Buy Something That Doesn't Work in Carrara? Post your Questions and Workarounds here. (please)
1…1314161819…53
  • VyusurVyusur Posts: 2,235
    Protozoon said:
    th3Digit said:
    the Protozoon piano does not even load in Carrara
    I expected the keys not to affect the hammers etc unless saved as poses which I was going to do each note but nah does not even load just gets an error
    Warning: file \data\Protozoon\HD Grand Piano and Poses\Grand Piano\Grand Piano.dsf could not be loaded
    Error: node /data/Protozoon/HD%20Grand%20Piano%20and%20Poses/Grand%20Piano/Grand%20Piano.dsf#Hammer%2001%20A0 not found
    Hi!
    I don't have any experience of Carrara, but I'll try to figure out a workaround. Does Carrara support Daz rigging?
    Protozoon
    Carrara supports DS rigging except for G3 and G8 figures.
    Stezza said:
    don't hold your breath
    this is the answer I got after waiting three years!
    Unfortunately, this product was never updated to work in Carrara.  Please note that at this time,
    Carrara is not currently under active development, for any platform. Our current focus is DAZ Studio and the Genesis figure platform.
    Unfortunately, we simply haven't had the resources for it.
    Please let me know if you require any further assistance.
    Thank you,
    Jamie
    uh oh.   guess i should ask for the refund again while in the 30 days.
    Hi!
    Protozoon
    the Daz Studio current default rigging "general" doesn't work in carrara.
    we've been using Edit, Rigging, Convert general to blended.  then saving it as a charactre preset.
    works on most figures.
    occasionally an ERC control won't work in carrara.
    or a formulae in a morph file will cause a figure not to load.
    Thanks !! for thinking of carrara customers !! !! smiley
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,634
    edited February 2018
    thank you for responding and your pm
    not many care as DAZ studio the only software that support is required for, hence this thread.
    I can get it in via FBX but of course have to manually pose every key and it's corresponding hammer etc but that is not unexpected, ERC functionality is DAZ studio specific
    it is certainly not the only thing I cannot get into Carrara but we post here so others can know before purchasing
    I shall still use it in studio anyway yes
     I still need to see if I can figure out Casual's midi script too or maybe pair events with the D3D midi piano poses to drive the animation, I do not have any scripting knowledge but can read a pz2 and duf file in notepad and swap out morph etc names, do so for mimic dmc files often and this should be no different it is just an animated pose generated by a midi file instead of a wav file the mechanics are the same.
    except there will be 88 morphs/poses to do hopefully only once, future generated poses a straightforward find and replace in notepad++ should work.
    casual's script may be the best choice
    https://www.daz3d.com/forums/discussion/70673/animating-a-keyboard-using-a-midi-text-file#latest
  • Bunyip02Bunyip02 Posts: 9,345
    Cyborg Generation 8 https://www.daz3d.com/cyborg-generation-8 is causing Carrara to crash, also tried converting to blended weight but it's still crashing. crying
    Looks like it's use DAZ Studio Pro if I want to use the figure.
    Post edited by Bunyip02 on
  • chickenmanchickenman Posts: 1,202
    Looks like it's use DAZ3D if I want to use the figure.
    As it is gen 8 I suspect that it is the naming in the skeletton as Misty found with gen 3 and gen 8
    and if like his other cyborgs even if it loaded the pistons etc need joint controls that fail in Carrara
    Piston Droopsie.
    Stezza posted a fix for that.
    https://www.daz3d.com/forums/discussion/comment/2736711/#Comment_2736711
    I'd certainly like a general way of making DS ERC stuff work (preferably without relying on Fenric's ERC plugin!) . . .
    Chohole jumps up and down in frustration.    "Looks like it's use DAZ3D if I want to use the figure."   you use Daz 3d every time you visit the forum, gallery or store.  Some products that you buy at Daz 3d do require that you use Daz Studio instead of your preferred program, which could be either Bryce or Carrara, or even a 3rd party program.
    I use DAZ Studio Pro about 10% of the time, Carrara about 85% of the time, and others (including Bryce) about 5% of the time.
