Show Us Your Iray Renders. Part VII
11920222425100
  • tkdroberttkdrobert Posts: 3,618
    Robotech: Carrier Ops
    Robotech: Carrier Ops by tkdrobert
  • FSMCDesignsFSMCDesigns Posts: 12,854
    edited April 2019
    More testing with the new GPU. The new HW Buck with the Whitetail preset and the LAMH preset at 500K of fiber mesh hair.
    1393 x 878 - 1M
    1393 x 878 - 710K
    Post edited by FSMCDesigns on
  • ZilvergrafixZilvergrafix Posts: 1,385
    Unfinished comic, all rendered with a GT-730 2Gb
    960 x 540 - 113K
    960 x 540 - 159K
    960 x 540 - 155K
    Unfinished comic, all rendered with a GTX1060 6Gb
    1280 x 720 - 227K
    1280 x 720 - 197K
    1280 x 720 - 134K
    1280 x 720 - 78K
    1280 x 720 - 104K
    1280 x 720 - 263K
    1920 x 1080 - 181K
    1280 x 720 - 252K
    1280 x 720 - 166K
    1726 x 882 - 263K
    1726 x 882 - 499K
    1280 x 720 - 329K
    1280 x 720 - 171K
    Midori and the Antares, all rendered with a GTX1060 6Gb
    1644 x 875 - 277K
    1920 x 1080 - 181K
    1920 x 1080 - 256K
    Random works
    777 x 874 - 60K
    752 x 882 - 128K
    679 x 960 - 41K
    1194 x 906 - 169K
    1194 x 906 - 161K
    1194 x 906 - 170K
    1280 x 720 - 101K
    765 x 906 - 86K
    960 x 960 - 118K
    1020 x 489 - 38K
  • Lothar WeberLothar Weber Posts: 1,611
    edited April 2019
    Hi, my Name is Lothar and i'm in Daz since December 18. Still learning every day. So now trying to get gems to work with Caustics, no luck in this. Do you have any tips how i could get this work?
    Render took 56 min.
    Thanks for Tips and Comments.
    Visit my Gallery and comment if you like ;-)
    1280 x 1280 - 2M
    Post edited by Lothar Weber on
  • dyodyodyodyo Posts: 42
    Having a play with badger lighting :)
  • RafmerRafmer Posts: 564
    edited May 2019
    Hidden
    1080 x 1080 - 830K
    Post edited by Rafmer on
    Rafmer said:
    Hidden
    Not that well, I can see her legs and side, he must be blind with all the armour, LOL
    Great image though, very well done.
  • JamesJABJamesJAB Posts: 1,766
    New render using "Octiana for Genesis 8 Female" and "dForce Summer Romper for Genesis 8 Female(s)"
    (Yes the dForce draping was done with the octomaid lower half)
  • xmasrosexmasrose Posts: 1,409
    edited May 2019
    JamesJAB Great one! She looks so bored.
    Post edited by xmasrose on
  • L'AdairL'Adair Posts: 9,479
    Render took 56 min.
    This is a very lovely image, the play of light and shadow works really well. However, the areas where the light through the gems would create the caustics you're hoping for are in shadow.
    If you want to see the caustics of the earring on her right hitting her neck, for example, you would need to reposition the light so it's coming from her right side.
    Here's an image I created in 2015 that uses caustics. The main light is shining in through the window and hitting the glass vases. Notice the caustics on the back wall are inline with the light, as are the shadows. (The image below links to the larger image. View it full-size to see the full effect of the caustics from the vases.)
    My Vintage Doll, by L'Adair
    (This image is four years old. I've learned a lot since. then.)
  • MattymanxMattymanx Posts: 7,000
    Random works
    You have fine taste sir (but you forgot the front wing and hubs) There is a preload that will load the car with the hubs and front wing attached.
  • Oso3DOso3D Posts: 15,108
    Some people wondered about Octiana in male form. A lot of times you can play with geografts and parent them and... play around a bit.
    It still took a little of a heal brush to clean up the interface, but hey.
    Aguja environment, HFS head morph
    2000 x 1000 - 508K
    More playing with "Octiana for Genesis 8 Female"!
    This Image falls in with my "Sladen Stories" series.
    I reworked my character "Astrid Langford" from G3F up to G8F.  The face is not exact because the original version used Sunny7 as a base.  The body morphs transfered prefectly becasue no named character shapes were used.  (Though she is heavier in this render from a combination of age and her transformation :P)
    She is wearing "Aeon Soul's Helix Alpha Outfit".  I added dForce to it, and it drapes nicely over Astrid's new Octolegs.
    Story time:
    She was in the Rec Room enjoying her free time in her usual way... (eploring life in a veriety of other humanoid forms, both real and fantasy).  ***The "Rec Room" functions simmilar to Star Trek's Hollodeck except that it creates real cellular structures as needed, and can temporaraly change the users cellular structure as needed for the simulation.  When the program closes or you exit the room, it will undo any changes it made to the users.***  When Astrid asked the computer to close the program, everything faded to a blank room.  Well, aside from a message floating in the air in front of her face.
       DATA ERROR (CYCLIC REDUNDANCY CHECK)
            //USER/LANGFORD_A/DNA_CODE.RRD
    As Astrid raises up one of her Octolegs into view, she sings out in a whimsical tone "Oh no! How long will it take to fix it this time?!"
    Hmmm, I wonder if these will fit into my cloths.
    Clara is going to be sooooo mad when she sees me!
    edited May 2019
    L'Adair said:
    Dear L'Adair, thank you for your comment. Just tried another one. with a much bigger gem... ;-)
    Post it right now.
    1280 x 1280 - 352K
  • FishtalesFishtales Posts: 6,228
    There's been a leak.
    2019-04-22 07:45:32.873 Total Rendering Time: 11 hours 45 minutes 7.39 seconds
    75% done
    Click on image for full size.
  • XpiderManXpiderMan Posts: 426
    Just doing some tests, but I like the expression and pose, so "Soldier Girl" was rendered. :)
    Soldier Girl
    Floating island + aguja + Oso Ammonoids + a few other things
    1000 x 1300 - 183K
    Post it right now.
    That looks really good. Even the left earring has a bit of caustics.
    Rafmer said:
    Hidden
    Thank you! She is baiting him to make him feel confident cheeky
    Loving the new Sky Island.
    edited May 2019
    Ok, this is the last one with this bodysuit, I promise blush
    834 x 1080 - 596K
    May the 4th be with you.
    My "alternate" version of Star Wars based on the models I have. LOL!
    Absoutely fantastic work on the deers SFMCDesigns!
    a little macabre, Title: "Well i'm really not soooo bad..." ;-)
    Please visit my Gallery and comment if you like ;-)
    1280 x 1280 - 570K
    More fun with Octiana for Genesis 8 Female and dforce!
    I think she's looking slightly off-camera ...
