Removing limits
Choppski
Is there a quick way to remove limits from an entire genesis figure or from a specific section (i.e., all chest morphs, all head morphs)?
Choppski
do it in start of character creation (load)
load your character, in scene tab list,, "EXPAND ALL",, "select all" and via menu edit > figure, > LIMITS, > LIMIT OFF (rotation)
i suggest to SAVE after limit off,
at "F3" you can found the command in parameters and apply in your top "toolbar"
@ cm152335
You don't have to expand all - right-click on the selection in the Scene pane and from the menu choose Select > Select Children this selects all sub nodes. If you don't want the wearables to be included select the figures hip first.
If you just want to turn off joint limits for example on the arms, select both collar bones and right-click Select Children, then turn limits off.
@ Choppski
Limit Off (rotation) as it is called only turns off rotation limits on the joints. You asked for to turn off other morph properties that can be done with the Parameters pane in Edit Mode (right-click and choose from the menu). Now you can select all the morphs you want to turn limits off with the default Ctrl-click and/or Shift-click, then right-click again and choose Limits > Disable Limits on Selected Properties. But I don't recoment you to use morphs without limits I rather would change the min/max limits range - that also can be changed for all selected properties at once in the section Set > Min/Max Limits of the right click menu.
I appreciate the help. I think it may be easiest to create some shaping presets that turn off ones that I frequently need turned off.
I just searched for MCasual's scripts and here I found some that can make things easier.
I'm not shure of that limits get saved in shaping presets, scene subsets will do.
