Buy Something That Doesn't Work in Carrara? Post your Questions and Workarounds here. (please)
1464748495052»
  • Diomede said:
    Ouch - that really sucks, Wendy.  I feel some of your pain.  Fingers crossed that it works out for you.
     well Carrara itself is not the issue
    its everything else
    and that is the something that doesn't work in Carrara increasingly on Win10
    I know Carrara itself works in Win11
  • DartanbeckDartanbeck Posts: 22,051
    Ditto what Diomede said, Wendy. My heart goes out to you! heart
    Just keep your seatbelt fastened!
  • StezzaStezza Posts: 9,013
    Extended Security Updates program for W10 users
    Free – This option is available if you're backing up files to OneDrive, regardless of whether you have a Microsoft 365 subscription.
    How to enroll Windows 10 in the Extended Security Updates program
    To sign up for the ESU program, use these steps:
    Open Settings.
    Click on Update & Security.
    Click on Windows Update.
    Click the "Check for updates" button to ensure the device has the latest updates, and the enrollment option becomes available.
    How to use Windows 10 ESU to keep getting updates after October 2025
    smiley
    Wow Stezza. That's Awesome! Very nice post, my friend! Thank You!!!
    no probs if it works ok..
    I dragged my old laptop with W10Pro and fired it up... still works but I did wipe it and put some version of linux on it to see how it went... installed fine and updated. Then I turned it off and put it back in the cupboard. cool
    I have a Windows 95 IBM machine in the back shed somewhere ( unless the missus has turfed it ) tempted to see if it still works laugh
    Always tempting to look back in time like that.
  • moving stuff around in one's content library apparently
    Carrara (not DAZ studio) asks me where it is!!!
    this is just browsing to the library, not actually loading anything
    smart content doesn't work in DAZ studio for me anyway but I think Carrara might still use it to some extent
    I just plonked stuff by Predatron fom 4 different locations into one of his folders, the duf files, and Carrara asked me to browse to and find every one of them!
    DAZ Studio doesn't, it just loads them from wherever I put them
  • Bunyip02Bunyip02 Posts: 9,302
    +1 yes Extended for another 12 months which works well for my computer replacement !!!
    yes
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,864
    edited November 2025
    Genesis 9 animation conversions
    the first ones are fine and were baked aniblocks I believe I used Bone Minion on some
    others are iClone 3DX6 conversions
    but
    those last ones were keyframed G8 animations converted with n_alexandru's script
    and in Carrara they are crazy
    I need to test further if its the script or the animations themselves how they are keyframed
    may be an interpolation thing
    AND if it happens in D|S as I save and render them on the character after conversion
    not loading the saved pose file, it could be a save issue too
    but
    Talk about doing the Jitterbug !!!
  • my timeline was not showing everything as some of my body parts collapsed so missed a lot of keyframes
    Carrara still does weird spins though as need to use angles in motion and forget
    edited April 2
    this balloon dog for $10499.30 doesn't quite work right in Carrara but it is an easy excersise in getting it to work
    first you will need the Carrara Plugin called Daz Studio
    Open you expensive balloon dog in DS and then export in OBJ format and set for Carrara to your fav folder for doing stuff like this
    then one at a time in DS apply the pose and export each time the same as before and name it the pose you have applied
    when all that is done open Carrara
    import the OBJ default balloon dog ... it will be a bit over size when imported so adjust it back to 100%
    then into the modelling room... select all of the object and create morph
    in the morph you created create a morph and call it one of the poses you saved, then import the balloon posed OBJ file and appy
    do same for all the poses and then you will have a working balloon dog worth $10,499.30 working in Carrara devil
    then all that you need to do is create a balloon texture for the balloon dog
    1320 x 859 - 354K
    1079 x 712 - 310K
    Post edited by Stezza on
  • wsterdanwsterdan Posts: 3,435
    Nice to actually be able to use a $10,499.30 asset, thanks for the info.
    "first you will need the Carrara Plugin called Daz Studio". laugh
    I think that's the same plugin I use these days for Nano Banana Pro... wink
  • therixxtherixx Posts: 259
    edited April 16
    Ok, now the good comment has disappeared. I am not going to rewrite it all, but
    I posted my Easter card in the Show us your renders.
    I noticed an issue: the lens flares are directly made by Carrara, but they were supposed to be stronger than what I posted at first. They were ok while I was rendering at small sizes, but my final renders are 4096x2304 (from which I then get the smaller ones)
    It seems that, the higher the resolution, the weaker the lens flares become.
    So, for the final renders I raised the streaks intensity (of the lights with lens flares) a lot. Now the render looks like it was meant to be since the beginning.
    Here you can see both images in two separate posts
    https://www.daz3d.com/forums/discussion/comment/9494326/#Comment_9494326
    Post edited by therixx on
    edited April 17
    the light flares are actually postworked by Carrara so one could theoretically render them separately with other layers such as a depth map at a lower resolution to add in another program like Photoshop or Gimp with upscaling applied, or just add lens flares in another program in post for that matter
    I know, I was pointing out, as a reminder, a behaviour that could be unexpected. It was for me, at least.
    edited April 20
    I want to use Carrara
    it just makes me cry
    none of the Genesis 9 poses are now working on my saved blended weight Genesis 9 characters
    my DAZ Content folder won't update
    had to load blended weight mapped clothing via file because would error from browser
    I am just so frustrated
    I am going to try resaving in D|S4.11
    edited April 20
    rear wheels of Meshworks Cobra motorhome don't turn
    but they don't turn in DAZ Studio either wink
    maybe I need to hide them and cut off another set from the model and parent them
    update
    is a prop version I could easily cut up
    just used it's rear wheel but might actually be easier to use whole thing
    Wendy, did you buy the Cobra motorhome from meshwork's own site?
    So the shop works via paypal?
    I doubted this because they have a closing offer for 20$ every product, but the button doesn't work. Also, the contact email appears to be broken...
    And is that the Sunflyer motorhome? Because when I click on the Cobra I get a page 404 error
    edited April 20
    yes
    you need to go to the last product page to purchase the download from the link given
    not clicking product names but the number/letter combination  next to them towards the left
    then go back on your browser for the next one
    read the instructions carefully
    there are a couple of different motorhomes and addons BTW
    see https://www.daz3d.com/forums/discussion/comment/9503201/#Comment_9503201
    1920 x 1080 - 1021K
    yes
    Just bought the package with no problems.
    A couple of the download links came up with a 404 error, but the majority worked okay.
    Also check the Freebies and Projects for downloads.
    Thank you guys! During these days I got the freebies, but now I am off to download all the 20$ products! I wouldn't have figured out  how to do it, I thought it just was not working
    yeah, not the most user friendly site, some download links didn't work and some links double up on items that already have been downloaded. surprise
    then in Carrara it is a PITA getting the textures for a lot of the products... still.. for $30AU it's worth the effort. wink
