Genesis 3 to Genesis 8 Pose Converter (Commercial)
13468911
  • Sorry in advance that I didn't read through the five pages in this thread to see if an answer is here already, but.....
    I'm using Daz 4.10 and just bought this product. I can't figure out how to use it. Is there a How To type document anywhere or a Tutorial? I was able to open it up, but when I tried to convert just one simple pose, it hung on 0% progress for 20 minutes before I realized it had completely frozen Daz.
    I’m having trouble with the converter. It used to work fine but now I’m having issues with the v4  pose converter and the Genesis 8 pose converter. Sometime when I run it is says it runs but there is nothing there. Half the time it doesn’t make the icons for the pose when it does convert it.
  • Zev0Zev0 Posts: 7,123
    edited November 2017
    Can I see logs of the time this happened? If possible, clear log.txt first then run the process so its easier to track.
    Post edited by Zev0 on
    Sure. I’ll do that tonight. Thanks for your time.
    Okay, here I decided to convert this product: https://www.daz3d.com/trouble-brewing-poses
    The Converter tool I'm using is: the G3 to Gen8 tool.
    I know this can work, since I just converted another Feralfey set right before it- and it went smoothly.
    When I ran on this set, it did its song and dance just like the it converted the last batch- but nothing shows up in my result file.
    txt
    txt
    trouble-brewingerror-log.txt
    34K
    I also tried to convert this pose set: https://www.renderosity.com/mod/bcs/?ViewProduct=118978 Using the same tool. It runs... But I get nothing.
    txt
    txt
    log2.txt
    109K
  • JBroJBro Posts: 4
    This doesn't work, and your little fan club is no help. Product Support?
  • jag11jag11 Posts: 885
    I only see this problem from the log:
    2017-11-29 19:14:29.226 DEBUG: sFilePath = C:/Users/seren/Desktop/Genesis 3 Female and Male/!Reset G3F.duf2017-11-29 19:14:29.226 DEBUG: Path D:/DAZ 3D/People/Genesis 8 Male/PosesC:/Users/seren/Desktop/Genesis 3 Female and Male2017-11-29 19:14:29.226 DEBUG: Reading C:/Users/seren/Desktop/Genesis 3 Female and Male/!Reset G3F.duf
     The path in the second line above is malformed.
    How do you expect any help when all you've said is the script doesn't work and no one is any help? If you want support beyond the forum, put in a technical support ticket. That's how product support works.
  • k886860k886860 Posts: 12
    edited December 2017
    この製品は、あまりにも頻繁に動作を停止します。
    コンバータの問題なのか、またはポーズの問題なのかは分からないが
    特定のメーカーのポーズを変換しようとすると、プログラムが凍結しまいます。
    私はこのコンバータを利用して多くのポーズを一度に変換することを望んだが
    このような理由から、ニッチいちいち一つ一つ指定して変換するしかありませんでした。
    また、この製品だけでなく、以前のコンバータは、4.10のバージョンでは、ポーズの変換速度が遅すぎ、むしろ4.8バージョンでは、私の速度が出てくる不思議な現象が出てきます。
    今回の製品は、4.9以上でのみ動作するように作成され4.8を使うことがないようにされた
    Post edited by k886860 on
  • この製品は、あまりにも頻繁に動作を停止します。
    If that is the case why don't you put a ticket in, I use it and have no problem with the speed when converting !
    Thanks. I’m afraid I’m not a script writer. Can you explain what that means?
  • nonesuch00nonesuch00 Posts: 18,856
    There in the 2nd lines: PosesC: should read Poses C: but that could just as well be a mistake in the debugging log and not the actual work log.
    Means the developer assumed both, input and output folders would be declared in the Content Directory Manager, when they are, Content Manager returns a well formed path and no two root combined paths.
    Let me know if that fixes it.
  • Hi,
       Really like this product, however I did just run into a little problem but also a solution. This might also be the issue causing some of the folks above problems as well.
    Here is the issue. I have been using the batch converter on a number of poses without issue. I just tried it on a new pose collec "Be Seated for Gen3" and attempted to apply converted pose. This failed.  Upon researching the orginal pose file I noticed that it used the Mac convention of 'CR' vs. the windows 'CR/LF'.  I am on Windows.  I used a text editor (NotePad++) to convert the file to the Windows format and re-did the conversion. Voila the error is gone and the pose applied correctly.  I hope this helps some folks.
  • PlayerdarkPlayerdark Posts: 6
    edited February 2018
    So thanks to Jag11's comment above I finally realized that the in and output paths must be in the daz library path. No problem, but should be somewhere on the UI so people dont waste time finding this info.
    So I stored a pose preset file with an animation and the converter runs fine on it, but when I try to load the file on G8  I get "An error occurred while reading the file, see the log for more details".
    So for now it looks like the product does not work with animations which is what I need.
    Is there any hope for a quick fix?
