* Closed * RRRR "Picture, or it didn't happen" Render Contest
Totte
The RRRR is back for another round!
This time the theme is "Picture, or it didn't happen". It's a theme with endless possibilities, just render something that the render proves it really happened.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over seven years until it needed a well deserved break. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won. No lucky bastards are in play now, but will be for the next run.
Current Lucky Bastards Standings:
| Player | LB count |
| Lucy45 | 1 |
| Totte | 1 |
| acb | 1 |
| aprilshowers2065 | 1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Friday April 19, 2024, and will go on all over the holidays until Sunday June 23, 2024 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Elliandra is sponsoring with two items from her store
acb has sponsored with a $20 DAZ GC.
Luci45 has sponsored with a $25 DAZ GC.
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 12 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
RRRR "As the story goes" (Saturday February 3, 2024, to Sunday March 31 2024 )
https://www.daz3d.com/forums/discussion/672471/rrrr-as-the-story-goes-render-contest-closed/
Entries thread:https://www.daz3d.com/forums/discussion/672466/rrrr-as-the-story-goes-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/683131/winners-announced-rrrr-as-the-story-goes-render-contest
Pull #1
#3382 Khemsit 8 (#72473)
#425 Metal and Gemstones (#22072)
#967 Window Seat (#23470)
#4767 Roadnames BC (Rendo)
LB #2352 Abraham Hair and Mustache for Genesis 8 Male(s) (#52839)
Pull#1:
Pull #1:
5545 Steam Punk Hide Away
3419 Lisa's Botanicals - Hanging Plants
6466 Vintage Frames
5567 Stella Hair for Genesis 3 and 8 Female(s)
2119 Extravagance for Baroque Grandeur (LB)
Totte#01
Also Used:
Parkside Freight Boxcar
Parkside P Car tracks
Home One (Ceiling lamp)
Floyd HD for Genesis 8 Males + Casual Craze + Hand Craft for Casual Craze
Gentlemen's Library
dForce Urban Adventure Outfit + Capri Hair + Z What a Diva Poses
Gentlemen's club (table) + RW Classic Chess
Skies of Economy
Maryam for Genesis + Bolt Outfit + Chaerine Frizz Hair + Z Fun Summertime Poses
Shaders and Scripts Used:
Iray Real Lights
Code 66 Toolbox Vol 5 (Lineup Between)
Ground Shaders
Expression Randomizer for Genesis 9
FilterForge
A game of chess
Nadine always shows the old and wrinkled photo from when she and her friend Maryam waited for a delayed train at the trainstation, and Nadine beat Albert Einstein in a game of chess.
Good one, Totte! I think Eistein was better at 3D chess.
tag: luci45 #1
Josie's Spy Camera
Josie's friends did not believe her tales about her Uncle Bob's strange island home. So she took her tiny spy camera with her (this being in the times before cell phones.) Maybe next time...
6466 Vintage Frames
Also used:
Cyber GM8
Lil Scrap Boy
Coated Machine Metal Iray Shaders - MR
DD PBR Rock Shaders for Iray Vol 1
Teen Josie 8
Growing Up for Genesis 8 Female(s)
Ghost Light Kit
Slouchy Sweater
Threads Pants and Textures
FMA Over the Sea HDRIs and Skyspheres
@Luci45: Uncle Bob seems to have a very cosy little island... well done!
Pull #2
#1995 Bolnnar the Dwarf for Genesis 8 Male(s) (#48331)
#4017 Medieval Village Mansions Construction Set (#85318)
#3748 dForce Charming Ever After Outfit Textures (#82459)
#777 Noctem Sanguinis for Arabella 7 (#22937)
LB #2224 Super Nova Capital Ship (#51215)
Oh, that Lucky Bastard really screwed up this pull, on the other hand, I did watch "Rebel Moon".....
tag:luci45#2
The Mud House Roof
When climate change brought historical massive rains to the dry climate where Kesh Kuth lived, he bought a new rain roof from the Bix Corp. The Utra Dry Roof was guaranteed to prevent any and all flooding in his home. With the first storm his home was flooded with more rain then fell outside. Kesh called the company to complain and they sent a representative to say Bix Corp would not pay for damages. Kesh, anticipating the need for litigation, brought out his guarantee and read the terms to her, as his two sons recorded the conversation.
