DS 4.9.4?
1356
  • MartialMartial Posts: 431
    Allo
     How can i download the new version ?
    I can not see it in my account, product library using name filter
    It is not displayed  when i using DIM
    It is not downloaded when i click download at
    https://www.daz3d.com/get_studio i clicck and nothing is downloaded just go to my product library and i cannot see ther  DAZStudio file
  • FauvistFauvist Posts: 2,290
    Fauvist said:
    I don't want my computer CONNECTED to DAZ over the Internet.  With this new update - can the DAZ Studio I have on my computer be fully functional without being connected to DAZ or the Internet?
    Yes.
    But then, what is this DAZ CONNECT feature?
  • BlueIreneBlueIrene Posts: 1,318
    I'm not touching this until I know what it does to custom categories...
    I backed everything up before warily updating, but the new version did nothing to my custom categories and they're all where I left them.
    I'm relieved that that's not changed, but to be truthful I've yet to see where anything has changed. Admittedly I haven't had much time to test drive the new version and I imagine most of the improvements are behind the scenes, but I've noticed nothing new feature-wise and no change in performance during the normal course of events. Slightly underwhelming, although I expect I will feel differently if I want to Power Pose and do it with plenty of additional specularity :)
  • BobvanBobvan Posts: 2,653
    edited June 2017
    Yes.
    Speaking of that I somehow have the new install on the beast needing to connect how do I go about changing that thanks..
    Post edited by Bobvan on
  • HavosHavos Posts: 5,627
    Fauvist said:
    Yes.
    A feature introduced in 4.9 (not this release), and like many other features, you do not have to use it. If you do want to use it, then you will need to connect your PC to the net just once. If you do not want to use it, just carry on as before, no installation methods have been removed.
  • nicsttnicstt Posts: 11,715
    oh was kinda hoping when saw the big deal of this new version the new genisis4/8 was going to be a part of it but wasn't
    I wouldn't really expect it; new figure and new Studio the same day would be extra headaches.
  • escrandallescrandall Posts: 507
    The first time I've updated and the Measure Metrics password didn't need to be reapplied
    You don't have to log it; you can uninstall SQL components. I did for months, but object to the spam that Studio subjects my SSD to when it is uninstalled.
    This might be what is needed for gen4/8? Who knows? :)
    I was guessing that Studio 5.0 would coincide with Genesis 4/8 release.
  • Nyghtfall3DNyghtfall3D Posts: 813
    Yup, mine isn't.
    No reason why it should. If the auto-fit improvements had been done with Genesis 8 in mind (which is pure speculation, of course), and if the new Genesis 8/V8 is indeed due to arrive soon (more speculation), then I imagine that the new figure would work correctly with 4.9.4.
    Installed and it left my categories alone :).
    Laurie
    Laurie
    Laurie are you the same AllenArt who posts all those cool iray freebies? If you are many thanks!!
  • CybersoxCybersox Posts: 9,541
    Yeah, given how well G3F seems to be selling, I would imagine that DAZ would have the common sense not to derail the gravy train just yet, especially when the G3s are in the process of finally replacing V4/M4 as the dominant figures in this hobby.  And really, any significant improvement on the existing figures is going to be dependent on enough new features/capabilities being worked into Studio that it would go beyond an incremental upgrade.  My guess is that we might see Studio 5 hitting sometime around the end of this year.or the beginning of 2018.
  • marblemarble Posts: 7,500
    I'm a little confused about what is Power Pose and what is Active Pose and which one has been improved and how. Most of the language in the DAZ announcement is way above my head.
  • Alright I just updated Daz Studio and as for the auto fit the shoes from V4 to G3F still not working right even with the smoothing option. Can someone please tell me if they are having the same issue with the auto fit and how can I fix it thank you
    2200 x 1862 - 2M
    2200 x 1862 - 2M
    Bobvan said:
    Laurie
    If you mean shader settings, bangles and earrings...that would be me. And you're welcome :D
    Laurie
    Yeah, I would like to know the difference too. LOL
    edited June 2017
    AllenArt said:
    Bobvan said:
    Laurie
    Laurie
    Your PVC shaders are brilliant sorry to go OT I like to thank vendors when I get the chance :)
    1860 x 950 - 2M
  • Richard HaseltineRichard Haseltine Posts: 109,358
    Active pose is a tool, it lets you pin bones and adjust the pose around them - but only by dragging in the viewport, and only with translations. As far as I know it is unchanged.
    PoserPose is a pane, it allows hot points on a template image to be assigned to parameters on the figure so that you can drag on the hot point to adjust the parameter without having to change selections (a more visual form of Pose Control parameters). Power Pose has been updated, it had been lacking the ability to support newer figures without hacking files but it now has the tools for creating and savng set-ups.
    Boots and shoes, at least high heels, have always been a problem for AutoFit.
  • Sensual ArtSensual Art Posts: 646
    Achilles Heel of autofit I presume!
  • AndySAndyS Posts: 1,447
    Chohole said:
    some AV programs simply see something new and say  "Ooh it's new, must be suspect" because it isn't already added to the heuristics that the program recognises.
    AndyS said:
    Nyghtfall said:
    ... and I've just discovered Windows Defender doesn't like 4.9.4.
    You're not alone. There are several further security programs indicating DAZ using some kind of trojan mechanisms.
    Perhaps in DAZ they're harmless. But in general - yes there are suspective sigatures used by the developers.
    I often pointed it out in the past but it was denied.
    You know what:
    Several big companies and portals like facebook, yahoo, sony, etc. thought the way you do. And ...
    They got hacked several times in the near past.
  • fixmypcmikefixmypcmike Posts: 19,708
    You know what:
    When this happens I go to a site like virustotal to see which AV's are reporting it.  If it's only ones that use heuristics which depend on many people downloading an app, I take it with a grain of salt.  I use Avira, which hasn't reported any problems with any DS updates.
  • adzanadzan Posts: 268
    edited June 2017
    You know what:
    Sigh. Norton Security 22.9.4.8 (The 2017 One) is paranoid, it deletes daz studio  .dll  files let right and centre because it feels like it, I keep having to report false positives to Semantic.
    Today during the DS 4.9.4 install it deleted the daz automatic uninstall exe from the temporary folder because it was Bad! and wasn't trusted by their reputation system.  Bad Daz  lol.   I've learnt to wait for Norton to grumble when installing DS or it would have messed up the installed and I wouldn't have been happy
    Post edited by adzan on
    I use Bitdefender and Malwarebytes (both paid) and it gave me no problems or messages.
    Laurie
    Laurie
    Thanks - that's encouraging me to update because I use the same combination (except I use the free BitDefender).
    edited June 2017
    Ahh - that's a pity. I was hoping for an update to ActivePose so the pinned parts don't keep jumping out of place. I use it for animations but I always have to pull the limbs back to where they were supposed to be pinned which is a huge waste of time. I never use drag-posing (PowerPose) - can't seem to get the hang of it and the pose usually ends up in a weird contortion so I stick to the parameter sliders.
    Post edited by marble on
    You know what:
    I'm not seeing this with a current version of Norton.
  • So why when I click on Upgrade and then dowload it just takes me to the product Library with no Upgrade listed?
