Remove pose limits?
alisa53
in The Commons
Hey guys - is there a utility or some other way to allow disabling pose limits, so the you can bend or twist farther?
Every slider in Daz has a small gear icon on the top right.
Click on that > Parameter Settings > Use Limits.
If it's ticked then the limits are those defined by the person who created that slider.
You can change the limits by modifying the Min. and Max values. Or totally disable limits by unticking "Use Limits".
To remove all limits : Right Click on the object in the scene tab > Select > Select Children
Then in the viewport, left click the small icon that looks like a human, next to your pivot point > Limits Off (Rotation)
Searching forums often helps more than a new thread ;)
https://www.daz3d.com/forums/discussion/276311/removing-limits
https://forum.daz3d.com/forums/discussion/388676/quick-question-about-pose-limitations
https://www.daz3d.com/forums/discussion/483411/how-do-i-on-off-limits-on-everything-at-one-time
https://www.daz3d.com/forums/discussion/388676/quick-question-about-pose-limitations
etc. and a few hundred others on the subject.
Edit>Figure>Limits>Limits Off (Rotation)