806 Casual Long Hair -2
3899 Mongolian Beauty - HD Faces and Morphs -2
1811 Dream Home Eclectic Roof Decor
3992 Mud House
4114 Noble Nomad - 3
Also Used
Heath Hair for Genesis 3 Male(s) & Female(s)
Sword of Time shirt
Summer Pleats for Neat Pleats blouse
Rain Boots for Genesis 2, 3 and 8 Female(s)
April Showers for Genesis Female umbrella
Everyday Wardrobe for Genesis 2 Female(s) Jeans and Shirt jeans
Urban Survivors HD for Genesis 2 vest
Mei Lin 6
Lee 7 texture
HFS Fantasy Shapes for Genesis 3 Male(s)
Viking Hair and Beard for Genesis 3 and 8 Male(s) beard
Short Mohawk Hair for Genesis 3 and 8 Male(s)
Totte#02
Also Used:
Tactical Assault + Bollywood Poses
Merlin 8.1 + Charming Ever After Outfit + Nikon Hair and Beard
Arabella 7 + Mechanic Outfit + dForce Electro Hair
Mesa Desert
Medieval Ballistae
MAGMA-930 (missile warhead)
Sci-Fi Settlement Construction Set
Oso Ground War VDBs
Scripts and Shaders used:
Ground Shaders
Render Architecture
Lucky Shot
The outer rim mining moon Gamush-IX had been under blockade by the space empire for weeks. Mayor Mazzur came up with an idea how to trick the advanced AI missile defense system on the Super Nova Class Imperial Battleship, a medieval ballista without any guidenace system or thrust engines. They built two ballistae and placed a tactical warhread at the tip of each bolt. They only needed one shot, former Gunnery Sergeant Bolnnar scored a hit on his first try.
Pull #3
743 Capsces Tough as Nails Poses and Expressions for Gianni 7
1724 Divinity Skies Prophecy
3321 Lani Hair for Genesis 3 Female(s)
5373 Skyterminal 5
2061 EsidorHair
OK, a very lucky pull, with 2 sky items. I feel lucky when I don't get both an interior and an exterior.
@Luci45: Thanks for your comment
@Luci45 #2: So typical, things never works as expected
Alright here we go again,
#1265 - Meck9
#3048 - Vintage Style Safe
#4003 - CP - Winter Circlet
#5549 - Toon Amy for Genesis (Character/Hair)
tag: luci45 #3
The Princess Escapes
Fleeing from her impending arranged wedding, Princess Mstalia headed for the spaceport and freedom. Then her husband-to-be, Zarnock the Great, showed up via a magic portal and unsuccessfully tried to convince her to return home and marry him.
Used:
5373 Skyterminal 5
2061 EsidorHair
Also Used
ATVE Mods - Janus and Desert Coyote
Skies of iRadiance - Sunny Sky HDRIs for Iray
Rough Rider for Genesis 3 Female(s)
Uber+ Iray Sheer & Silky
Marionette for Genesis 3 Female(s) boots
dForce Hand of Helios Outfit for Genesis 8 Male(s)
MMX Resource Saver Shaders Collection 5 for Iray
PTF Portals
Totte#02 - Great shot and great angle. Looks believable.
Welcome back, FirstBastion !
tag: luci45 #4:
1743 Domestic Defence
2318 Genesis 3 Female Body Morphs
6301 Ultratrees - Realistic Tree System
2909 House Mouse'S Poses
4454 Pillars And Rays Photoshoot
tag:luci45#4
It Wasn't A Dream, Really
"I saw a human here, really. She had a funny-looking weapon and was snarling. She wanted to hurt us. You and Bert were there. Don't you remember?"
Used:
Also Used
i13 On My Own Sleepwear for the Genesis 3 Female(s)
Make Me Itsy Bitsy Baby Props and Shaders
MountainScapes Backdrops Volume 2: Snow Edition
Poppy Dance
On a hill right outside the city they found a field of poppies ... and danced.
Also used:
Modern Dance Troupe Poses for Genesis 8
Crazy Times for Genesis 8 Female
Green Valley
UltraScatterPro
Well, that pull didn't speak to me at all. I hope the next one will be more communicative.
@Luci45:;
Luci45#03: You also made a wedding runaaway, great one, I hope Princess Mstalia got away safely!
Luci45#04: That's a lovely one, a dream or a nightmare....
@acb:
acb#01: I got some "gone with the wind" vibes from that one, great entry!
Oooo, I didn't know the RRRR had started up again! It took me a couple of weeks, but I managed to pull an entry together...
