BJ Pose Zone (Commercial)
2»
  • UthgardUthgard Posts: 899
    Yeah, hierarchical poses are quite bothersome in that often enough they just... don't really add anything of value. Much like hierarchical materials, truth be told, which make kitbashing a nightmare. Skipping anything other than the main pose would be a perfectly workable solution.
    Sorry to hear about the animation limitations. I was quite excited when I tried to convert an aniblock and it seemed to work, but, well, I can make do with Bone Minion still. Thanks for your input on the issues.
  • jmucchiellojmucchiello Posts: 1,935
    Unsolicited Customer Testimonial:
    I finally got to play with this and less than a minute later I'm sitting here blinking my eyes in astonishment. What normally would have taken 5 minutes with various tools I have for mirroring and partial posing took less than 30 seconds: Top half, bottom half, think for a second, mirror the top only. Done. Amazing that this only was created this year. Between this and the eventual IK thing I might be retiring a bunch of other tools. I just need to figure out where to place it on screen. It can't share the same pane as the Content Library. And it there are times when it being with the Scene Pane or with the Parameters Pane make a lot of sense.
  • bluejauntebluejaunte Posts: 2,247
    Did it convert probably just the first keyframe? I guess it could work to do the rest, would have to advance the frame every time and rinse repeat. Could be quite slow though. This all works by parsing the code in the pose preset file directly. That's what makes it so effortlessly drag and drop. You drop a pose, I ask what is in this file, what figure do these bones belong to and and what are they doing. Then translate it it to the selected figure's generation through various conversion layers, filter out the stuff you didn't want, and apply the pose in the end.
    Lovely :) Sure helps to have multiple monitors. I have Pose Zone on the far right on my right monitor next to a pane group with Content Library, Smart Content and Render settings. It's always visible.
    Remember you can dock it in more places if you don't drag on the tab but on the bar above it. Don't think this is so obvious to a lot of people.
    What's the difference between these two menu items?
    • Mirror -> (Bakes Pose Controls) - is this one mirror left onto right?
    • Mirror <- (Bakes Pose Controls) - and this one mirror right onto left?
    I just noticed there was a flip option as well.
  • barbultbarbult Posts: 27,380
    Yes, the subtle little arrows indicate the direction.
  • MrRogerSmithMrRogerSmith Posts: 173
    Hey bluejaunte, this is a really great tool!  It's been very helpful.  If I had a wish it would be that we could drag from Smart Content instead of just Content Library.  When clicking on "Show Asset in Content Library" it opens up the entire pose pack, which means I've got to hunt through the pose pack to find the pose I had already chosen through Smart Content.  Since I spend about 90% of my time in Smart Content, this is a bit inconvenient--some of the pose packs are fairly large.  Still a great tool!
    Thanks, yeah that would be a good addition. For BJ Shelf too I guess.
    Probably beyond what you think about for the tool. But imagine if multiple figures were selected and you hit Right Arm. And the Right Arm pose of the first figure were copied to all the subsequence figures. Just a thought.
  • crosswindcrosswind Posts: 10,159
    Yeah, pls add this feature !  I'm also a heavy user of Smart Content. It'll be great if I can directly drag a Pose Preset from Smart Content. Thank you very much !
    That would certainly be a great help, particularly with how often Smart Content somehow fails to find something in my Content Library (I don't know why or how, but manual searching is quite a frequent task).
    I think that should work more like this: copy whole pose of selected figure into a sort of clipboard, paste it on any zone of any other figure. Definitely have a use case for that as saving a pose just to get it onto another character is annoying. Also because saving a pose correctly is annoying.
    So guess what another feature is that I would love to have? Saving the pose! Save a full pose from Full Body zone, or any partial pose from the partial zones. And save it with 1 click correctly (or 2 I guess, 1 for the right click menu). Should be possible because of the parsing nature of the plugin to write those files directly, nice and clean, circumventing all Daz Studio dialogs. Would have to look into thumbnail generation though, see if the SDK exposes that. Or hack something.
