• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1…39404142434445…49»
  • iangiger007iangiger007 Posts: 3
    February 2018
    SilentLadyGTA said:
    iangiger007 said:
    thanks for this script.
    but i am getting white eye other then everything is textured.anyone know how to fix
    I got the same problem until soneone on Deviantart suggest not using iRay material. So I made a test with non iRay material and now I got quite normal eyes. I need to fix iris because they are too dark and there is no transparency.
    This is really a great script !!!!!!!!!!! Thanks to the creator !
    thaks for reply but i found other solution that work for me
    anyone having same problem  in cycles render engin setting feature set to suported fixed eye for me
  • mtl1mtl1 Posts: 1,508
    April 2018 edited April 2018
    I'm not getting the correct output for scene.blend for some reason... any thoughts? The script does output the OBJ but I can't do anything else other than that...
    How would I check if the module is installed properly?
    edit: Ah yes, checked the log and it says that it can't find the mcjblendbot module, hmm.
    edit2: strange, I had to install it manually from zip for some reason... at least it's installed now :)
    edit3: okay, now that i have it running... everything is magenta? what's going on? :( narrowed it down to textures not being collected.. hmm.
    Post edited by mtl1 on April 2018
  • bartoszcholewinskibartoszcholewinski Posts: 0
    May 2018
    @mCasual Will you add the export option for rendering using the radeon prorender?
  • waltage80waltage80 Posts: 6
    June 2018 edited June 2018
    it's real to convert DAZ PBR maps to cycles material using this script? or only by hand?
    because color map it's just past century
    animation transfer also not working(
    Post edited by waltage80 on June 2018
  • mCasualmCasual Posts: 4,607
    i know nothing ( except what i saw in google a moment ago ) about PBR maps
    i hope to update teleblender this summer
    notably for that real-time preview mode in Blender and the what's the word shader ... principled
    unrelated image
    note that the stl importer only works on stl files that use simple statements
    Post edited by mCasual on June 2018
  • marblemarble Posts: 7,500
    June 2018
    Have you seen the Diffeomorphic Blender importer by Thomas Larsson?
    http://diffeomorphic.blogspot.com/p/daz-importer-version-13.html
    I believe his code is open so you could, perhaps, cooperate in some areas if it would be beneficial?
  • autodolorautodolor Posts: 70
    July 2018
    1395/5000
    'I have a question about this ... I mean: I'm trying to make clothing animations, where there is no problem if we talk about render or 2D. I use the script "GeoSender" from Mr.Casual, but the indexing results as "X1.obj" and then, until the ninth, as "x9.obj". Then, we have the 2-digit decimals, up to frame 99. And, then, the "x100, x999.obj". They are not panned as "x00001" to "x01000". There is no logical sequence to load, in order of name, in "Morph Loader Pro". I do sequences of explanation from frame 0 to frame 9, with a prefix "Fliename.0000", followed by those of 2 decimals, with "Filename.000", etc.. Tedious and boring, but it does it. Well, but now that "object" is not animated if I do not load a script called "AnimMorph".
    My destination is not render, but webGL formats, such as glTF (ascii or binary glb ..).
    So as prop, the clothes are useless, because they remain in the first frame. I assign it to the "hip" parent of the person-model, genesisx, etc ... and yes, I can already make it a figure. But when exporting it to Blender, or Maya, like .fbx, I only get an animated file without respecting the different variations of the .obj, but something flat that moves, but far from the physical simulation offered by "dynamic clothing" in Daz.
    The same goes for Marvelous designer. Both export in alembic, mdd or ps2, or in Maya, as a cache.
    Can someone help me in this matter?