    Just warning Carrara users who only use Carrara that it is a DAZ Studio Pro only figure, unless someone comes up with a workaround of course (which would be welcome).
    EDIT: names changed - hope everyones happy !!!
  • think Chohole was emphasising DAZ3D is the company and includes Carrara and Bryce and content that works in both.
    DAZ studio is the software
    aliasing lists a morph/pose control under other body parts.
    pasta-ulizing erc's calling aliases could be problemo-matic.?
    aliases sidebyside for x, bend for z, twist for y, then using those in erc ??
    Considering that this is a Carrara forum, and this thread is specifically about products (mostly Daz products) that don't work in Carrara, I think that everybody knew what you meant.
    Yes,  it's just that the more people who refer to that program by the Company name rather than the program name, the more people will think that it is the only program that the Company have.
  • DiomedeDiomede Posts: 15,462
    RE: Carrara Native Content Objects - Taking Inventory
    This has come up before, but somewhere along the line the included native content lost a bunch of models.  Do we know what else is missing?  Are there shader presets missing?  Etc.
    I was reminded while doing some computer hard disk housecleaning. I wanted to eliminate some duplicate saves on the same disk.  My most recent install of Carrara is missing some of the old native content buildings.  I confirmed by looking in DIM's installed file list.  For example, the old Carrara native content included Brooklyn Bridge, Independence Hall, and The Whitehouse.  I tracked down my old content and added them back in, along with several other buildings.
    But it made me wonder what other content I have probably been overlooking.  Does anyone know about other categories of presets missing some elements, and where to find them?
    1515 x 465 - 137K
    1721 x 235 - 75K
    1748 x 282 - 98K
    1867 x 968 - 232K
    Post edited by Diomede on
    Brooklyn bridge!!
    iirc there was a pdf of the native content with the install
  • the lifeforms went missing too
  • namtar3dnamtar3d Posts: 254
    LoRez Skeleton
    https://www.daz3d.com/lorez-skeleton-bundle
    Carrara was unable to import cr2
    1327 x 943 - 385K
    edited March 2018
    namtar3d said:
    LoRez Skeleton
    I am able to load it from the smart content tab.  It is listed under L for LoRez instead of S for skeleton.  Also, had to find the actual figure instead of the poses and shaders.  They are all in the same browser folder.  Aargh.
    NOTE - for the record, I try to avoid the smart content as much as possible.  Unreasonable fear on my part.  But I find that sometimes the DS version will load even if I have trouble with the cr2 version from the Runtme folders.  Generally worth checking.
    1846 x 805 - 254K
    edited March 2018
    Diomede said:
    namtar3d said:
    LoRez Skeleton
    thanks for that, yes I bought it, tried it once then put it back on the shelf - thanks for jogging memoery that it exists
    funnily enough I hardly buy any stuff here anymore...
    Post edited by Headwax on
    It works! thank you. Sadly the props can't be conformed automaticaly.
    Do you know if can i load the army presets?
    991 x 643 - 283K
    edited April 2018
    dont think this will ever finish loading.  https://www.daz3d.com/sakura-extreme-detail
    carrara not responding over half hour now.
    it did loadsmiley
    Post edited by Mistara on
  • StezzaStezza Posts: 9,258
    Wendy ( or any other Carrara'ist ) ... did you purchase the fly?
    if so.... does it work in Carrara?
    not fond of flies, I do use the Poser housefly occasionally but do not want one as detailed as Alessandro's awesome as it is, just too ewww.
    I have my fly spray ready smiley
    I think Alessandro also has a platypus coming soon.... will have to get that as well ...
    no probs apart from needing to adjust the shaders.... still haven't got it quite right yet..
    platypus heart
    edited April 2018
    fighting with the rosemill moor walls.  wall is solid, in wireframe mode i can see the geometry there shaped to the window.
    thought i'd just nip into the wrenchroom and assign those to new shader domain foe a transparency shader,
    darn thing wont let me select those polys it just shimmers at me
    sufferin succotash.
    i ended up using the ds geometry editor to delete those polys, and converted the wall figure to prop
    i guess, in carrara i shoulda detached skeleton?