    That pose copy-paste sounds very useful.
    I have an existing pose with the perfect right hand pose. I want to put it on a figure's left hand (mirrored of course). Is this posible in one step? Same for arm poses, leg poses, left to right, etc.
    In one step no. This would break the known universe and end humanity.
    I was hoping for an extra context menu entry:
    Right Hand
    Flip
    Mirror
    Set from Left Hand
    Reset
    Maybe you'll get bored and code it. :) :) :)
    Right Hand
    Flip
    Mirror
    Set from Left Hand
    Reset
    I might have misunderstood. I thought you wanted to drop a pose on Left Hand zone but get the pose from the right hand? Each hand zone has a mirror in both directions, doesn't that cover what you want?
     Drag RH pose preset to Right Hand, right-click Right Hand to flip or mirror, then reset ~  However, you'll lose the original righ-hand pose... Is that what you want ?
    edited August 13
    bluejaunte said:
    Right Hand
    Flip
    Mirror
    Set from Left Hand
    Reset
    No. Both hands are tight fists. I have a pose with right hand as an ASL (American Sign Language) "B" (open hand) and left hand is an ASL "I" (fist with pinky raised). I want to put the "B" on the figure's left hand while the right hand remains a fist.
    In the image, on the left, let's say the male figure has a pose in our library applied fully. And the female figure currently has some complex pose and her lefthand needs to be updated. But what she needs is on the left hand of the pose.
    As we can see, the "B" is on his right hand and "I" on his left. And she has two fists.
    After the drag, she has a "B" on her left hand and right is still a fist.
    I don't know how the menu pops up during a drag. Maybe after a delay while hovered. Or something.
    448 x 306 - 141K
    Post edited by jmucchiello on
    edited August 13
    Select girl's right hand, Copy Selected Item(s)... (Ctrl + C), in Pose Zone pane, right-click Right Hand > Reset.
    Drag "B" Pose Preset to Right Hand, right-click Right Hand > Mirror, then Reset. Select girl's right hand again, Paste to Selected Item(s)...
    This is the only way I could think of... if there're Pose Control properties dialed on any hand (e.g. Fist...)
    Pose Zone better auto resets all poses + pose controls dialed on that zone before applying a Pose Preset. For instance, if right-hand has Right Hand Fist property dialed, I have to manually Reset it before loading a Pose Preset to it.
    (Pls correct me if I'm wrong ~~)
    Post edited by crosswind on
    edited August 13
    Right, so if I understand correctly now, after B loads on her, you flip her hands and that's the correct result? Instead you want a menu to pop up when you drop the pose? And then you have to select something in that menu? Isn't that 2 actions as well? Unless I'm still misunderstanding I don't feel that would be faster at all. I guess I could consider making Ctrl + drag sort of pre-mirror the pose. So dropping on left hand gets the right hand from the pose.
    Oh while the right hand remains a fist, ok. So no flipping.
    Post edited by bluejaunte on
    I think that's correct, because I can't assume that you wanted to get rid of the pose control first. So whatever you load gets added to it. You could first bake pose controls though. Flip the whole pose 2 times I guess then you'll know there are no pose controls left. The Bake Pose Controls checkbox at the top is only to get rid of Pose Controls that might be saved in the pose.
    Or yes, just reset the hand first is also great. It removes pose and Pose Controls.
    Simplest way to do it:
    1. Flip the whole figure.
    2. Apply right hand to right hand
    3. Flip the whole figure.
    When I first posted, I hadn't figured that out. It's now just an academic exercise.
    Exactly ! until I understand it can Bake Pose Controls as bluejaunte explained yes
    Oh right, that's clever. smiley
    Still Ctrl drag could be cool. Especially if I could manage to also flip the dragged icon.
    I was thinking right-click drag (or ctrl+drag) would pop up the menu instead of excuting the action immediately. That's still a second click but the mouse is right there.
