Show Us Your Bryce Renders Part 14
1434445464749»
  • mermaid010mermaid010 Posts: 6,285
    Thanks Teobaldo. Condolences on the lost of a member of your family, wishing you peace and comfort during this painful time.
  • HoroHoro Posts: 11,713
    edited September 21
    Teobaldo - thank you. I am sorry to hear about your loss. These moments are not easy. I wish you and your family comfort and peace and hope this painful time will be over soon.
    The centre statue is from the Stanford 3D Scanning Repository, at left and right an instance. The material is from Fifty Funky Shapes and Fifty Funky Metals, for the instances only the colour for Diffuse were changed. They stand on the ground plane with some transparency and reflection. In the back a 2D Face as mirror. Background and ambient light by the unpublished Anteroom2vrNW HDRI. No sun, no haze. Thai statues (Stanford xyzrgb_Statuette).
    Coloured Statues
    1200 x 800 - 227K
    Post edited by Horo on
    Beautifully presented statues Horo
    Thank you mermaid.
    edited September 23
    The terrain was self made and given a modified material from High Resolution Terrains 1. The water is the ground plane with my material, a bit below a mirroring ground plane. Sky and ambient light by the SunSet HDRI from HDRI Enhanced Skies and the key light by the sun. A pond in a low ground of the green vegetated hills.
    Hills with Pond
    1200 x 800 - 315K
    edited September 23
    Magnificent landscape Horo, amazing work as always.
    Once again I used one of your ideas - the abstract – Funky Shape on page 43.  I used the same shape the OctoInterLoop1, but the materials, Hdri (Alienroom) and GWL lens setup are different. I like the result and will try the same setting with other objects and Hdris.
    900 x 600 - 798K
    Post edited by mermaid010 on
    mermaid - thank you. Your abstract looks really great. Yes, do use other objects and HDRIs. There are so many possibilities. Some small changes can result in a completely new result.
    Thanks Horo and thanks for the inspiration too.