Pull #1:
katfeete#01 -- Bet You Can't
On the bright side, Shea thought as he tried to get his breath back, while he had so lost the bet, his friends had video of him trying to "Pin The Tail On the Black Cat", and that counted for something, right? And maybe if he watched it he could figure out how he got from riding his board to down here....
Also used:
Dark Materials
Dark Raven
HFS More Than Human (DarioFish)
Future Wilderness Propellor Skate
Hermes Hair
Vandal Outfit
Cargo Shorts(SdeB freebie)
Long Tail (AprilYSH freebie)
@katfeete: katfeete#01: Nice one! Never mess with the black cat, old jungle saying.
Pull #3
#1157 FangTastic for Genesis 3 Female(s) (#24028)
#2404 Colors for Wicker Bob (#53593)
#1757 The Fallen One HD for Genesis 3 Male (#42395)
#298 i13 Underground Battle Arena (#21764)
LB1: #3071 dForce Dark Lore Outfit Textures (#66895)
acb#1 - It came out pretty well in spite of not speaking to you. I've done a lot of those.
katfeete#1 LOL, quite a pull. I like Shea's friends reactions. Nice render!
Thanks, Totte. I didn't know where that runaway bride idea came from. It looks like she also could use some help from a wandering mercenary.
Pull#5
5518 Spring Flowering Shrubs - Golden Forsythia
3156 Jepe's Cinematic4 Poses and Props for Michael 8
1757 Double Bass and Poses for G8.1
327 Army Uniform Textures for Genesis 3 Male(s) and Genesis 2 Male(s)
6448 Victorian Garden Cold Frames and Edging Tiles
aprilshowers2065#1
Well, this was an interesting pull...
18 dForce Banana Suit Outfit for Genesis 9
293 Tane The Old Deer for Daz Horse 2
309 6 Wheels Sci-Fi Truck
576 i13 Manga Style
1142 Low Resolution Tropical Trees and Shrubs
For the Glory of the Bananaland!
The invaders may have the technological advantage, but that wouldn't stop Captain Brodin or his trusty Lieutenant Elaria! Just because they seem to be headed in the opposite direction of the enemy... well that's all just part of their brilliant tactic!
Totte #1 Nice, like the old photo effect :)
luci45 #1 She'd get some very interesting pictures there for sure ;)
luci45 #2 So typical... they always try to get out of paying for the
Totte #2 Haha, nice aiming ;)
luci45 #3 Keep running Mstalia! :O
luci45 #4 That does have a very dreamlike look for something that wasn't a dream ;)
acb #1 Looks like they're having fun :)
katfeete #1 Well that's a situation and a half XD They're expressions...
Luci45 and aprilshowers2065, thanks for your comments!
@aprilshowers2065: Made me think of the classic Oddball in Kelly's Heroes, who had made their go faster backwarrs, to get out of trouble faster than they got into, fun one!
Totte#03
Also Used:
Eva 7 + Mischief outfit + Wildling hair
Greek God Outfit
Assassin 8.1 + dForce Dark Lore Outfit + Curly hair and facial hair for genesis 8 male + Long and full beard for genesis 8 male + Protector for him sword + European Daggers
Freja 8 + Wicker Bob Hair + Barbarian Armour + Historical Weapons
LowPi Crowd Generation Bundle
Scripts and Shades used:
Dramatik Skies HDRI
Invisi lights
The Illegal Gladiator Games
During an illegal gladiator game with hight stakes betting, held somewhere at an undisclosed location outside London, a reporter with a hidden camera took a picture with his phone and uploaded it to the cloud, before his phone smashed and he was removed.
Thank you all for the comments!
Pull#2:
... that seems to be better ... I can at least hear some mumbling
Guys. Scrolling this thread Bitdefender detected something about thsunsetgrillcomic, probably the SSL certificate, so take a look.
Ah, yeah, that's probably me. I dimly remember Dreamhost screwed something up with reissuing the security certs last year -- they're always doing something like that -- but between some personal losses, a run of creative burnout, and just general exhaustion, I haven't updated the site in three years and I haven't had a chance to look at it. I'll drop the link signature until I get a chance to poke around and find out what Dreamhost wants THIS time.
katywhite:#1
Title: I thought it was art...
Caption: After seeing so many different strange art pieces in the gallery, including functional 'futuristic cars', when a toddler managed to drive one of those cars in the gallery, Judy thought the falling wall and the panicking man was just another art piece.
Items I Pulled:
@katywhite: katywhite:#1: I love this, such a creative use of Make Art, you can always trust a toddler to make things happen!
