• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Textures not working in Daz via Blender via Meshy
tam_c3df5332fctam_c3df5332fc Posts: 143
August 7 edited August 7 in Blender Discussion
Hey everyone,
I have been using Meshy to make uniforms and miscellaneous items for my Daz scenes
As you can see by the first image, Meshy does a pretty good job with not only the shape but the textures
EDIT: Meshy gives you the ability to take any object and split it into parts, which allows me to manipulate these parts in Blender
From there I take the obj file into Blender so that I can align all the parts with a G8F model that I had exported from Daz
As you can see with the second image, I can apply the Transfer Utility and the obj file can move right along with G8F
Where I have the issue is with the textures. Sometimes I have very little issues, I go to the Surfaces tab, select all the "parts" and change the base color image to include the texture file that Meshy made
I know that when you look at it, that it seems like it is a mess but that is the file that obj file is using to create what you see in the first image which is what you see when you open the obj file in 3D viewer
How is it possible to be so accurate in the 3D viewer and then turn out like the second image
I have tried in Blender to bake the textures, but it just creates these black and white base color images - see the forth image
As usual, thanks in advance
Post edited by tam_c3df5332fc on August 7
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,432
    are they textures or vertex colours
    I don't use Blender but regardless the object needs UV mapping and the textures baked if vertex colours
    Also, I do know GLB which I recall Meshy uses, doesn't export a separate texture but importing into other programs a map is created in my case Twinmotion, Unreal engine and PCon planner
    Blender I have always had issues exporting maps for anything so no help there
    I know this is the Blender forum so hopefully someone can help, I am only speaking as someone who has used Meshy
    Post edited by WendyLuvsCatz on August 7
  • tam_c3df5332fctam_c3df5332fc Posts: 143
    August 7
    Thank you for your response @WendyLuvsCatz
    In Meshy, after you create your object, you click on the object in the right pain, then in the middle section, if you click on the object, then you will see a button "Texture" from there it creates another object that has textures
    You can then download the new object with the textures and in the zip file you will see the texture file that it used - that is the third image that I uploaded for this post
    August 8
    so, have you changed that texture that you cannot use it in DAZ studio manually adding it
    I am aware one can download textures and other formats from Meshy
    was just trying to find out what's changed in Blender
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
