Carrara Challenge #37 - Dungeons Deep - WIP Thread
12357…12
    a primivol trick:
    1. load a model, a bulky one as you need a thick volume, with a single mesh, if the eyes are stand alone spheres you won't see them.
    2. give it it's final shape morphs pose & location, so no animation.
    3. add a primivol object and give it the same location size& rotation as the model.
    4. use the model for the shape of the primivol object, in primivol's ramp off tab - 3d mesh.
    5. make the model invisible, in the general tab.
    6. if the primivol is a fire make it don't receive & cast shadows, in the genral tab too.
    7. if a fire add a bulb with soft shadows at the center the primivol / model.
    Very frakkin' cool!
    great and thanks for the mini tut :) didn't know about rotating and sizing the primivol
    Diomede said:
    Stezza, those cucumbers have gotten themselves in quite a pickle!  laugh​  Looks great.
    Shlomi, excellent looking cave.  Thanks for the step-by-step.  Saw your indirect light comment and decided to see what difference it would make for my project before it got too engrossed.
    So I have added some of the greebles and shaders to my space ship section.  The section has two blue-tinted tube lights in the roof.  No other lights.  I then duplicated the section (including tube lights) back toward the horizon.  I did put a negative light in the last duplicated seciton.
    Here is a test with and without indirect light.  The advantage of indirect light seems minimal to me.  The main drawback for the indirect light was the render time, which is signifiant.
    So Cool! This reminds me of when I was experimenting with Carrara's 3D Paint facilities
    ...and back then I also created a Carrara product for making D&D (or other RPG) dungeon tiles to print out. It works great for my own use even though I never finished it as a product. But with this one I made the textures using Genetica. Each square of the grid as well as the walls of this example are a cube in Carrara - each side has a different texture, so they can be easily rotated to change the individual tile. Each cube is named according to the grid space it occupies, so we can easily bring in a treasure or trap tile and align it with the cube in question. The border of the tile and the door with v-lighting are masked on top to enable the tile to look like a tile.
    very interesting Dart - so you are just not a pretty face :)
    quickie from me while not wrapping chrissie presents
    3802 x 2265 - 4M
    edited December 2017
    Post edited by Headwax on
  • DustRiderDustRider Posts: 2,921
    head wax said:
    Love the expressions!!
    Moving forward a bit, this is "Ember in a pink bikini getting attacked by a dragon in a dungeon".
    Well at least that's where I'm at now, but I think you may be able to see where I'm headed. I had to use DS to texture the dragon (DAZ Dragon 3) because trying to apply the mat preset would crash Carrara. Of course I could have also just manually applied the textures, since I had to anyway when setting up the Octane materials (glossy/specular mix), but I wanted to see if the alternate method worked. Not real satisfied with the lighting yet, but it's getting there.
    1600 x 1600 - 615K
    Post edited by DustRider on
    Jonstark said:
    So, did a bit more work on my Christmas-themed dungeon.  It's not coming together exactly like I pictured (nothing ever does though), but it's getting closer.  Trying to strike a balance between hiding the monster in the darkness and not making it totally invisible, it's tough to find the right balance though and I'm not there yet.
    Great idea, a creepy Santa Clause .... or maybe the Grinch?
    Stezza said:
    In the modeling room I created a tube and a globe for an ant hole.. joined & resized it to suit the cut it in half and used the displacement brush to rough it up..
    used the one default light and set the camera to 35 with depth of field turned on.
    Added some ants and duplicated them from Ken Gilliland over at Hivewire3D and then surface replicated them to the ant hole I modeled. Used a skull from them bones.
    Title - Ant Nest
    Wow, just wow!
    a primivol trick:
    Very frakkin' cool!
    yesyes
  • DartanbeckDartanbeck Posts: 22,154
    Looking fantastic! Yeah, I always just consolidate the dragon and manually load the maps and tweak them to taste. Sure looks cool, what you'r going for here!
    DustRider said:
    Me too! Especially seeing the dog ready to just go insane on whatever it is they're seeing. Get 'em, boy!
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Stezza, HW, Dustrider, Jonstark - looking good!
    Herk and the Serpent Queen
    I've become fond of the Daz generation 3 characters, and have decided to take a graphic novel journey with them.  This is a panel from a future part of the story, which just happens to fit this Challenge.
