BJ Shelf (Commercial)
124
  • fullerdbfullerdb Posts: 81
    Look, people, this is going off the mark. An update has gone awry. These things happen. I will apologise to Bluejaunte if they think that anything I wrote here is inadvertently offensive to them. I just hope that anybody who can help acts to find a quick solution so that everybody can go back to using this great plugin.
    If anybody wants to discuss the philosophy of software distribution, they can start a new thread and invite me. This is not the place. Thank you; sorry; see you all around.
  • Richard HaseltineRichard Haseltine Posts: 111,087
    fullerdb said:
    I don't think it is fair to make this the user's fault.
    It seems to be a Daz fault, which we hope they will speedily fix. If you did have backups it would have let you recover from the effect of the error while waiting for an actual fix - but I certainly don't hae room to preach as I don't back up my multiple terrabytes of content installers..
  • jmucchiellojmucchiello Posts: 1,903
    edited July 12
    Even though we know what the issue is, should all who were affected file a ticket? Would that raise the visibility of the issue and perhaps get a solution out faster? Or would that have no affect? (I'm assuming someone has already filed a ticket, of course.)
    Post edited by jmucchiello on
  • bluejauntebluejaunte Posts: 2,235
    All good to be annoyed. Certainly no hard feelings from me :)
    I'd hope it gets fixed Monday. If urgent hit me up with some kind of proof of ownership, screenshot or something, and I'll hook you up with the zips. Or subscribe to my Patreon (still free), get on the Discord and message me there.
    No, the PA is aware and on the case and the update should be available to all users without needing any furthe action.
  • barbultbarbult Posts: 27,316
    I have my PC back up automatically every day to a Synology NAS. It is painless (other than cost of the NAS and discs) and has saved me several times. This is how I easily recovered my DS4 BJ plugins. I think this is a good backup plan for your terabytes of content. Once setup, you don't have to remember to do anything. If something like this bad DIM file erases files, you can go back a day,multiple days, month(s), or longer, depending on how you've setup your retention policy.
  • garrett_3dgarrett_3d Posts: 763
    Slightly off topic, but @barbult , how do you get on with the Synology? I'm in the market for a NAS and I see mixed reviews on them.
  • Darn came here to solve this problem and saw the warning too late.
    For those preaching backups, did you just reinstall the previous install package for shelf?
    Or are you talking a full reinstall of a backup of Daz Studio?
    I do backup all my stuff on Synology NAS, but I don't want to make things worse by installing the wrong thing.
    I can wait if I need to and deal with the annoyance for a short time if it's required to do a full install.
  • TugpsxTugpsx Posts: 903
    Just extract the .dll file from the zip file and place it in DS4 plugins folder. If you are not backing up the DIM files but backing up your Daz Studio folder, extract restore that bjshelf DLL file only back to the Daz plugin folder.
    I just got a notification that it went live in the store. Can you guys try again if that fixed anything?
  • edited July 13
    @tugpsx, thank you, i'll give that a go.
    Thank you very much. Copying it over worked and all my saved items in the shelf are there.
    Post edited by Umi no Senshi no Ishi on
    Keep in mind to get your shelf items into DS6 you can export shelf data in DS4 (right-click empty space in tab area) and then import them in DS6 (right-click same area).
    Ok there's various miscommunications going on, I'm not sure how long this will take now so if you need DS4 version just message me.
  • LauritaLaurita Posts: 288
    Read this thread , thought it was safe to update now - lost BJShelf. :-(
    DIM says the file date is July 10 for all four of your plugins that I own. Is that correct?
    Sounds about right for when the DS6 versions were packaged. Problem is DS4 versions get deleted when you install them.
    We did have a NAS a few years ago, but it relied on a connection to the maker and that became unreliable (this seemed to be a common issue with the model). Not that its maximum disc size would have been much help anyway. I do keep planning to replace it with a new one, but the connection issue has left me wary.
    I have had a Synology NAS for several years. I upgraded to a new one a year or so ago. Now I run both. I have been pleased with them. Their customer support has been excellent, too. They are very capable devices. I probably only use a tiny fraction of their capability. There is a lot that I don't even know what the terminology means. That hasn't stopped me from using the small part I want to use.
    I have a pretty old Synology NAS at this point. Still works great. Recently they got pretty bad press though because they would only allow their own brand harddrives, which is unneccessary and pissed everyone off. I think there's probably better options now.
    edited July 14
    I believe they have changed that restrictive disc policy. I did populate my newest NAS with their discs and have had no problems, for what that's worth.
    Post edited by barbult on
    Ah ok yeah maybe that's over with.
  • DasTriDasTri Posts: 234
    To just make that plain for all who tinker now with reinstalling their old backups:
    All you need to copy into the "plugins/" directory are the
    • dsp_BJ_SelectionHistory.dll
    • dsp_BJ_Shelf.dll
    No need to touch anything else. Copy the exsting files into a backup-directory or straight to V6.
    Thanks to fullerdb for pointing that out.
    And once this hassle is over I will repeat my suggestions here to make this tool even better. Seems they got swamped a bit. Good luck!
    Thanks for the quick help, Bluejaunte!
    Hey, guys. I'm very glad that the update came quickly. But has it worked for anybody?
    It did not work for me. I installed the new DS4/DS6 versions through DIM. Then I uninstalled everything. Then I downloaded the install files from the Product Library. Then I manually copied the files in many permutations. Then I noticed that the files in IM00111675-02_BJShelfPluginDS4.zip and IM00111675-01_BJShelfPluginDS6.zip are exactly the same, which does not look like what it's supposed to be. Perhaps Daz got them mixed up somehow?
    Or am I missing something?
    edited July 15
    I downloaded both zip files and checked. Yes, the DS4 zip contains the DS6 plugin. I am [utterly] losing it.
    Checked the zips I uploaded, they are correct. Not my fault, apologies anyway...
    edited July 15
    I downloaded both zip files and checked. Yes, the DS4 zip contains the DS6 plugin. I am utterly losing it.
    Thank you for being here and working to solve this. And I really appreciate that you are even offering the upgrade to DS6.
    Post edited by fullerdb on
    LOL Richard. Thanks for keeping me civil.
    Sorry I can't do anything actually useful.
    It sounds like Richard has all the qualifications for most any job at DAZ3D. LOL
    To be fair, turns out it was at least partially my fault. Apparently a DS6 update needs the DS4 version to be submitted again, even if it hasn't changed. It's one SKU and so the update will just take whatever is in the zip as "this is all the files now". That is kind of dumb IMO, since that also means they have to theoretically test the unchanged DS4 version again, creating more work. Or take the PA's word that the version is unchanged I guess.
    On the other hand, how was I supposed to know? We were not instructed whatsoever. I would think a DS6 update being submitted without a DS4 version present would at least result in a "is this really what you want" kind of communication? It is called quality assurance after all laugh
