*Closed* RRRR Render Contest Summer 2024
Totte
The RRRR is back for another round!
This time the theme is.... No, no theme this time, just pull, setup and render.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over seven years until it needed a well deserved break. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won. No lucky bastards are in play now, but will be for the next run.
| Player | Current LBs |
| Luci45 | 2 |
| Totte | 1 |
| acb | 2 |
| katfeete | 1 |
| 1stbastion | 1 |
| katywhite | 1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Wednesday July 31, 2024, and will go on until Sunday September 22, 2024 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Elliandra is sponsoring with two items from her store
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 9 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
RRRR "As the story goes" (Saturday February 3, 2024, to Sunday March 31 2024 )
https://www.daz3d.com/forums/discussion/672471/rrrr-as-the-story-goes-render-contest-closed/
Entries thread:https://www.daz3d.com/forums/discussion/672466/rrrr-as-the-story-goes-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/683131/winners-announced-rrrr-as-the-story-goes-render-contest
RRRR "Picture or it didnt happen" (Friday April 19, 2024, to Sunday June 23, 2024)
https://www.daz3d.com/forums/discussion/683536/rrrr-picture-or-it-didn-t-happen-render-contest/
Entries thread: https://www.daz3d.com/forums/discussion/683531/rrrr-picture-or-it-didn-t-happen-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/695536/rrrr-picture-or-it-didn-t-happen-winners-announced
Pull #1
#5108 Gabriel Flipped Hair for Genesis 9 and 8 Male (#89942)
#3241 Lightning Bolts Vol. 1 (#70131)
#1787 Old Industrial Office Room (#44421)
#1086 Medieval Prison Room (#23784)
LB 1:2265 Warfare Poses (#51803)
Pull#1:
2234 Ferry Boat Poses
652 Brocade Iray Shaders - Roundabout
3793 MICK-Great Hall
6307 Umbrella Patio Table
6745 WorkBot (LB)
3697 Medieval Inn (LB)
I will participate in this one I promise!
I'm gonna try and participate! Hopefully life will not get in the way this time... lol. (hurries to update her list of items before she pulls)
Pull#1
tag:luci45#1
The Royal Children
Young Prince Richy gets stuck in the playhouse and is worried that faithful Robot Robby's help might be too heavy-handed.
6745 WorkBot (LB)
Also usedBig Time Tools
Fishtail Braids for Genesis
Micah Hair
Pirate for Genesis and Genesis 2 Male(s)
Adventurer for Genesis 2 Male(s
Sultry Hair for Genesis and Genesis 2 Females
Timothy HD for Michael 6
Grand Ballroom Dress for Genesis 2 Female(s)
Wolf King for Genesis 2 Male(s)
Peasant Dress for Genesis 2 Female(s)
@Luci45: You're off at a great start!
@luci #01. ROFL! Danger Prince Richie! Danger! Robbie the robot has a hammer and you are starting to look like a nail! good one
Thanks, Totte and Gopherus.
Pull #2
332 Army Vehicles
6200 Triple Moon Cottage and Props
1059 Colors for Summer Fun Hair
754 Captivating HD Faces and Bodies for Genesis 8 Female
5712 Sw French Quarter - Grocer'S Corner (LB)
5069 Sacred Barge (LB)
Tag: acb#01
Evil step mother being evil
"How dare you disturbing my TV show by lazily taking a break!"
Tag;Totte#01
Also Used:
KOO Matthieu for Genesis 8 Males + Sleuth Detective + The Firearm Pack
The Tentacle
Sewer1 (Light)
Neo City (Trashbag)
Nuclear Shelter (box)
Wheelchaor (Westpark)
The Fallen One HD for Genesis 8 Males
Scripts, Lights and Shaders used:
Invisi Lights
Skies of Economy
Iray Real Lights
The Paranormal Specialist
Dick Dunwoody, specialist in paranormal activities, was called out to the old asylum, The Priory of St Mary of Bethlehem, which was originally built when Henry III was king over England, in the year of the lord, 1247. When he opened the closed door to the very old section that had been closed for centuries, he saw more paranormal activities than he had ever seen in his whole life. He knew exactly what to do, run away and run fast.
nice one!
Don't forget to put your tag on it in the entries thread!
Thank you. Also for the reminder.
@acb #1. Another case of passive agressive. Doing nothing right in her step moms face. really ticking her off! well done!
@totte #1. knowing what to do when meeting the undead is what makes a specialist a specialist. An amateur might have tried recharging his cell phone. good one!
Thanks Gopherus for your comment.
Pull #2
#551 'Perfect 10' Standing Poses for Genesis 3 Female(s) (#22354)
#2888 Pilot Uniform Materials of WWII (#63559)
#3177 Deck Hand Hair for Genesis 3 and 8 Male(s) (#69329)
#3252 Frontier Outpost (#70311)
LB#1:#5542 Christmas Puzzle (#92856)
tag:luci45#2
Left Holding the Barge
Queen Hatcheksup and her funeral barge were dispaced in time and space by a vengeful priest's curse, resulting in being shrunken to Barbie doll size and popping up at various times and places for 4000 years. Anubis caught up with her at Witch Walda's home in New Orleans just as the elite US military unit for recovering anomolous arial objects was closing in. He wisked her through a portal to the Underworld, leaving a surprised Witch Walda holding the barge.
Used:
332 Army Vehicles
Also Used:
dForce H&C Pajamas Set for Genesis 8
Egyptian Outfit for Genesis 3 Male(s)
Pharaohs of the Sun for Genesis Female
PTF Portals
Army Uniform for Genesis 3 Male(s) and Genesis 2 Male(s)
Persian Rug Collection
Skinchangers + HFS Fantasy Shapes for Genesis 3 Male(s)
Thanks, Gopherus
And... Pull#2:
acb#1: Nice one! Extra LBs can make you very creative.
totte#2: That is some very para-paranormal activity. If I were Dirk, I'd think about a career change.
