Victoria 8
1…1011131516…19
  • JQPJQP Posts: 527
    JazzyBear said:
    Alien fingers! Both male clones do this.
    Jazzy Bear, when I get weirdness like that, I zero the pose and "adjust rigging to shape," that always fixes it. No idea if it'll work with V8, but my guess is it will.
  • JazzyBearJazzyBear Posts: 805
    Thanks... I am sure it will.
    I was reminded this is a clone and not a true shape anyway.
    It was about 2AM or 3AM when I forst did that so the brain wasn't too clear. I was just excited the clones were included with the Gen8 essentials!
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,860
    Loving her....and of course, she is squirrel approved.  :)
    oh I really love this one in your gallery to like up? wish could share this with others on fb too love showing off what others can do
    So what is this hair on Victoria 8? I thought it would be in the pro bundle but it doesn't seem like the same ponytail
    looks like the twilight hairs Twilight Hair for Genesis 3 Female(s) https://www.daz3d.com/twilight-hair-for-genesis-3-females  Twilight Hair for Genesis 3 Female(s) in Vendor, goldtassel,  3D Models by Daz 3D
    Twilight Fall for Genesis 3 Females(s) https://www.daz3d.com/twilight-fall-for-genesis-3-females ;Twilight Fall for Genesis 3 Females(s) in Vendor, goldtassel,  3D Models by Daz 3D
    Colors for Twilight Hair https://www.daz3d.com/colors-for-twilight-hair ;Colors for Twilight Hair in Vendor, goldtassel,  3D Models by Daz 3D
    Is there a "mouth realism" morph that defaults to on like with G3?
    There is a "mouth realism" morph, but as far as I can tell it stays off until you slide the morph slider?
    There's a Mouth Realism morph, and also an Eye Rim morph, both HD, and both defaulting to zero value. Those seem to be the only HD morphs that come with the base G8.
    Whoops, not quite, the base expression morphs are now HD as well.
  • Jan19Jan19 Posts: 1,109
    I like V8.  Everything I've tried for G3 will work on her except the character shapes.  Is there any way to get a G3 character shape to transfer over to V8?
    Any advice appreciated. :-)
  • Mr PbodyMr Pbody Posts: 7
    So is there a way to convert morphs?
  • TottallouTottallou Posts: 555
    This tutorial will get you on your way to transferring Morphs
    http://sickleyield.deviantart.com/journal/Tutorial-Transferring-Character-Morphs-G1G2G3-409437916
  • RedzRedz Posts: 1,459
    edited June 2017
    Redz said:
    First try transfering a G3F morph to G8F using the manual method that was described here on the forum when G3 first came out.
    This is Monique 7. I think she turned out quite well for a first attempt, just a little kinking at the ends of the fingernails.
    Llynara said:
    She looks very good, Redz! Do you have a link to that thread? Would love to try it. Thanks!
    She'd look better if I'd remembered to put her lashes back on. This is the original thread https://www.daz3d.com/forums/viewthread/24093/ If I have time tomorrow I may try to write up a quickie updated  tutorial. I can share my helper poses/shapes but not I should think,  the G8 mesh itself that''s used to make the morphs from G3.
    Here's Mei Lin on G8F
    Redz this is fantastic, How are you doing this because I can't seem to find the method you referenced in the thread you linked. I am quite on the fence because I have beautiful V7 characters and like most don't want to start all over again, I would invest in V8 if some of my character morphs can be used on her.
    This is the method I used, slower but I've found it better than the transfer utility for body morphs especially, though the nails are still a little off
    Tutorial and helper scene/morphs included
    DOWNLOAD HERE
    Post edited by Redz on
  • I wonder when M8 will come out next!
  • a-sennova-sennov Posts: 332
    Llynara said:
    Cayman Legacy UV's
    This product uses geografts and they will not work on G8F because she has different mesh (thow shoulders and thighs are topologically the same except different default pose).
  • OdaaOdaa Posts: 1,548
    edited June 2017
    I must be doing something wrong...morph dials are showing up but they don't do anything.
    ETA: never mind, working now.
    Post edited by Odaa on
  • TryhardTryhard Posts: 166
    Has anyone figured out how to transfer legacy morphs like V4/A4 to G8?
    edited June 2017
    Thanks for the info. :-)  I can't get anything character-shape wise to work though.  I checked the number of polygons, and G3F and G8F do not have an identical poly count.  No big deal.  I still like V8.
    Post edited by Jan19 on
  • PhilWPhilW Posts: 5,162
    DOWNLOAD HERE
    That looks very clear and very helpful - Thank You!
