Quick Question about pose limitations
DDCreateDDCreate Posts: 1,421
Is there a way to select a character and turn off all pose limits or do you have to go joint by joint? Just wondered if I was doing things the hard way.
Thanks!
  • DDCreateDDCreate Posts: 1,421
    Sorry to bump this. Just wanted to give it one more shot.
  • QuixotryQuixotry Posts: 919
    If you want to turn off limits on everything (this will include eyes and tongue, which usually don't need limits off) right-click on your figure in the Scene tab and use Expand All from the little menu to make all the bones show in the tab. Then select all of them at once (not the eyelashes if you're using G8) and look in the viewport for the little symbol that looks like a human figure. Right-click on that and select Limits Off from the menu. That should turn the limits off for everything you have selected in the Scene tab. To do that with a bit more control, you can just select the character's bones in batches - for example, select all the leg bones, or all the arm bones, or all the torso and neck bones - and follow the same process. Then you don't need to remember to go back and set limits to on for the eyes or tongue. To turn limits back on, it's the same process. Just select everything you need in the Scene tab and then right-click the symbol and pick Limits On.
    I hope that helps.
    804 x 644 - 561K
    Awesome! Thanks Quixotry, I appreciate it!