#3
1900 Dynamic Destruction Vol 1
5289 Shanty Town
3708 Medieval 2 (Rendo)
5763 Take A Seat Catty Poses For Catty 8.1 And Genesis 8.1 Female
3636 Mars Rover (LB)
3608 Manly for Gianni 6 (LB)
Tag: acb#02
Lighting the Float
They gathered enogh of the yellow lightning bugs to light their float for the upcoming parade. But of course, they still needed to find the blue and red ones - presumably at monoliths with blue or red glowing holes at the top... Maybe they could change the color of the monolith to get different bugs? That's how it is in every other adventure game, right?
Pull#03:
tag:luci45#3
Black Market Commotion
"Zeke, Was that Billy's wearhouse again?"
"Yup. It sure was. I wonder what he was doin' this time."
5289 Shanty Town
3636 Mars Rover
Also Used
Catty 8.1
AJC 2020's Modern Realness Outfit for Genesis 8 and 8.1 Females
dForce Walking Dangerously Outfit for Genesis 8 Female(s)
Horror Survivors: Marius clothes
M3D Western Outfit, Hat/Hair, and Weapon for Genesis 8 and 8.1 Female
VDB Apocalypse
Milen Hair
Bone Minion for Genesis 8 and 8.1 Poses for Genesis 2
Pull #4
85 A Quiet Repose
5387 Sleep Under The Stars
5903 The Deck Collection
323 Armor Rings
1635 dForce Sunday Best Outfit for Genesis 8 Female(s) (LB)
4759 Real Feel Double Layered T-Shirt for Genesis (LB)
Thanks @Luci45 for your comment. (you ment #1 I guess, this is #2)
@Luci45 : #2 That's a lot going on there, love it!
@acb : #2 Lol, You've played too many computer games, nice one!
@Luci45 : #3 Wow, what a scene! And poor Billy, he seems to be unlucky over and over.
Totte:#02
Also used:
LY Keinan HD 8.1 + Pilot Uniform of WWII + Standing Conversation Poses
Lekkulion for Genesis 3 Females + Rough Rider
Zellarian for Nix 8 + SciFI Settler + Standing Conversation Poses
Whistling Death
Creepy Curious
Everyday household items
Hover Furniture (Table)
Vintage Tech
Vintage Film Props
Nautical Whimsey Vol 1
SciFi Mini Tank Bot
SciFi Roller Bot
Scripts, lights and shaders used:
Skies of economy
The Wormhole Portal
Marine Pilot, Major Jessica B. Caldwell, was flying a routine patrol mission over Iwo Jima in late April, 1945, when a weird lightning storm hit her plane and when she looked down, the world looked very different. She successfully landed, and when she exited the plane outside some weird aerodrome, two strange looking figures appeared with a floating table with stuff on it. One of the said: – "Welcome to our universe. We asked for help from the ancients, and they sent us these items, and you. Solve the riddle, and we can bring down the evil empire."
Major Caldwell looked at the items and thought what am I experiencing right now?
@Totte: #2 What she's experiencing right now is an adventure game. That's what it is! I sense a hidden theme
But I hope she doesn't combine the lighthouse with the plunger. That could make a Dalek.
Thanks @acb!
You're right I guess, you did an adventure game, Luci seems to do one too, where the player keeps mixing the wrong ingredients and burns, and then this, I think the "puzzle" is what needs to be solved, the rest of the items are just red herrings, to confuse the player. On a side note: I participated in an "Escape Room" event last weekend, that's where I did get the idea of a lot of useless red herring clues.... (No, we did not succeed)
Pull#3
#231 DM's Folly DS (#21601)
#2446 ExpansiveAPESuit for Genesis 8 Female(s) Textures (#54809)
#1818 Sci-Fi Head Gear for Genesis 3 (#45507)
#4856 Tekknika: Cryo Chambers (Rendo)
LB1:3299 Servant of The Yellow King Outfit for Bullwarg HD and Genesis 8 Male (#70911)
Why does this also smell Scifi Adventure with a touch of space cowboys?
Tag: Totte:#03
Also used:
Bullwarg HD for Genesis 8 Male
Victoria 9 + ExpansiveAPESuit
Karen 7 + ExoSuit + Elector Hair
Hold 8 HD + Beard Boss + BW Kwame Outfit
Desert Depression
Greeble City Blocks 4
Future City Scape City Blocks 01
MJF Hedging anf Foliage Vol 1
LowPi Bundle
Scripts, Shaders and Lights used:
RSSY 3Delight2Iray
Legacy Set Converter
Advanced Material Converter
MMX Resource Saver Shaders Collection 2
HedgeMaker
Ground Shaders
Skies of Economy
The Last Hipster
To solve the riddle, Victoria and Karen needed to find the answer to a question, a question that only one of the last Hipster could answer. The last hipster was the only surviving hipster from the great purge in 2347, and have been kept alive even since, together with three clones, just in case. The question they needed the answer to was:
- "How to you make a perfect vegan chai expresso latte with almond and soy milk?"
I have been struggling with my last pull. So aweful. I decided to look for some inspiration here and wow, I got some! I love all the crazy surrreal game stuff, Totte and acb! I especially like Totte #3.
Thanks!
What I do when I end up in an "Artist's block" with a pull, is that I setup the different parts pulled (fix mats, check what they are), then I toss everything into a scene and just move stuff around to see if something pops up, usually it works, but 've had a few pulls that has been imposssible, so then I just do something with them and move on, knowing "this wont get any attention", but at least I can ake a new pull.
