Poses for Cat Zeus by Vyusur
richardandtracy
Please find attached a set of poses for Cat Zeus by Vyusur. They are somewhat unusual and complement the poses by Vyusur showing the cat doing catty things.
There are 10 poses and 8 mirror poses for the non-symmetrical poses.
The image below shows all the poses, but not the mirrors. We have had cats for years, and all of our cats have regularly been in poses similar to most or all of these poses.
The poses are:
- Barf 01 and 02
- Claw Scale Removal
- Flat Cat 01 and 02
- Running 01
- Washing 01 to 04
The two flat cat poses rely on a little script to override Vyusur's lock on the hidden Abdomen [1]/2/3 and Chest Scale properties, and set them to Y Scale=80% and the Z Scale to 110%. This stretches and flattens the cat's tummy in the same way as a real cat goes liquid as it lies down. There is a script to undo it when you need to. The poses are in the following directory: {content}\Animals\Vyusur\Cat Zeus\Zeus Poses\ChestnutP, and the 3 scripts are in a subdirectory of that directory.
Hope they're useful.
Regards,
Richard.
Amended 1 May 2026: Barbult had a problem with the poses with scripts. It appears I had managed to get an error in the scripts which meant they would occasionally work - and occasionally fail. I have amended the scripts, and learnt a lot in the process, so if you could download and install the scripts, you can avoid the risk of script failure.
Where can we buy the cat?
It's available at Renderhub currently
thankyou richardandtracy
My pleasure. They were quite fun to do, and much of the time I had an 11 month old Maine Coon kitten showing me 'Flat Cat' poses to recreate.
Regards,
Richard
Would anyone find a DAZ House Cat pose transfer script any use?
It may be sensible to try to get both cats to use all the available poses as there are so few for each.
Regards,
Richard
yes
OK, I'll look into whether it's possible and how difficult it would be. Also makes sense to see if the other cats in use could be added in, Eg Mr Rattlepaws, Millenium Cat and the Hivewire Cat. Some of those may be more used than others, but the Millenium Cat has a few pose sets still available. I'd expect there to be a few issues with the Mil Cat, given how old it is, but you never know.
Regards,
Richard
Definitely
Regards,
Richard
I would definitely be interested.
Is everyone aware Zeus poses work on Vyusur Cat Mars aswell
It would also be great if AM Cat can get added to your list, whenever it is available. Can't have too many cats ;-)
it's identical basically just a different texture and scene identification
non dforce fur
after leaving DAZ for political income reasons couldn't sell dforce curve fur
I bought Mars when at Renderosity for the texture AND editable fur!
can change the scene identification and use everything interchangeably
Saw it & loved it, thanks.
Regards,
Richard
I had to do a lot of searching to find Cat Zeus on RenderHub.
Here is the direct link. https://www.renderhub.com/vyusur/cat-zeus
I went directly to RenderHub, and it took awhile to find it.
I'm also very interested in the script for Daz House cat pose transfer, thanks!
I'll see if I can work out equivalent bones between the two - that's usually the biggest problem. For example with V3 to G8, V3 has L & R thigh bones, L & R buttock bones and no pelvis. So when converting from V3 to G8 means that the pelvis is given a pose half way between the V3 L & R buttocks, and then the difference between the V3 R buttock & G8 pelvis is added to the V3 R thigh rotation and applied to the G8 thigh. The same sort of thing is done with the left side. It's usually just a matter of thinking it through, but there are occasional surprises, like 90 degrees bend on one character does not cause the same size bend angle as on the recipient character. Sounds odd, but it happens.
Regards,
Richard
Yes! Most definitely.
I have given in and bought the Maine Coon morph for Zeus. I think some extra poses will be needed . The tail length morph had to go to 300% to look right. But nice anyway. Here with standard Zeus and the DAZ House Cat.
Regards,
Richard
Gorgeous cats.
I do like Cat Zeus, and given what Barbult is doing in her art thread, I couldn't resist completing a picture with a hapless male getting told off for allowing cat food bowls to reach the 'empty' state. A dreadful state that involves the male of the species (shadow visible in the right of the shot) getting sworn at by a hangry cat and ranted at by a deeply disappointed spouse.
I had meant to publish the food bowl freebie years ago, but never did. Tomorrow maybe?
Regards,
Richard
Barbult had some problems with the poses with scripts. I made an error in their coding, now updated. So if you could go to the first post and download the amended poses, that would avoid the risk of an error. I do apologise.
Regards,
Richard.
It may be a little obvious, but I'm dotty about cats in general and our cats in particular. As a result I have come up with a few more images with Vyusur's Zeus in a Maine Coon guise. And, obviously, the Cat's particular human has to be worshipping the cat appropriately:
If anything, Cat Zeus (Maine Coon version) is a bit small for a Maine Coon. Our two can stand on their back paws and see onto the kitchen worktop. Do really like this cat.
Regards,
Richard.
I've installed the updated script files. It looks like it is working correctly now. Thanks for the quick fix.
Edit: NICE cat renders, too. Both the cat and his human look great.
I have a few eye watering poses for Zeus, who is twisting his back as only a cat can. Five poses with mirrors.
Zip file updated to correct directory name.
Regards,
Richard
Please find attached six hierarchical poses and mirrors for cat Zeus and G8F Base figure.
To use, load the figure, parent Zeus to the figure's root node, then apply the pose to the figure. These poses are very sensitive to differences in figure size.
As an aside, I thought mirrors were going to be very difficult, but it turned out to be easy. With Zeus being parented to G8F Base meant that when I recursively mirrored the pose, Zeus was mirrored too. Much easier than I expected.
Figure details: G8F base shape body. Head is Valiona converted to G8F from G3F. Trousers are Lilflame Low Rise Trousers (Rendo) and the top is a freebie from somewhere (I think). Hair is either Nydo hair (top left & top right) or Classic Side Part Hair. Shoes, where used, from Arryn/Onnel Alina Outfit
Regards,
Richard
Please find attached six hierarchical poses and mirrors for cat Zeus and a G9 figure, CB Lores. I can't bring myself to use the G9 base figure or either of the male/feminine base figures, they're just horrible, so I'm afraid there is a bit more work than with G8F to fit Zeus.
Details: Cat Zeus, currently from RenderHub. Figure is CB Lores. Hair is Akhelloos Sofina Hair from Rendo or Goldtassel Cafe Curls. The top is a freebie from Aeon Soul, the trousers are Lilflame Low Rise trousers from Rendo.
Regards,
Richard
