio to Blender
    1080 x 1080 - 228K
    Post edited by Chohole on September 2019
    progress - i was able to determine that only rotated, root nodes, with non-zero origins need to have their location coordinates healed - Blender Cycles render of a Daz Studio scene - after materials fix and pose fix
    1080 x 1080 - 3M
    Blender eevee render of a Daz Studio scene
    next i'll see if i can let teleblender do the transfer from daz studio with just 1 button, i just have to learn how to make Blender import an FBX file via script
    maybe i'll have a teleblenderFBX and a teleBlender new-old-school that uses waveFront .obj
    1920 x 1080 - 2M
    September 2019
    Looking good. I have a new chinese motherboard for dual xeons and 128gb of ecc ram in the mail. I will hopefully use this new system to do evee animation from within blender. Thank you for your hard work and your great scripts.
    here we have a daz studio scene rendered in blender Eevee
    the steps were
    1 - 'manual' FBX export
    2 - 1 button-click = creation of a blender script to fix materials using a daz script
    3 - 1 button-click = creation of a blender script to fix poses and locations using a daz script
    4 - start blender
    5 - import FBX
    6 run mat fix script ( also replicates Daz cameras and lights )
    7 run pose fix script
    8 click Blender render button
    but in the next version of mcjTeleBlenderFBX, it will be
    1 - click button to do steps 1 to 7
    2 - click Blender render button
    1080 x 1080 - 2M
    some issues i have to resolve before posting a new version of mcjTeleBlender FBX for Daz Studio
    by the way, did you know you can follow all my works at deviant art and my gallery contains no nudity
    my name there is mcasual ( i dont post the link in case you know ...
    https://www.daz3d.com/forums/uploads/FileUpload/fa/7316f6efca52f29356f45aff3d237d.jpg
    1200 x 880 - 226K
    September 2019
    Went to devian art and commented there
    September 2019
    toe and finger-tip position Blender-FBX-Fix test when i transfer all the rotations from the figure's root node to the hip,
    i get perfect position the proof is, the big toe stays on the white trajectory and the index tip stays in place
    so today i'll do this mathematically speaking when i fix the animation in blender
    September 2019
    Looks great. Thank you very much.
«1…43444546474849»
    Daz 3D
    Daz Productions, Inc
    224 S 200 W, Salt Lake City, UT 84101
    HELP
    Tutorials
    Help Center
    Press
    Blog
    Contact Us
    Advanced Documentation
    JOIN DAZ
    Sell Your 3D Content
    Affiliate Program
    Licensing Agreement
    Open Source
    Privacy Policy
    Terms of Service
    DAZ STORE
    Platinum Club+
    Daz Shop
    Freebies
    Bridges
    HELP
    Tutorials
    Help Center
    Press
    Blog
    Contact Us
    JOIN DAZ
    Affiliate Program
    Licensing Agreement
    Open Source
    Privacy Policy
    Terms of Service
    DAZ STORE
    Platinum Club+
    Daz Shop
    Freebies
    Bridges
Daz 3D
© 2021 Daz Productions Inc. All Rights Reserved.