    2018-02-12 13:28:59.393 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLWink_HD.dsf#eCTRLWink?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Wink_HDLv2.dsf
    2018-02-12 13:28:59.393 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLScream_HD.dsf#eCTRLScream?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Scream_HDLv2.dsf
    2018-02-12 13:28:59.394 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLRage_HD.dsf#eCTRLRage?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Rage_HDLv2.dsf
    2018-02-12 13:28:59.394 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLPain_HD.dsf#eCTRLPain?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Pain_HDLv2.dsf
    2018-02-12 13:28:59.395 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eJCMPain_HD_div2.dsf#eJCMPain_HD_div2?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Pain_HDLv2.dsf
    2018-02-12 13:28:59.395 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLHappy_HD.dsf#eCTRLHappy?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Happy_HDLv2.dsf
    2018-02-12 13:28:59.395 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eJCMHappy_HD_div2.dsf#eJCMHappy_HD_div2?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Happy_HDLv2.dsf
    2018-02-12 13:28:59.395 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLFear_HD.dsf#eCTRLFear?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Fear_HDLv2.dsf
    2018-02-12 13:28:59.396 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eJCMFear_HD_div2.dsf#eJCMFear_HD_div2?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Fear_HDLv2.dsf
    2018-02-12 13:28:59.396 WARNING: fileinput\dzassetdaz.cpp(5795): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLExcitement_HD.dsf#eCTRLExcitement?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eCTRLVictoria8Excitement_HD.dsf
    2018-02-12 13:28:59.791 Begin Loading Character Addons...
    2018-02-12 13:28:59.866 File loaded in 0 min 0.0 sec.
    2018-02-12 13:28:59.867 Loaded file: genesis 8 female eyelashes.duf
    2018-02-12 13:28:59.880 Loaded Morph Deltas in 0 min 0.0 sec.
    2018-02-12 13:28:59.880 Loaded file: FHMVictoria8.dsf
    2018-02-12 13:28:59.900 Loaded Morph Deltas in 0 min 0.0 sec.
    2018-02-12 13:28:59.906 Loaded file: FBMVictoria8.dsf
    2018-02-12 13:28:59.908 Loaded Morph Deltas in 0 min 0.0 sec.
    2018-02-12 13:28:59.908 Loaded file: PHMMouthRealism_HD_div2.dsf
    2018-02-12 13:28:59.913 Loaded Morph Deltas in 0 min 0.0 sec.
    2018-02-12 13:28:59.913 Loaded file: PBMNavel.dsf
    2018-02-12 13:28:59.925 Loaded Morph Deltas in 0 min 0.0 sec.
    2018-02-12 13:28:59.926 Loaded file: PHMEyelashesExpand.dsf
    2018-02-12 13:29:00.041 File loaded in 0 min 0.0 sec.
    2018-02-12 13:29:00.042 Loaded file: Victoria 8 Eyelashes.duf
    2018-02-12 13:29:00.044 Finished Loading Character Addons
    2018-02-12 13:29:00.057 File loaded in 0 min 7.1 sec.
    2018-02-12 13:29:00.082 Loaded file: victoria 8.duf
    2018-02-12 13:29:10.455     C:/Data/DAZ 3D/Studio/ConversionOut/temp1.duf (653,1): Syntax Error - expected ',' or ']'
    2018-02-12 13:29:10.456 Error reading file, see log for more details.
    2018-02-12 13:29:22.381 DEBUG: Content Library Asset Path = C:/Data/DAZ 3D/Studio/ConversionOut/temp1.duf
    2018-02-12 13:29:22.381 DEBUG: oAsset.contentType = Preset/Animation
    Post edited by Playerdark on
  • dawnbladedawnblade Posts: 1,723
    Just bought this and converted pose sets by FeralFey (Classic Pin Up Poses), i13 (Fierce Fantasy), and Neikdian (Active: Magic) with metadata on. Wow! Works flawlessly. smileyyes
  • ArtsyDragonArtsyDragon Posts: 682
    I am not sure what is going on. It very well may be user error.
    After some success with the G3 to G8, I was excited to try the G2 to G3. Steps were the same. I selected the path where the new poses should go, I selected the path where the current posers are located, I click 'convert' and then to my surprise, I cannot find my converted files.
    They are not in the folder where the original files are (which is good, I created a folder at the same level as the original folder). They are not in the Local User area where the poses that were converted from G3 to G8 went. I checked the 'converted' folder in the Coentent Library just in case and that is also empty.
    If someone could help me figure out where the files ended up, I would appreciate it.
    Thanks,
    @illysArt
    How about a screen shot of thePose Conveter main screen that pops up,
  • DiniDini Posts: 115
    Hello.
    I bought the converter today.
    Unfortunately, nothing is visible in the destination folder after conversion.
    The destination folder remains empty.
    What do I do wrong?
    Thank you
    edited March 2018
    Need a bit more info. Did you add metadata in conversion or not, did you hit refresh? Can you post a screenshot of your settings and path inside the script?
    Sorry. Unfortunately I do not speak English.
    I use Google translator.
    I tried it with metafile and without.
    Here is a screenshot.
    710 x 682 - 132K
    Is the path of converted poses on the G: drive mapped in Studio?
    No. It is a freely chosen path on another drive.
    Daz Studio is on drive C, including "My DAZ 3D Library".
    The path chosen has to be added to your Content Library as mapped. See attachment.
    735 x 467 - 32K
    It works now.
    But only with "Smart Content" and "Content Library".
    Unfortunately, "Add Individual Poese Files ..." or "Add Pose Directory ..." does not work.
    So I work with "Add Individual Poese Files ..." or "Add Pose Directory ..."
    I select in the window the files I want to convert and click on "Convert Files".
    He converts the files.
    Then I click on "Browse To Converted Files Directory ..." and the destination folder is empty.
    ("Crate Metadats" is OFF)
    But with "Smart Content" and "Content Library" it works now.
    Many roads lead to Rome.
    Many Thanks wink
    "It works now.
    It is only meant to work with those.
    Dini said:
    It works now.
    Dini said:
    It works now.
  • RAMWolffRAMWolff Posts: 10,373
    Hey Z, will this convert poses between the same generation like from Male to Female and vice versa?