    July 2018 edited July 2018
    Just now i updated my free script to export an animated scene as a series of nunbered obj files
    https://sites.google.com/site/mcasualsdazscripts/mcjgeosender
    it will now zero-pad those numbers with 4 zeros which will let scripts/apps like
    https://sites.google.com/site/mcasualsdazscripts2/mcjobjstomorphingprop
    ... convert them into a morphing object which can then be animated just like the original
    autodolor said:
    1395/5000
    Post edited by mCasual on July 2018
    July 2018
    Thank you. I am going to try.! :D
    July 2018
    I sincerely appreciate your review of the script. I guess it was a couple of letters in the code, but it saves me a lot of time.
    On "mcjObjsToMorphingProp", it only loads the first .obj, and the morphs, but in the animation, there is only the first .obj. It is not a question of a different scale. I think Daz's "Morph Loader Pro" works better ...
    This only happens with dynamic clothing. In the same way, when you export, for example, genesis 3 with those clothes, to Fbx format, genesis is brutally deformed. I solve it with two fbx.
    My case is quite particular, since I transfer from Daz to Blender to generate the glTF file, and there is no way to correctly accept the geometry, apart from a file size of about 100/200 Mb, totally unusable on the web with Three. js, etc ...
    Anyway, thanks again. I'll tell you when I do the tests.
    July 2018
    the animation above this post was done with mcjObjsToMorphingProp
    you load frame000.obj
    then mcjObjsToMorphingProp imports the 105 other objs as morphs into the frame000 object
    then there's a button to animate the 105 morphs one after the other
    i simulated the cloth ising DynCreator at 100fps
    then i rendered the animation at 30fps
  • artphobeartphobe Posts: 97
    October 2018
    Hi mCausal - any chance we will see a Daz to Blender (with ProRender) scene export script?
    October 2018 edited October 2018
     i'll look into that very soon, since daz rolled out iRay, i dont render much in Blender-cycles,
    i dont know proRender yet but i'll look into that
    tonight i released a new old car prop ! maybe i'll use it for render tests, if by 'hardware agnostic' they mean non-radeon cards are supported \
    https://sites.google.com/site/mcasualsdazscripts9/mcjchevymasterdeluxe
    1920 x 2702 - 869K
    Post edited by Chohole on October 2018
    good news / less good news
    after using the cycles to prorender ( i didnt read the error messages )
    i was able to render on my nvidia card in GPU mode
    but the texture images didnt work
    but her hair has colors so it works
    but when i will modify teleblender i'll make it generate prorender node trees not cycles, or i'll use those
    1510 x 956 - 177K
  • nicsttnicstt Posts: 11,715
    October 2018
    .this would be great
    Coming Up Soon !
    support for Radeon proRender
    demonstration renders coming sooner than soon
    that's an iRay Render tho
    960 x 960 - 112K
  • Milo_471560Milo_471560 Posts: 511
    October 2018
    sweet I am starting my b LEARNING and since I Have a mac with a nice Radeon in there :)
    October 2018
    this would be cool, cause just might get a AMD radeon pro then
    progress report
    1920 x 1149 - 171K
    1920 x 1149 - 114K
    July 2019 edited July 2019
    The future is eeveedent mcjTeleBlender Blender2.80
    workin on mcjTeleBlender for Daz Studio For Blender 2.80 ( eevee ! ) that's a cycles render, contrary to previous versions, we'll let the Blender obj importer create the node-tree-materials, then a python script will adjust the materials for the extra parameters that are not included in .obj and .mtl files
    i tried to launch Blender from Daz Studio, but they broke a feature .... i think as a result of changing the UI to QT or something. because i get messages like "QPixmap: Must construct a QApplication before a QPaintDevice" which seems to be related to the absence of a console screen when Blender is remotely launched
    but but my mcjTeleBlender Daz Script produces batch files, which can be launched "manually", and it launches Blender, which runs an mcjTeleBlender Python script, which loads the .obj/.mtl files that were exported by mcjTeleBlender, then that scrip can adjust materials and add lights and environment spheres and cameras that are exactly like your Daz Studio cameras, same position and orientation
    1920 x 1040 - 167K
    Post edited by Chohole on July 2019
  • DigiDotzDigiDotz Posts: 515
    July 2019
    This is it!!   I am happy to buy you a coffee again ..I'd go as far as adding a nice vanilla slice but am still pretty broke laugh
    working on mcjTeleBlender for Daz Studio for Blender 2.80
    i have the foolish hope of posting a beta tonight
    here i'm working on distant Lights in Daz Studio which are SUN lights in Blender 2.80
    there's POINT lights and SPOT lights
    and AREA lights i think will become ... something emissive
    ( the horse is an old png iRay render ... to make the image fall in the Digital Art / 3-Dimensional Art / Characters / Female category)
    1920 x 1040 - 207K
  • Dean_2026310Dean_2026310 Posts: 22
    July 2019
    laugh.. Looking forward to trying this Casual..
