Adding to Cart…
@zev0
Hello, unfortunately, this script Brow Remover for Daz Studio | Daz 3D doesn’t work for me in the latest Daz Studio 6. The utility box (grey panel with options) appears, and the Genesis model selection slider works. However, the “Show Mask” option does not. Also, when I try to run the script without the mask showing, the viewport flickers on the selected model’s face and the process cancels itself (the eyebrow removal "plucking" doesn’t complete.) I have tested it on Gen 1 through 8 on both M and F models, but the mask (reddish mask) does not show over the eyebrow area. I have tested the height dial also, nothing. I posted this message under General not realizing there is a devoted thread. Apologizes.
A lot of scripts need to be updated to work in DS6.
Thank you very much, Leana!
It dawned on me to try that with the Brow Remover. Naturally, it still works in Daz 4 (I'm still learning new things}. I saved the brow results under the Material Preset and Scene Subset. I opened up Daz 6 and this process worked perfectly. One thing though, at first I tried to save as a Character Preset in Daz 4, but I am guessing due to morph reset or temp files, it did not transfer over the face files.
Update: This method no longer works. The Brow Remover package is disabled in Studio 6 as well.
Hello! Oh my God, I just realized I forgot to select the whole model (assuming that is what I needed to do) because recently, when I was working with the Brow Remover, I only selected the face. That's when the missing files would show up. Selecting the whole figure worked. Thank you!
08/30/2026
I ran into the "problem" again. It worked in S6, and then it didn't. Finally, after saving the browless textures in a non-cloud path, it has worked in Studio 6(no more missing textures/tested twice). I corrected this by saving the browless textures in to ...\DAZ 3D\Studio\My Library\Runtime\Textures\and created a personal folder, and saved the Material Presets in the Material Preset folder. The materials may show up under ...\My DAZ 3D Library\ also.
Thank you very much again!
I hope this get update to DS6
Im currently using DS4 sins this don't work on DS6.
Is Zev0 around? I think they are. Still, can't you just edit the skin to remove it?
By the way some human textures are afflicted by painted pubic hair.
It's way down from brows but, who knows...
