Adding to Cart…
You issue may be a bug in dForce itself.
I had a similar issue while using the dForce Sweet Anime Outfit for Genesis 8 Female(s).
I wanted to use dForce on the parisol fabric and frilly trim. As soon as I hit simulate, all of the fabric surfaces went poof and just vanished from the scene, until I hit the clear button.
It could be a general dForce problem.This is the only dForce that I have used. I did just discover that if I save the Scene and restart DAZ Studio, I am able render in iray again.
JamesJAB did you open a ticket with DAZ3D for your problem?
To get hair flow over her shoulder, you first need to move as much of the hair away from the pokethrough as possible, even if you have to make them float in mid-air, normal soft preset 8 should be a decent preset for achieving hair falls. Hair explosion could be caused by this, and it could also be caused by badly designed hair strands - in which case you can try using the weightmap to fix it
, oh and, weightmapping is actually required for most of the animation simulation to work
If the hair is falling down from the scalp, it means that it is not really nicely connected to the scalp surface, all you really need to do is to paint the roots of those area grey in the weightmap, and it should stop falling from the scalp
Now that I see your image, i remember i ran into a similar situation before. Have no idea what caused it but it should be back to normal if you save the whole scene and restart daz... I couldn't remember if I did anything other than that...
You can also try to open the scene in BETA version of DAZ and see if it is fixed
I am having the same problem but I am missing something in how to make this work. I have tried Alt+"Paint Brush Button" and release, Alt+"Paint Brush Button" and holding Alt down, pressing Alt while the "Paint Brush Button" is already pressed. No matter what I do I get a Red circle around a Green circle and can't paint anything.
One thing that I am wondering about is if the "dForce Modifier Weight Node" is correct. The hair does show up as Red as was mentioned in the PDF but, even though it is parented to the hair, it shows up way down on the ground. I've tried positioning it around the head but I not sure how it is supposed to behave.
Yup! That's how I solved it... according to my memory
It seems like you are painting something onto the scalp, just a very small chunk of it. Try increasing the sensitivity in your screenshot from 0.30 to 0.50+ and it should have better result :) The red circle around a green circle should be correct, holding ALT while painting simply gives the reverse effect of painting something red (which is what happens when you don't hold ALT and paint)
Are you refering the gradient painting in this? Yeah you have to drag the yellow circle on the top because that's where the color grey starts, and the red circle is when the color becomes completely red
What I am refering to is when you first create the dForce Modifier Weight Node. The Node itself is showing up at ground level.
Changing the sensitivity from 0.30 to 0.50+ works. I have both of the Characters hair working without exploding or falling out now. I am playing around with different presets now to try to get the results tuned in better. Once I have everything looking the way I want it to I will post some before and after shots along with notes on where I had trouble.
Oh! I actually had no idea about that! It shouldn't affect anything tho, since mine is probably at the ground level the whole time... lol
Glad to know it works! Good luck and will be waiting for your result
Is there a trick to help paint these hard to get spots? There is blue and even red that I can't seem to change. It works OK for a single frame but when I try to do the whole Animation she loses hair.
That case, you may want to try out the gradient painting mode on the right of the smooth brush (the one that looks like a pillar), but the yellow circle on the top and red half way down and let the gradient do its job :)
The problem I have with invisible renders is still there. I've done everything I can think of and things you've thought of. Nothing works. I do not have access beta versions of Studio, so I'm SOL.
Scott
And the DAZ support has no clue as well?
Have you tried looking for some kind of log file or something? There must be some kind of error message with stuff like this...
I haven't opened a ticket with DAZ support, my experience when I'm dealing with hard to find issues is less than stellar. Then again, studio is a free product, so I understand. Logs? Nothing out of the ordinary there, either.
That literally hit me in the head, and I still have absolutely no clue where the bug came from LOL, well, maybe next version of DAZ would eventually have some kind of error message in this...
That makes two of us. I've had some pretty bizarre issues since 4.10 came out. Stuff like .dll's getting moved to hidden directories, etc. All were OS related as they do not occur anymore since more updates have been installed. In those cases, there was absolutely no indication in any log on the entire machine, it just happened. This, because rendering works on figures where hairforce is not being used, tells me it's either in Studio or hairforce. Unfortunately, nothing I've done since having this issue then troubleshooting has led me anywhere except off a cliff. It's sad because when you announced this product, my excitement over more realistic hair positioning was over the top. Now, I just don't use it. I'm certain this issue is extremely rare as only one other person has reported it, however I can't help but feel disappointed--and that's not your fault--because my expectations were realistic in that I hoped I would be able to play with the product and see where it fit for me. I had no illusions that the product would work for every hair. Oh, well. I have more of your products that work great.
Scott
Okay, here are log messages. I was running through a bunch of different hairs and got this with Swizzle Bob. First error message ever, in fact the alert box said to check the logs, so here they are:
2018-01-17 22:29:26.042 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2018-01-17 22:31:03.851 WARNING: ..\..\..\src\dzopenclkernelfactory.cpp(30): Open CL notify: CL_MEM_OBJECT_ALLOCATION_FAILURE error executing CL_COMMAND_NDRANGE_KERNEL on GeForce GTX 1080 Ti (Device 0).
