Show Us Your Iray Renders. Part V
13435373940100
  • Oso3DOso3D Posts: 15,118
    Not quite a taur, but along the same lines... drider.
    I'll put it here as a simple URL for the arachnophobes: http://willbear.deviantart.com/art/Drider-608725995
  • ebonartgalleryebonartgallery Posts: 273
    edited May 2016
    Rafmer said:
    This is my first iray render. I also started playing around with the emissive for the sphere primitive. I'd like to include something to put 'mist' right around it, or otherwise break up the obviously featureless sphere texture.
    Try the bloom filter in render settings. Increase threshold to about 8000-10000 and maybe reduce the two other settings if you need it.
    Well, that worked just as advertised!
    1024 x 1325 - 2M
    Post edited by ebonartgallery on
  • KnittingmommyKnittingmommy Posts: 8,191
    edited May 2016
    That looks much better with the bloom!  Uh, you might want to lift your figure up just a little as his shoe is currently stuck in the ground just a smidge.  Nice going, though, with your first Iray image!
    edit to add:  Overall, you did a great job!
    Post edited by Knittingmommy on
    I really like bloom. Yeah, with some work you can do it in post, but it saves enormous time to tweak it in render.
  • RafmerRafmer Posts: 564
    Great job! I really like it!
    Cool! Much better now. Glad it worked how you wanted it.
    edited May 2016
    Going on to another idea - I set up the stone on his necklace and the stone of the archway to be emissive, and added some shaders in... then noticed that there seems to be nothing past the archway. No sky, no nothing. I fiddled around with the various dome/sky stuff - before, it was set to 'sun/sky only' and about, oh, 9AM. So I tried with the default environment map and could see nothing except the same kind of blurred background you see here. Then I applied (or thought I'd applied) an HRD texture from HDR Outdoor Environments - um, maybe. I don't see the Environment Map change on the Render Settings, so... I'm uncertain of how to apply that thing.
    1024 x 1325 - 2M
  • kyoto kidkyoto kid Posts: 42,411
    edited May 2016
    And moar...
    (Original texture in trans color, surface texture from WTZ shader)
    ...looks like something our game group encountered on one of our recent dungeon crawls. Nearly took out half the party.
    Post edited by kyoto kid on
    And in my 'zany taurs' list... ELETAUR!
    It's not the recent elephant, older model, + elebeast.
    ..I like it.
    Usually you can find the HDR environments in render settings -> presets; doble clicking the HDR should change your render settings to dome and scene and use that HDR in the environment map. If not, click on the image of the environment map and browse to it yourself. Always make sure that Draw Dome is ON too.
  • 8eos88eos8 Posts: 170
    edited May 2016
    Don't you just hate it when your characters try to break the fourth wall......
    898 x 1069 - 1M
    Post edited by Chohole on
    edited May 2016
    Oh, now, that is just too cool!  Very nicely done!
  • nelsonsmithnelsonsmith Posts: 1,337
    My very first iray render (that I'm showing at least).  Not quite ready for prime time, as I'm still learning to master lighting and other aspects of the dials, but I can see that the concept will work.
    1124 x 720 - 550K
    That was weird.
    I was at Render Quality 10 and 73% convergence. Then thought ... yeah, maybe drop that. I dropped it to RQ 5... and convergence dropped to 60%.
    Um. wot?
    ...good job, and such a cutie too..
    That was weird.
    Um. wot?
    ...sounds like our streetcar. I'll look up at the tracking board and it says "arriving in 6 minutes", then look up again a couple minutes later and it reads "arriving in 9 minutes".  Must be some sort of spacetime error occurring.
    Nice work!!
  • D.RobinsonD.Robinson Posts: 283
    That was weird.
    Um. wot?
    Speaking of which what exactly does the Render quality setting do? I cant seem to find any real answer.
    Daniel
    Thanks! :D  Started off as a happy accident while I was panning the camera, then I adjusted the pose a bit
    edited May 2016
    Testing a new costume I recently bought. Materials look great with just applying the Iray Uber Base shader.
    834 x 1080 - 1M
    Post edited by Rafmer on
  • 3CPO3CPO Posts: 164
    Exploring the undersea realm...
    1452 x 916 - 621K
  • ToyenToyen Posts: 2,078
    My first custom sculpted head morph for G3F. Called her Lily : ) Skin textures are from Cailin by Raiya.
    Another test of my shader. Everything in here uses my shader, it's all procedurally generated patterns, no texture maps of any kind.
    1080 x 1080 - 2M
  • BobvanBobvan Posts: 2,653
    edited May 2016
    Nice stuff all *nudity*
    http://fav.me/da2uv0b
    Post edited by Bobvan on
  • zombietaggerungzombietaggerung Posts: 3,943
    edited May 2016
    Most of the intelligence community doesn't believe he exists. The ones that do call him the Winter Soldier. He's credited over two dozen assassinations in the last 50 years.
    G2M, kitbashed his outfit/weapons, mostly V4 & M4 stuff except the arm, that's for G2M I just retextured it.
    2000 x 3236 - 1M
    Post edited by zombietaggerung on
  • IvyIvy Posts: 7,165
    that is wicked .. Awesome render zombietaggerung
    Add to Anti-Banner
    Ah thank you! I'm glad you like it.  blushlaugh
    Very cool zombietaggerung!
    Thank you! :D
    edited May 2016
    For this one I changed all the surfaces to Iray in the purple/violet hues, then decided I liked it best in B&W LOL...
    1177 x 1080 - 931K
    Love the concept! Very creative!