    SickleYield's tutorial seemed to work for me once I selected "favorites and subcomponents" instead of "favorites." Didn't have time to test it extensively before leaving for work though.
    If I were trying that, I would see about transferring them to Genesis 1, 2 or 3 first and then transferring the result to G8.
  • Loving her....and of course, she is squirrel approved.  :)
    She is in the gallery here and in the Daz Studio Artists art group on FB.  Thanks  :)
    I'm in that group and few others but no share button there or in gallery here only one you have here but it is a good one this shouls get in the top rated gallery
  • RenderGuyNYRenderGuyNY Posts: 104
    I just couldn't help myself!
  • hjakehjake Posts: 1,346
    edited June 2017
    I messed up this morning on my V8 purchase and neglected to add V5 and V6 pro to my cart before hitting checkout - got confused and thought I had them already - only have V7 Pro - I really shouldn't shop until after my morning two cups of coffee... Meh, I already have most of both bundles that I really wanted - but still annoyed at myself...
    I did not add v5 and v6 pro bundle for same reason. thought i bought them already ????
    they were manually added to my library by Daz without my asking this morning.  Thank you Daz.
    and i did get a bonus 10% on everything for buying a previous Victoria pro bundle.
    so check your product library.
    Post edited by hjake on
  • ToyenToyen Posts: 2,080
    edited June 2017
    Here is my V8 render. Enjoy! :)
    Post edited by Chohole on
  • nonesuch00nonesuch00 Posts: 18,878
    DOWNLOAD HERE
    Thanks. I have done SickleYield's tutorial successfully (thanks @SickleYield) and I will try yours to. There always seem to be exceptions to these things and knowing more than one one to do this might be helpful in those exception cases.
  • SnowPheonixSnowPheonix Posts: 896
    edited June 2017
    I want to hate Genesis 8 but since its backwards compatible to my Genesis 3 skins, all those really great skins I invested in are still usable... all is not lost.  I can have my cake and eat it
    too.. O.K.  So of course Victoria comes out with her all too familiar perfect skin blandness that says she's been sheltered in a dark closet all her life... her skin is almost literally a blank canvas... that beings said, I do like what I see.  I figure I'll have to wait a few months to see a character with more color varations in the skin but so far...  I love her and I love that somebody was listening to me and made a new set a wings to go with this angel.
    Alright... I love how the lighting reacts to her.. whatever you've done to the skin to make it react so perfectly to light.. with all that sub-surface stuff going on.. Wow.. great job.  I love all the new articulations.. Yes, it does look that much more real.. we're not just fooling ourselves... I didn't want to but I have to love her and save up for the eventual release of the male version... You got me but make a skin with some real variations please.
    1288 x 575 - 547K
    Post edited by SnowPheonix on
  • Seven193Seven193 Posts: 1,156
    edited June 2017
    It's not just an A pose, the legs are spread apart too. What a nightmare that's gonna be for creating shoes. Is there a pose available where her feet are flat on the ground? (For the base figure)
    I can understand how having an A-pose for the upper body might be an improvement for fitting clothes, but why do it for the legs?    I mean, come on, the feet for Genesis 8 aren't even flat on the floor.  IMHO, shoes should be fitted flat, not at an angle.  Why not have both, A-pose legs and flat feet?
    It probably has something to do with maintaining straight lines, from the hip to the foot, so having both might be an unnecessary complication for fitting footwear like long boots.
    Post edited by Seven193 on
  • DaWaterRatDaWaterRat Posts: 2,887
    Based on the release dates of Michael 6 and Michael 7 ... I'm guessing November.
    edited June 2017
    So I ran transfer utility to transfer a morph from Karen 7 to Victoria 8 it seem to be stuck at 22%. I went and took a nap for a couple hours and came back. It seems I was successful when I came back, so I tried it again. It takes 20 minutes for transfer utility to work. You have to search for the dials.
    Two issues I've noticed right now. First the process takes a long time and second the arms are exploding when using poses. In addition the toes look strange.
    Post edited by Mr Pbody on
  • 3Diva3Diva Posts: 12,058
    DOWNLOAD HERE
    Whoa! Thank you so much for sharing this! I look forward to trying it out! yes
  • LlynaraLlynara Posts: 4,772
    edited June 2017
    Anneka Demon on G8F looks pretty good! I ported over some of her morphs with Redz tutorial (thanks, @Redz !) The new facial rig is AMAZING!
    Post edited by Llynara on
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,984
    JQP said:
    EWWW  Yuck, can this be fixed?
