Help with dforce morph not saving
im trying to save a morph for Genesis 8 Kensington hair but when i try to import the morph i get this error? -daz 3d Warning: Geometry did not match, failed to create morph.does anyone know how i may fix kinds regards
How did you create the morph?
If you're using a modeler, like z-brush, you need to be sure not to add or remove geometry.
You'll probably need to start over and make sure to not add/remove geometry.
And make sure you set resolution to Base before exporting from Daz Studio.
This hair is a strand-based hair.... you exported and manipulated the polylines in other software ?
You have to activate Geometry Editor before export / impotr the SBH - OBJ, otherwise you'll get the geometry mismatch error.
Sorry, just saw these messages I'm using the dforce2morpht https://www.daz3d.com/dforce2morph?srsltid=AfmBOorRVSaUZ4skshAP7HojmMH8C0non-nfw-KwGyMvDKykuRaaQ1WR
when i try to save it gives me that error
I'm not sure if dForce2Morph can correctly work with strand-based hair ~ You can ask the PA who made the product: https://www.daz3d.com/forums/profile/2970716/RiverSoftArt