  • Silver DolphinSilver Dolphin Posts: 1,638
    July 2019
    Oooh looks nice. Thanks
  • estaf1001estaf1001 Posts: 9
    July 2019
    Python script fail. look for console for now.
    [code]import mcjBlendBot
    mcjBlendBot.setGloss( 0.05, 0.15 )
    mcjBlendBot.setRenderEngine( "CYCLES" )
    mcjBlendBot.setImageSize( 1700, 2200 )
    mcjBlendBot.setCyclesSettings( "EXPERIMENTAL", "GPU", "OPENCL", 100 )
    mcjBlendBot.setSmooth( True )
    mcjBlendBot.setEdgeSplit( True )
    mcjBlendBot.addCamera( 1.45, -3.7, 1.9, 76, 0, 22, 59.429 )
    mcjBlendBot.setOutLocAndType( "/Volumes/home/tmp/DAZ3D/images", "TIFF" )
    mcjBlendBot.loadfix( "/Volumes/home/iron/Desktop/scene.obj", "CYCLESMATS", "/Volumes/home/tmp/DAZ3D/matLib.blend", True )[/code]
    Blender 2.79b
    Script stopped at mcjBlendBot.loadfix( "/Volumes/home/iron/Desktop/scene.obj", "CYCLESMATS", "/Volumes/home/tmp/DAZ3D/matLib.blend", True )
    802 x 605 - 186K
    July 2019
     if you start blender  using the .bat file that was created in your /Volumes/home/iron/Desktop/ folder, then you will see detailed error messages by the python script
    Blender 2.79b
    blender 2.80 eevee render
    i never used eevee ( well maybe i did in 2018 was it? ) so ... anyway i found the "Blend alpha" setting to make the cornea crystalline instead of you know, scary white
    600 x 800 - 108K
    Post edited by mCasual on July 2019
    If you open The Render Settings and check 'Refraction' and then under material select 'Alpha Clip' on the appropriate materials you'll get transparency on eyelashes and hair.
    https://www.youtube.com/watch?v=lFWiU0a5CiQ
    A cool tutorial.. Not by me.
    342 x 440 - 27K
    310 x 483 - 26K
    Post edited by Dean_2026310 on July 2019
    so gar when i import the scene in Cycles mode
    and i switch to eevee, amd i change the Materials/settings/blendmode from its default value of "opaque" to AlphaBlend or Alpha clip, i get the desired result ( hair, eyebrows, eyelashes, corneas )
    i plan to automate this, not sure if i'll have to do the import in eevie mode
    daz studio (frozen) scene rendered in blender eevie i may attempt to export via fbx instead of obj but last time i tried ( in 2013 or 2015 ) it had scary results that almost traumatized Gabrielle, but she's battle hardened
    900 x 1200 - 114K
    and so ends the weekend of July 20th 2019
    here you can see, the opacities work, the colored diffuse maps ( diffuse color multiplied by the diffuse map ) work
    and the texture tilings work
    the release this week of teleblender this week should support RPR (i think) Cycles and EEVEE
    1920 x 1042 - 298K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
