Help with dforce morph not saving
im trying to save a morph for Genesis 8 Kensington hair but when i try to import the morph i get this error? -daz 3d Warning: Geometry did not match, failed to create morph.does anyone know how i may fix kinds regards
  • How did you create the morph?
    If you're using a modeler, like z-brush, you need to be sure not to add or remove geometry.
    You'll probably need to start over and make sure to not add/remove geometry.
  • felisfelis Posts: 6,490
    And make sure you set resolution to Base before exporting from Daz Studio.
  • crosswindcrosswind Posts: 10,226
    edited August 14
    This hair is a strand-based hair.... you exported and manipulated the polylines in other software ?
     You have to activate Geometry Editor before export / impotr the SBH - OBJ, otherwise you'll get the geometry mismatch error.
    Post edited by crosswind on
