N.G.S. Anagenessis II - Revolution [Commercial]
1…3738404243
  • RAMWolffRAMWolff Posts: 10,393
    Looking forward to this release for sure!
  • DoctorJellybeanDoctorJellybean Posts: 10,170
    The only question is 2018 or 2019? laugh
    YIKES!
    Was wondering if we were going to have it before Genesis 9 ;). *chuckle*
    Laurie
  • missuskissesmissuskisses Posts: 918
    On one of the DA page comments, Dimension Z says hopefully this summer...I hope so, too!
  • ArielRGHArielRGH Posts: 105
    One ring to rule them all! :O
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,852
    aahh but which Summer and where in the world? Winter here in Australia now
    DA page says he's in Greece, so I'm hoping that means by end of August 2018. Did not get the impression that it would take another year, but who knows.
  • jardinejardine Posts: 1,224
    +1
    j
  • ragamuffin57ragamuffin57 Posts: 132
    Hmm  Just wondering if we are going to get a substancial update on the Iray front as Zevo who is quite quick  bringing new and updates to his products has gone silent  on his up comming  Genises 8 Skin Builder  and Also N.G.S.3 is on hold now could be both PAs have technical issues to overcome but as we have not had an update on the Daz studio front for quite a while  and the private build is now 4.11.0.154  wondering if an update with new Iray features is about to be released  ????
    Probably wishfull thinking  love to have an Arnold type render engine in a more affordable software  happy to pay for it !!  hey  excitied  for the release of  N.G.S 3 !!!  have enjoyed  N.G.S.2  but looking forward to see what N.G.S 3 brings !!
  • donovancolbertdonovancolbert Posts: 1,421
    Is the NGS Anagenesis 2 freebie script working or broken currently?
  • TooncesToonces Posts: 919
    Works great for me. I've found it a bit quirky on items without diffuse textures, and it always seems to recurse up to the root node of the selected surface (which isn't always desired...sometimes you just want the selected surface to be impacted), but these nuances aren't too hard to work around.
    finally picked this up so could try out the ngs skin version of Satine, also increased pores to max and added lip gloss option
    https://www.daz3d.com/gallery/#images/603321
  • vrba79vrba79 Posts: 1,548
    Breath some new life into the original Genesis figure this way.
    thought I'd test this out on one of the few v4 skins/characters I have, the cheer leader/model Reby Sky that Daz did
    https://www.daz3d.com/gallery/#images/604236
    with this one I tested  N.G.S. Anagenessis 2 - Revolution on a skin I created via facegen pro 2 wh9ich not only gives you a face but full body texture based on the face skin texture, at first had problem arms appearing different lighter than rest till relised my mistake was selecting the wrong genesis script picked g2 instead of g3 after selected right one worked with the pores on all of these I select high pores liking this ngs
    https://www.daz3d.com/gallery/#images/604751
  • ChadCryptoChadCrypto Posts: 596
    It seems to be weird. I installed that correctly. when I get to the final stage of clicking it, it does nothing.usually you get a flicker of something going on. weird.
  • IllidanstormIllidanstorm Posts: 655
    Can someone please help me with this?
    I want to apply NGS2 to this figure https://www.renderosity.com/mod/bcs/sabby-adley-for-genesis-8-/124204
    Here is how she looks without NGS2
    And here with NGS2
    Her skin looks not good at all. It's too olive colour. With other darkness settings she looks too brown. What can I do?
    And here with NGS2
    NGS2 really only works for the previous generations - genisis, genesis2 also known as 6 and genesis 3 also known as 7, I did manage a victoria 4 skin but that's close to genesis. If your g8 character was using a g3 skin it'd work but a g8 skin and I'm new to using this ngs2 btw I'd say no it wont work for that but the creator is working on a new version of NGS made to work for the genesis 8 figures
    edited July 2018
    I made it work now by turning the teal colour to more of a red tone. Not sure what exactly the parameter was is but it works now. Thanks anyway.
    Post edited by Illidanstorm on
    cool I did a g8 test came out like yours did I'll try what you did thanks
    Ok.
    For me it was SSS Reflectance Tint.
    Question : since this uses only one map, is it less memory hungry than a regular mapping system? Thanks!
    Normal G3F loads like this into the GPU for me
    Without NGS
    Iray VERBOSE - module:category(IRAY:RENDER): 1.8 IRAY rend progr: CUDA device 0 (GeForce GTX 1080 Ti): Processing scene...
    Iray VERBOSE - module:category(IRAY:RENDER): 1.3 IRAY rend stat : Geometry memory consumption: 13.7061 MiB (device 0), 0 B (host)
    Iray VERBOSE - module:category(IRAY:RENDER): 1.3 IRAY rend stat : Texture memory consumption: 354.251 MiB (device 0)
    Iray VERBOSE - module:category(IRAY:RENDER): 1.3 IRAY rend stat : Lights memory consumption: 196 B (device 0)
    Iray VERBOSE - module:category(IRAY:RENDER): 1.3 IRAY rend stat : Material measurement memory consumption: 0 B (GPU)
    Iray VERBOSE - module:category(IRAY:RENDER): 1.3 IRAY rend stat : Materials memory consumption: 67.0977 KiB (GPU)
    With NGS
    Iray VERBOSE - module:category(IRAY:RENDER): 1.3 IRAY rend stat : Texture memory consumption: 1.31543 GiB (device 0)
    Iray VERBOSE - module:category(IRAY:RENDER): 1.3 IRAY rend stat : Materials memory consumption: 70.0977 KiB (GPU)
    So NGS uses more memory for textures. 350 MB vs 1.3 GB. NGS is creating several bump, normal and other maps. So that statement isn't true.
    edited July 2018
    Edit 4: I fixed it.
    edited July 2018
    Ok.
    ok tried that one in blue praying is normal g8 skin and one in red ngs2 altered and sss reflective tint redish
    2719 x 2139 - 1M
    Post edited by ANGELREAPER1972 on
    Edit 4: I fixed it.
    I made that mistake too
    Thanks for checking! This is good to know when setting up a scene...
  • nicsttnicstt Posts: 11,715
    And here with NGS2
    I use it on G8.
    And here with NGS2
    I use it on G8.
    I mean, technically the buttons/script will work, but it's not optimized for the dual-lobe that many G8 figures use. The new version will have scripts for both pre-G8 and G8 figures. I really can't wait!
