DAZ Studio 4.9 Pro, General Release, Now Available!
Daz 3D is pleased to announce Daz Studio 4.9 Pro General Release!
- Version: 4.9.0.63
- Date: 2016-1-21
Highlight Videos:
New Features:
See the New Features page, this post, and the Change Log for more detailed information.
Important Notes:
!! IT IS HIGHLY RECOMMENDED THAT YOU BACKUP YOUR CONTENT DATABASE IN DAZ STUDIO 4.8 BEFORE LAUNCHING DAZ STUDIO 4.9 !!
How do I backup my User Data in Daz Studio?
Content Database / Metadata related
- The first time you launch Daz Studio 4.9, any data that exists in the content database is migrated so that it can be used in Daz Studio 4.9.
- The amount of time the database migration operation takes is proportional to the amount of data to be migrated.
- The database migration operation does not delete the data that it migrates from the previous location so that it remains accessible by earlier versions and other applications, such as Carrara.
- Daz Studio 4.9 uses the same PostgreSQL database as Daz Studio 4.6 and later, and/or other applications, such as Carrara.
- A portion of the data contained within the database is shared amongst versions but not entirely. For example:
- Creating a category in either Daz Studio 4.9 or 4.8 will cause that category to exist in the other version
- Assigning a file to that category in Daz Studio 4.9 will NOT cause that file to be assigned to that category in Daz Studio 4.8
- Assigning a file to that category in Daz Studio 4.8 WILL cause the file to be assigned to the category in Daz Studio 4.9
- Reseting the database in any version of Daz Studio that uses PostgreSQL (4.6 or later) will purge all of data in the database, including any data that may be used by earlier versions or other applications, such as Carrara.
- After the initial migration operation, edited metadata in Daz Studio 4.8 will not be migrated to Daz Studio 4.9.
- A workaround is to export User Data from Daz Studio 4.8 and reimport User Data in Daz Studio 4.9.
NVIDIA Iray related
- Fixes made to the implementation of Sub Surface Scattering (SSS) in the NVIDIA Iray renderer affect materials which have "Translucency Weight" active—not set to 0. This manifests in skin tones appearing more blue than they do in 4.8. A quick adjustment that can be made during the BETA phase is to adjust the "SSS Reflectance Tint" from a light blue to a light yellow—R: 1.00, G: 0.88, B: 0.67. Adjust this value to your liking.
- After the BETA phase, Daz 3D products will be updated to include this change.
- The Mac version now requires OS X 10.7 or later.
Frequently Asked Questions:
- How do I backup my User Data in Daz Studio?
- General Release, Public Build, BETA... What is the difference?
- Has the Content Management Service (CMS) changed?
- What is the Application Improvement Program about?
- Have the content packages been updated too?
- How do I get the latest version?
- Can I have a General Release and a BETA installed at the same time?
- What about the plugins I have?
- What is new in Daz Studio 4.9? Do I need to update my copy?
- Is there any documentation?
Frequently Asked Daz Connect Questions:
- What is Daz Connect?
- What are the goals of Daz Connect?
- How do I get my purchased products now?
- How can I get new products through Daz Connect?
- Are all products Daz Connect ready?
- Will the products I already own keep working?
- Will products from stores other than Daz 3D keep working?
- Can I use products installed through Daz Connect with other software?
- Does this update make it easier to find content I can use with Auto-Fit in Smart Content?
- Can I use the Content Library pane with Daz Connect?
- Does Daz Studio 4.9 require me to use Daz Connect?
- Does Daz Studio 4.9 require me to be online to use Daz Connect installed content?
- I use my content on multiple computers. Can I still do that?
- I have multiple people in my household who share content with each other. Can we still do that?
- Is the encryption associated with Daz Connect essentially Digital Rights Management (DRM)?
- Can I copy products installed using Daz Connect from one computer to another?
- I like to move files around on disk to organize them differently. Can I still do that?
- What will happen with the content already on my hard drive(s)?
- What will happen to my custom metadata?
