[Released!] VisualMenus [Commercial]
1…67891012»
  • mdingmding Posts: 1,764
    Saxa -- SD said:
    Have more better news for you ;)
    Just found this link >https://www.daz3d.com/forums/discussion/56849/how-can-i-use-script-to-launch-an-external-application
    Essentially follow Rob's syntax, which is:
    App.showURL( “file:///c:/MyApp.exe” );
    Just tried this for one of my mp4s.
    (1) in folder path you want in DS, make  new text file. rename extension to .dsa.
    (2) enter code above in new dsa, then substitute your filepath. Spaces and different directories are fine. Mine was 4 folders deep.
    (3) refresh folder in DS, see .DSA, double-click and now my MP4 auto opens in MPC-HC.  My MPC-HC is set as the .mp4 player in win os.
    DazStudio really is awesome in all the features it offers.
    Happy tut'ing!
    OMG that is so cool - thank you so much @Saxa -- SD!!yesyesyes
  • LauritaLaurita Posts: 295
    Saxa -- SD said:
    Not sure what Bitwelders continued absence from this thread means.  Still JVs with Zevo.  Maybe not available for forum support for reasons.  Dearly hope it works at least with new DS/new code when that out.
    I honestly believe he simply has no clue how indispenable VM are for some people. Me included.  I would love to know how many units of this tool got sold over the years, I just hope it is profitable enough for Bitwelder to update it once (if) DS5 is relaesed.
  • evacynevacyn Posts: 993
    I keep getting the notifications about new comments, and I'm always hoping it's Bitwelder with an update ;)
    @Laurita - I hope he does know how important it is. A part of me dreams that the reason there hasn't been an update is that they're working on incorporating the core functionality into DS5 :)
  • NathraiNathrai Posts: 67
    Heyho - I hope it's okay to post in here, but I thought this would be where the VM experts would be found ...wink
    I love, love, LOVE VM for letting me customize my GUI to my very needs, but there's one thing I just can't seem to get right. I have a couple of custom toolbars full of VM links that I changed the icons of. But whenever I open the main VM window, the icons go back to the original VM ones.
    So this:
    Turns back into this:
    Is there any way to keep the main window from overwriting my custom icons?
    149 x 39 - 5K
    150 x 40 - 1K
  • barbultbarbult Posts: 27,652
    Can you be more specific about the sequence of what you are clicking on. Your screenshots are tiny and don't show the whole VM window that you are viewing. I use VM a lot and have never seen this problem.
    edited April 2024
    Sorry for the confusion - the screenshots are not from the VM window, but the DS Tool Bar.
    What I'm doing is:
    1. Create a new VM menu
    2. Go to Windown --> Workspace --> Customize... to add the new menu to the DS Tool Bar
    3. Set the icon for the custom action
    4. The new icon is displayed in the DS Tool Bar as expected
    5. And it stays that way, until I open the VM window - don't have to click on anything, simply by opening the VM window the icons on the DS Tool Bar reset to:
    493 x 584 - 40K
    806 x 633 - 75K
    807 x 635 - 80K
    Post edited by Nathrai on
    Thank you for the clarification. I've never tried to add a visual menu to the toolbar. I've always just assigned a keyboard shortcut to each one. I'll try following your example and see what happens for me.
    I think you should be setting the custom icon for your visual menu in the visual menu interface before adding it to the toolbar. Did you do that? You didn't mention it in your list of steps, and I can't tell what icon is on that Launch VM: Plugin Panes in the screenshot. Why are you changing the toolbar icon? That doesn't seem like the right process to me. Once I have set the custom icon for the Visual Menu in the Visual Menu interface, that icon shows up on the toolbar after adding the visual menu to the toolbar. I did not need to change the toolbar icon from the Windows>Workspace>Customize interface.
    When you say the icons are displayed on the toolbar correctly until you open the "VM Window", I'm not sure what "VM Window" you mean. Do you mean your custom menu assigned to the icon you just added to the toolbar or do you mean the main Visual Menu Dashboard or something else? Once I have added my custom menu to the toolbar, I have not found a way to make it regress to the generic visual menu icons you showed in your step 5.If I go to the VisualMenus product and click on the VisualMenus script, it opens the dashboard, but nothing changes on my toolbar.
    edited April 2024
    Oh, WAIT! maybe it did just change right now! I need to try this again!
