Adding to Cart…
Thanks for the reply namffuak .
I did all that several times and am still waiting for a useful reply from help centre.
Yes. When it wouldn't show up, I searched in the store and it showed it as a free item. I thought I had to go through the check out inorder for it to show up. But I finally checked on Public Beta and it was finally there. Didn't have a chance to come back until now to say that I finally found it. Since this has to be installed through DIM, I assume that the DS beta has to as well. But I see it on the Daz Connect install panel. Can it be installed from there too?
Amazing
Installed and played around with some very simple meshes, seems identical to good 'ol Hexagon 2.5 but so far no crashes.On my current system Hex was pretty unstable so this seems much better so far. Since I haven't migrated to G8F yet and I'm sort of maxed out on G3F and G3M stuff I've been feeling to urge to model some props and funirture and stuff, just for the fun of it. Now .. no excuses! I'm thrilled that this is moving forward!
Great news, thanks DAZ.
is this new that you can place tabs on second monitor now seperately ?
and all those models
never noticed them before
ok you can place tabs on second monitor but it does not save them or ?
As stated in the announcement post, the initial goal for this Public release was stability. Improvements, etc, will follow over time.
I'll take stability.
I am SO looking forward to the new version!!
The "Triangulate Non-Planar Facets" tool icon and the "Triangulate N-Gons" tool icon are backwards. The documentation has them labeled correctly.
..still a bit confused as to where the content is supposed to go. All Daz content gets pointed to my D:/Library drive.
saving tabs on 2. Monitor works now dont know why
but never knew you could do this
a big wish from me is that if you unfold for uv map it would in a way that the corners are matching so you could paint better on it
if you unfold a cube you can have 6 sides shown but they do not match the corners
Ruphuss, can you take a screen grab of the map you make in hex and change it in a paint program and post both images. May-be there's a work around (or a differnt way of unfolding your prop) we can come up with.
The content goes in the application folder. DIM will place it for you, as long as you install the content after the beta application.
Adding tools to the custom tool palette seems to cause Hexagon to crash when exiting the program. Clearing out the custom tool palette allows Hexagon to exit without crashing. I haven't narrowed down which tool exactly is causing the crashing.
Using DIM , which i never like and i hate again, i have IM00032301-21_Hexagon25ContentPublicBuild but not the application itself. I follow the instruction and try and try again using DIM
I have finally only content models not app beta version Can i repeat ;: i never like DIM interface and hope sincerly that DAZ will rebuid it with a simple clean interface where we simply choose what we want , set where we want put it and download or install it where we want Please redesign the interface of DIM
So i will reinstall the 2,5 version with sn i have bought some years ago from Eovia even i did use it so much , prefering Silo, Rhino and Zbrush But i have liked the interface
I had to check more than just Public Build in order to see the Win32 Hexagon 2.5.2 BETA app listed for downloading. Checking off Public Build only shows the Hexagon content file for downloading.
There's another tickbox to show or not show programs.
I can't find the beta in my DIM. I've serached for Hexagon, Beta, Public and others, have checked the "Display Hidden"-Button, but it wasn't shown. Can anyone please help?
You did add it to your account?
https://www.daz3d.com/hexagon-beta
I use Blender. But in my opinion adding Exagon as a modeler tool for Studio is a huge step forward.
Now, adding sculpting capabilities to Hexagon for editing/creating HD morphs and/or to bake them to normal maps would be great. And would also make it much easier to use the interactive licenses, that, in my opinion, at this time are almost useless for most assets.
The second big missing one is real animation in Studio. I mean a real IK system. Not just a part-time IK for posing. Plus some serious particle and volumetric engine for fluids and flames fx. Plus a fiber engine for hair. That is, adding fx to animation itself.
In my opinion the two keys above are what Studio is missing to reach Blender or Maya users.
I have tried again I still have only content not Hexagon application it self
You'll find the check mark that will show the app in your queue soon enough. If I could figure it out (my first time ever using DIM), anyone can.
Please go back to the Ready to Download tab, click the Download Filters button, and post screenshots of your settings
Thanks for reply
Here the screen shoot, Richard
That isn't showing the Download Filters.
I followed the instructions to locate and download the beta; once I have it, however, it fails to install, saying the installation path can't be located.
Under Settings>Applications, the only options I have are for Hexagon 2 or 2.5, 32-bit; selecting either still gives me the above error. DIM v. 1.1.0.72
It WILL install; what I did was create the directory I wanted to install it in using DIM, then restarted the installation process. You may want to restart DIM to make sure it picks up that directory.
Nope - that didn't do it.