- Can I still custom sort my files?
- If the content is stored encrypted, how do I reinitialize morphs?
- Will Daz Install Manager and Daz Connect work side by side? Can I choose one or the other?
- Do I have to re-download all of my products?
- Does having the Daz Connect service mean that all content will finally be Smart Content capable?
- Does Daz Connect work with plugins?
- Will my saved scenes also be encrypted?
- How do I add content that I have created myself to Daz Studio?
- What happens to my Bryce and Carrara content?
- Does Daz Connect support 32-bit operating systems?
- Will this update work with products like ZoneAlarm or other software firewalls?
- Will this update eliminate the Hexagon, Bryce, GoZ, or Photoshop bridges?
- Will the DSON Importer for Poser plugin work with products installed using Daz Connect?
- Will this update keep zip packages on my computer like Daz Install Manager does?
- Is there a reason to upgrade to 4.9 if I do not plan to use Daz Connect?
- How do I install Daz Connect products using Offline Packages?
Public Beta Threads:
Previous General Release:
Post edited by rbtwhiz on
Daz Studio 4.9 resolves many issues, and implements many improvements, since the 4.8.0.59 General Release. More detail on specific fixes/changes/improvements can be found in the Change Log, which can be viewed online within the Documentation Center portion of our site. All new downloads of the Daz Studio 4.x Pro product (SKU: 13176) will be of this version.
* "Export Product Metadata..." options include:
** "More Information..." options include:
Has the NVIDIA Iray renderer been updated?
Yes, it has.
Iray 2015.3.6, build 246000.9999
Added and Changed Features
Fixed Bugs
See Also
Iray 2015.3.5, build 246000.9245
Fixed Bugs
Iray 2015.3.4, build 246000.8334
Fixed Bugs
Iray 2015.3.3, build 246000.7491
Fixed Bugs
slots has been fixed.
have been fixed.
parameter is not array typed.
Iray 2015.3.2, build 246000.4498
Fixed Bugs
Iray 2015.3.1, build 246000.3782
Fixed Bugs
Iray 2015.3, build 246000.3341
Fixed Bugs
Iray 2015.3 beta, build 246000.1253
Fixed Bugs
Iray 2015.2.1, build 243400.2118
Fixed Bugs
Iray 2015.2, build 243400.1151
Fixed Bugs
For instance:
The compiler erroneously assumed, that the default case has a reachable exit, hence code after the switch is not dead.
When base::blend color layers() was used in a jitted expression, the modes color layer hue and color layer saturation failed. This has been fixed.
where the compiler complains that a T[] array cannot be transformed into a uniform T[] array.
Yes, there is. And we're actively working on more.
Check out the User Guide and QuickStart Guide that we've posted in the DAZ Studio 4.x Documentation section.
The Reference Guide is also in the process of being populated/updated—updates will be posted as they are completed.
*Note: Some pages are still being built. If you see "permission denied" for a page, that page is not live yet.
So it seems that 4.9 is all about DAZ Connect (which makes me feel very uneasy) and iRay, which I don't use because I don't have the right GPU. I really can't see any reason to upgrade.
Hence why I will have a back up of my content in case i can simply revert back. I am curious have they resolved where iray starts from scratch when making an adjustment....
I'm not sure that I can explain exactly what makes me feel uneasy - especially after reading all the promotion notes obviously written to put our minds at ease. That in itself makes me wonder why they need to put our minds at ease. When I look at DAZ Connect I see iTunes. I love my Mac but i hate iTunes. I love DAZ Studio but ...
Well, if you can love your Mac that comes from a company that refuse to follow any standard in existence unless they have to (html5) or they own it (quicktime), I don't see why you should have a problems with DS.
We are trying to be very upfront and honest about everything, which I understand could be quite unnerving compared to what you are probably used to. I apologize for not attempting to sneak something horrible through the fine print :). The general belief around the office is although this may seem scary to some the fact is that the truth is much less scary than anything imagined.