    The Herk character is a bit... different.  This post gives you a clue to his detached way of understanding the world.
    On the above render, I used a Daz snake texture and Carrara displacement for the Queen's skin (love displacement) and negative light for the skin tone.  I modeled armpit hair using Carrara hair. smiley  Also, there is a Horo hdri, along with some clouds for the green mist.  The characters are the morphing python, Freak 3 and V3 (with Caleb hair).  Comic Life 3 provided the captions, and PSE was used for tiny tweaks.
    1800 x 1041 - 7M
    1758 x 1133 - 530K
    Post edited by UnifiedBrain on
    Yes, Herk, I think she does! (work out, that is)
    Sweet render, UB!
  • Bunyip02Bunyip02 Posts: 9,345
    WIP - A Hungry Cave
    2270 x 1037 - 2M
    Post edited by Bunyip02 on
    Thanks Dart!
    Wow, that is pretty nasty-looking, Bunyip!  In a good way, of course.yes
    Thanks Dart!
    Thanks UB
    A couple of updates.
    Raw render straight out of Carrara.
    Postwork using the Mediachance Dynamic Auto Painter - Golden Age Finer filter.
    1200 x 900 - 2M
    1600 x 1200 - 3M
    That's super cool @Bunyip02!
    Once again I have abandoned what I was working on - it was just not coming out how I imagined. I decided to cannabilze some parts from the last one and just focus on a single room: a good old fashined dungeon of the sort you don't want to find yourself in!
    Everything is modeled in Carrara with just procedural textures.
    Here's the scene setup:
    The untouched render:
    The final with post-work:
    I've got a few more little things I'd like to add and I still really want to do some 3D painting in one of these, but just in case I don't get the energy to do it, I thought I'd go ahead and post it as-is.
    1908 x 1049 - 212K
    1400 x 1400 - 493K
    1400 x 1400 - 187K
    Post edited by MarkIsSleepy on
  • StezzaStezza Posts: 9,277
    @bunyip I'm sure I've seen that cave at Wombean! creepy as!
    nice shadows @MDO2010 I like it... hope you get the time to finish it..
    Thanks all for your comments on the ant nest.... smiley
    This next one I used one of Petipets SciFi corridor sets and made it much biggerer and also one of his UFOs'
    Set during WWII it's when the aliens handed over plans and a foo fighter to the SS.. One of the last photos that didn't get destroyed...
    Title - Foo Fighter
    941 x 717 - 331K
    1000 x 727 - 757K
    Post edited by Stezza on
    Awesome you guys! Bravo!
    Headwax - love the suspense in your render
    Dustrider - looks great, hope you have time to finish it off.
    UnifiedBrain - your sense of humour tickles my funny bone.
    MDO2010 - thanks for your comment. Your dungeon scene looks very interesting - hope you can get it to entry stage.
    Stezza - great work as always, the ants render is my favourite.
    Second one from me - Sting in the tail.
    Setup
    Raw render from Carrara
    Postwork using Mediachance Dynamic Auto Painter - Aqua Real filter.
    2274 x 1033 - 965K
    1600 x 1200 - 2M
    1600 x 1200 - 5M
    yes
    wowza, blink and youl misseltoe it
    Thanks Bunyip, now that is one creepy creature - very greek myth
    Title - Foo Fighter
    stezza, I hate to say it, but you are getting betterer and betterer
    this is a beauty, the lighting just sings - mind you, I liked how your other was going as well :)
    Bunyip02 said:
    WIP - A Hungry Cave
    wow, this one is creeping me out, has all sorts of Freudian undertones
    love this style, the lighting is 'just right' - care to give us a rundown on how to get that effect?
    thanks Dart et Dustrider :)
    thanks Head Wax.... means a lot coming from the master yes
    Thanks a bunch HW!  The HDRI did most of the heavy lifting.  Appropriate for this Challenge, I used the "dungeon" HDRI from Horo's Tourbillion HDRI set.  Then just followed his excellent read me directions for Carrara - HDRI at 200, GI at 200.  And I added a few low power distant lights (and a brighter negative light for the blue skin).  All of that seemed to work well with Freak (a slightly darkened skin map, default was too light for my taste), and with the V3 skin displacement.
    pleasure, master I wish!
    thanks UB, that's very kind of you! I like how you are working with the older characters too
