MatineeFX - Post Processing for Daz Studio 4 and 6 (Commercial)
StonemasonStonemason Posts: 1,275
edited October 12 in The Commons
MatineeFX is out now , A bit of a change from my usual environments. this came about as i wanted a way to automate working with Daz Studio Iray canvasses, in particular the depth/distance canvas which I use for adding depth aware haze to scenes, and wanting cool features like lens flares and colour grading
It lets you keep working on an image after the render has finished, trying different looks without having to render the scene again.
There’s colour grading, depth aware haze and atmospheric perspective, halation,bloom, anamorphic glare, lens flares, light leaks, film grain, vignette and chromatic aberration and more!...for depth of field You can click on the part of the image you want in focus and adjust the depth of field from there.
when rendering with MFX it uses canvasses to help with the post processing effects like dof and atmospherics,
There's also a bunch of presets to get you started, and you can save your own looks too. The split view is handy for seeing how far you’ve taken things compared with the original.flip view to check composition,full screen view for a better look at the image.
I've added a few examples below. It works with Daz Studio 4 and 6 on Windows.
https://www.daz3d.com/matineefx
Bonus points if anyone finds a couple of the hidden easter eggs
Post edited by Stonemason on
  • GhostofMacbethGhostofMacbeth Posts: 1,777
    Looks great
  • Awesome! I'm very interested in this.
  • ArtiniArtini Posts: 10,974
    Thank you for MatineeFX and creating this thread.
    It was the fastest decision to purchase the item made by you.
    All the best. Hope you will share more tips about its usage.
    edited October 13
    Just wonder what is the minimum version of Daz Studio 4 required for MatineeFX to work?
    I am using Daz Studio version 4.24.0.3 and MatineeFX does not appear in Render menu.
    Great that it works in DS6.
    Post edited by Artini on
    I like, how MatineeFX improves the render.
    Used https://www.daz3d.com/dforce-cb-mollie-mae-outfit-for-genesis-8-females-bundle
    on https://www.daz3d.com/lynelle-for-genesis-8-female-and-hollywood-mansion
    Render DS6
    Edited with MatineeFX https://www.daz3d.com/matineefx
    Used preset Three-Strip Hollywood
  • beachlegsbeachlegs Posts: 532
    This looks awesome, I will in time buy it :)
  • StonemasonStonemason Posts: 1,275
    It shuld work fine in 4.24.
    In DS4, could you open Help > About Installed Plugins and look for MatineeFX? If it’s listed, select it and post a screenshot showing its status and any error message.
    Also, did you run INSTALL_MATINEEFX.bat from the DS4 package as well? Each Studio version needs its own MatineeFX installation.
    This thread has solutions to install issues people may be having https://www.daz3d.com/forums/discussion/772721/matineefx-is-not-working#latest
  • adam_fe6a705dadam_fe6a705d Posts: 15
    edited 1:08AM
    Heya, StoneMason! Love your stuff and hoping to be able to give this a shot. I'm running 4.24.0.3. Plugin shows as installed when I look at Help > Installed Plugins. Green checkmark to the left of it. Daz Studio log file shows it being loaded with no visible errors or issues: "15:43:13.305 [VERBOSE] :: MatineeFX.dll". But I'm not seeing it listed anywhere in Daz to be used. There's no Pane for it, nothing in the Render pane/settings, nothing in the content library. Am I missing something?
    Edit: Tried it on a second system that has Daz 6 installed. DIM says installed, but didn't show up in the plugins. So did it manually. Now shows in the plugin list, but still nothing in the render window. I have to wonder if it's related to the fact that the base content directory for both installations is non-standard? Both systems share a CMS directory that isn't part of the normal Daz install. But again, both installations show the plugin as active and the log says it's loaded without issue.
    Post edited by adam_fe6a705d at
    just to confirm..did you check the render menu?
    477 x 144 - 28K
  • kyoto kidkyoto kid Posts: 42,470
    ...will it also work in 4.21?  That is the latest  version which works well with lttle trouble on my old hardware.
    I haven't tested on anything below .24 but there's no reason it shouldn't, all the functions MFX requires are in .21, so give it a go and you can always get a refund if it doesn't work, let me know how you get on
  • MattymanxMattymanx Posts: 7,002
    edited 6:47AM
    Yes it works in Daz Studio 4.24.0.3 - try manually installing it, the DLL and the folder in the plugins menu.  Thats how I installed mine (out of habbit)
    Post edited by Mattymanx at
    Yep, there it is. I was looking in the actual render panel. I'm so sorry for wasting your time :( Looking forward to playing around with this.
    Do you plan to add additional filters and modifiers down the line?
    no worries, I think a lot of users are not expecting to see it there, and I'm certainly open to ideas for expanding it