I don't have a problem with DS. I said I love it, didn't I? I don't like having the software I use becoming a marketing tool rather than a creative tool. DS 4.9 seems to be all about product sales and there is little else that separates it from 4.8 if you take the product aspect out of the picture.
I prefer the experience of a Mac compared to Windows but I don't like many of the Apple marketing decisions and try to avoid their control freakery wherever possible. I don't own an iPad or an iPhone or an Apple Watch or TV. I have perfectly good alternatives to all of those which happily integrate with my Mac. I used the iTunes example as a comparison in the way product is promoted and sold via the iTunes player. It is difficult to use iTunes to the full without being connected to the store.
I have some DAZ scripts which I have made.
IN ds 4.8, I could run these sciripts.dsa from smart content.
Scripts/Myname/smooth Settings category.
I already exported and re-import user meta-data.(which exported from 4.8) to ds 4.9 with off line.
but I can not find these scripts in smart contents.
Though there are all scripts in contet library, which I made and located before.
Then how I could add categories about these scripts,. for smart contents?
Now I can only find scirpts which offered as product, ( with product meta-data)
then I tried to make original product meta-data as same as before. (gather these scripts as my hand made scripts product,
then categorize etc,)
but there seems no way, to make new "product" about my original files.
anyway, How Can I use these scirpts as smart contents? show me guide or documents please.
Even though I add new category for these dsa files, in content library ,
the content library >categories not show these user made files. ,,
then I could not add new category for smart contents too. what have changed about these user-hand made files category in ds 4.9?
I really need clear documents, to make new category for user-made files, for product version ds 4.9.
Something is causing me to crash at random when changing materials that have Iray presets. I've been testing with the Alphakini and the Dark Storm outfits. I can change 3Delight materials all day, but Iray results in studio not responding and I have to force quit. I've tried in both texture shaded and iray draw styles.
Seems to happen in the beta version of 4.9 as well as the release version. I haven't had many items that came with Iray presets so I haven't noticed it prior to now (recently bought some stuff in the sale, which do have proper Iray presets).
/edit
I took a look at my preferences and changed some things and one of these changes seems to have fixed it. I turned display optimization to best (previously none), set texture resources to quality (was previously 1 notch away from performance), and turned on pixel buffer and cranked it to 2kx2k.
So far so good.
I just hit the X box on top of the initial log-in window and was back to work like nothing had happened.
I was really happy that 4.9 loaded up into file tree view, just as I had left it in 4.8.
All of my libraries are intact.
Even bought and downloaded a couple of new products to be sure.
DIM and away I went.
Thanks for that. ;)
Please explain when it happens, e.g. does it happen when you try to render using Iray?
Can I have Daz 4.8 and 4.9 installed at the same time?
Not if they are both General Release versions.
By updating to 4.9 I lost all my custom categories. That sucks big time since I just finished categorizing many gb of content in a way that is logical and use-friendly to me (contrary to the DAZ way of categorizing). I made a user-data backup before upgrading. I re-imported the user-data. Still my custom categories do not show up! I REALLY DO WANT THEM BACK!!!! Can anyone here tell me how to get them back? Will they return if I reinstall 4.8?
http://www.daz3d.com/forums/discussion/69753/4-9-categories#latest
same here
My first sentence, when changing materials using Iray presets. Garment is selected in the scene tab, out of habit I make sure the surfaces are selected as well, double click the preset and wheeee not responding. It was something to do with my interface options as once I changed those the issue disappeared (see my initial edit).
I have an entire hard drive dedicated to mgt runtime, very custom set up. Auto-install WILL NOT work. If 4.9 doesn't work with an existing runtime, then i won't be upgrading. However, the real question of the day, is whether product downloads will still be available as a zip files. If not, then you lost me as a customer .
Just a heads up.... if you download the 4.9 release via DIM, your downloaded version of 4.8 will be overwritten, in other words, it will disappear. So make a backup of your 4.8 versions before you download 4.9 if you want to roll back to that version.