2018-01-17 22:31:03.851 WARNING: ..\..\..\src\dzdynamicsengine.cpp(2294): ERROR: Memory Object Allocation Failure (-4)
2
I'm going to update graphic drivers and try again.
Scott
Same error message. :) But, this happens before the simulation is complete, so I can render the result before the simulation bombs. I guess that's progress. :)
I got it working. It has to do with the hair being used. I used a hair that has been shown in this thread to work and it worked for me. Simulated and rendered fine. Now, does anyone have a list of hair that works? Most of the hair I have does not work. It's odd how it doesn't work, thoujgh. Some explode, some throw errors without log entries, some just yield blank renders. So, there you go.
Scott
I am also finding that changing gravity settings sometimes yields better results, as well. I don't believe I've read much about gravity settings in this thread. Changing the time the simulation can run has interesting possibilities, as well.
Scott
Anyone seen this logged error sequence?
2018-01-19 08:08:57.186 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2018-01-19 08:09:16.127 WARNING: ..\..\..\src\dzopenclkernelfactory.cpp(30): Open CL notify: CL_MEM_OBJECT_ALLOCATION_FAILURE error executing CL_COMMAND_NDRANGE_KERNEL on GeForce GTX 1080 Ti (Device 0).
2018-01-19 08:09:16.127 WARNING: ..\..\..\src\dzdynamicsengine.cpp(2294): ERROR: Memory Object Allocation Failure (-4)
2018-01-19 08:09:16.357 Total Simulation Time: 35.9 seconds
This happened when trying to simulate Pascale Hair for Genesis 8 Female. Using the difficult Hair Preset 01.
Finally! A log entry where the simulation completes, then rendering yields nothng:
2018-01-20 12:50:18.845 Iray VERBOSE - module:category(IRAY:RENDER): 1.3 IRAY rend progr: CUDA device 0 (GeForce GTX 1080 Ti): Processing scene...
2018-01-20 12:50:18.860 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER): 1.5 IRAY rend warn : RTKernel: degenerated geometry, must disable all ray tracing
2018-01-20 12:50:18.881 Iray VERBOSE - module:category(IRAY:RENDER): 1.5 IRAY rend stat : Geometry memory consumption: 28.509 MiB (device 0), 0 B (host)
So, to me, it looks like something corrupted the geometry to the point where IRAY puked.
Apologies somehow your log post puked the daz's forum notification system as well and I did not get anything when you posted all that
Yeah, this sounds really like a bug in dForce cuz no matter how it simulates, it shouldn't corrupt the geometry in any way (even if it explodes I guess, you can render exploded items lol)
Force isn't strong enough...
For those getting the invisible renders, are you sure your rendering camera is the same as the non-rendering camera? Can you see the scene in the viewport on the Render tab just before you click the blue Render button?
For this "hair from another site", is it one that was made in Poser's HairRoom and then converted to a mesh?
Are you using camera settings presets where the actual camera object's parameters have been tweaked?
Is there a plane in front of the camera in an attempt to mimic a real-world camera lens filter?
I know these are frustratingly simplistic questions, but these issues are seemingly improbable at best, and history tells us that people asking for help tend to leave out important details for one reason or another. "I accidentally a whole bottle" type of thing.
One last question: Is DS installed on C:\drive and on WIndows 10? If so, remove it, install it on a secondary drive (even a partition on C:\ that is not named C:\) and see if the problem is with Windows' Maximum Security protocols.
As for hands getting tangled in the hair, put a sphere primitive around the hands and scale it so it's like a mitten - just beyond the boundaries of the fingers but not so big they're like wearing bowling balls.
Yeah, this was an old trick that served us Optitex users well when trying to get conforming hairstyles and dynamic hoods to cooperate with each other.
I've been using it with dForced hair to help it maintain the base shape around the head while still letting it cascade when the figure is laying down.
Camera is the same as the rendering camera (it happens when I use iRay from the drop down menu, too). Straight up DAZ store purchased hair, too. Camera parameters have not been tweaked--simple render. C Drive install, and I'm not moving it, sorry. When Dell finally decides to give me a credit for the 2TB SSD drive I found was incompatible with my Alienware 17 R4 laptop, I'll think about it, but not now--it should make no difference. I am not getting security errors (I'm a Senior Network Security Engineer by trade) in any log. Besides, if I use the surface selection tool, the surface can be selected from the blank screen (drop down iRay render in the active viewport). They're just invisible. If I go back to Texture Render, the figure is there. The error is the geometry gets corrupted and rendering stops--it's in the log; that action clears the active viewport.
So, I guess I wait until the next version of Studio comes out. It's a shame because some hair does not cause this problem but others do, even with weight maps painted. I've even lowered the simulation time to the point where nothing happens, yet I get the same error in the logs.
I apologize for not finding the log entries earlier--their position in the logs depends on the time it takes the failure to appear.
This all written, when applied to a hair that works, it's exactly what I want. Unfortunately, one of the key things is the number of surfaces in the hair. If there are more than three surfaces (including the cap/scalp), I can pretty much guarantee the above result.
What I will do later (once I sleep) is disable the graphics amplifier and try this with the built in 1080 (you can't have two graphics cards active with the graphics amplifier--the system won't allow it, I've tried). I have little hope this will cure anything as both cards pass diagnostics.
Thanks for the input! :)
Scott