    No, it seems OK to me when I look closely. This is the VisualMenu command I used to set the icon for the toolbar.
    255 x 200 - 16K
    Post edited by barbult on
    This little light bulb icon is the one I set in VisualMenus for my Light Sets visual menu. Here you can see it on the toolbar, still correct, while I have the VisualMenus script open to the dashboard.
    488 x 641 - 66K
    Aaaaaaaaaaaaaaah!
    I never realized there was an option in the menu on the created window itself - I though all you could do was rename and set shortcut when rightclicking in the list!
    Thanks so much, setting it from within VM did the trick, the icons are no longer resetting now heart
    Wonderful. Thanks for posting that you got it working.
  • PlatnumkPlatnumk Posts: 682
    I've ran into a problem,  I'm unable to add anything to a button from the Smart Content or Content Library.  It was working find in Daz 4.23 but not in Daz 4.24 even tho I have something selected in the Content Library.
    2424 x 1680 - 1M
  • jjoynerjjoyner Posts: 878
    edited May 2025
    I note in your screen capture that you have the Content Library Bookmarks tab selected and not the Content Items tab.
    I opened VisualMenus in Daz Studio 4.21 and was able to add selected Content Library items to a menu.  I next opened Daz Studio 4.24 Beta and was also able to add selected Content Library items to a menu.
    1200 x 650 - 156K
    Post edited by jjoyner on
    The Content Library Bookmarks allows it to point to a Folder in the Content Library Pane, For example you coiuld have a Button labeled "Genesis 9" then when you click on it you Content Library Pane opens up the Genesis 9 Folder.
    This may have been fixed in the latest beta but i'm running 4.24 General Release.  Just incase it makes a difference i'm also using MacOS.
    edited May 2025
    You are right. The VisualMenus Content Library Boolmarks does not work in DS 4.24.0.4. It works fine in 4.22.0.16.
    Edited to add: I worked around this problem by creating a custom action for the folder and setting button for that custom action in VisualMenus.
    Sadly this only works if you have a single Library,  I have 2 Librarys and when you create a custom action using the 2nd library it still ponts to the 1st library
    Came across the same problem. Really annoying as I am dependent on VM for organizing my workflow. I wonder if Bitwelder does even know how helpful and indispensable this tool is.
  • valithor9valithor9 Posts: 0
    The day has come and it doesn't work with DS6. I hope a solution can be found, but my expectations are low.
    I second that motion, please please update or male a new DS6 version.
  • HavosHavos Posts: 5,706
    I will add my vote for this. I use this plug in a lot
  • ArtiniArtini Posts: 10,993
    Last post of @bitwelder on the forums is from December 2023, so it can be problematic to get an update.
    edited July 7
    @bitwelder released a product together with Zev0 at the end of 2024, so was active 18 months ago, but that is still a long time. We have not had anything new from Zev0 for 15 months either, so both have not been active for some time.
    Post edited by Havos on
  • jmucchiellojmucchiello Posts: 2,521
    But Zev has been online today. No idea what they're up to. But bitwelder has been missing for 18+ months.
  • crosswindcrosswind Posts: 10,351
    I have the very same thought that @bitwelder will never make the plugin work for DS 6.x. It's really a pity.
  • winmathwinmath Posts: 149
    I'm getting the errors about variables being used before their declarations. Example
    Scripts/VisualMenus/VisualMenus.dse:2080:9 Variable "oWhatsThis" is used before its declaration at 2092:13.
    Scripts/VisualMenus/VisualMenus.dse:8942:17 Variable "bResult" is used before its declaration at 8980:25.
    This should be a minor fix for the developer. Hopefully Zev has the source code.
  • evilded777evilded777 Posts: 2,551
    It would be really disappointing if this never saw an update. I'd even pay for a new version that worked with DS6. I rely on this tool so much to manage all the other scripts I rely on for my workflow.
    Fwiw: I found BJ Shelf a very good, in some regards even better alternative.
