Poses for Cat Zeus by Vyusur
richardandtracyrichardandtracy Posts: 8,220
edited May 1 in Freebies
Please find attached a set of poses for Cat Zeus by Vyusur. They are somewhat unusual and complement the poses by Vyusur showing the cat doing catty things.
There are 10 poses and 8 mirror poses for the non-symmetrical poses.
The image below shows all the poses, but not the mirrors. We have had cats for years, and all of our cats have regularly been in poses similar to most or all of these poses.
The poses are:
  • Barf 01 and 02
  • Claw Scale Removal
  • Flat Cat 01 and 02
  • Running 01
  • Washing 01 to 04
The two flat cat poses rely on a little script to override Vyusur's lock on the hidden Abdomen [1]/2/3 and Chest Scale properties, and set them to Y Scale=80% and the Z Scale to 110%. This stretches and flattens the cat's tummy in the same way as a real cat goes liquid as it lies down. There is a script to undo it when you need to. The poses are in the following directory: {content}\Animals\Vyusur\Cat Zeus\Zeus Poses\ChestnutP, and the 3 scripts are in a subdirectory of that directory.
Hope they're useful.
Regards,
Richard.
Amended 1 May 2026: Barbult had a problem with the poses with scripts. It appears I had managed to get an error in the scripts which meant they would occasionally work - and occasionally fail. I have amended the scripts, and learnt a lot in the process, so if you could download and install the scripts, you can avoid the risk of script failure.
Post edited by richardandtracy on
«1
  • Ron KnightsRon Knights Posts: 2,788
    Where can we buy the cat?
  • LeanaLeana Posts: 13,628
    edited March 29
    It's available at Renderhub currently
    Post edited by Leana on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,752
    thankyou richardandtracy heart
  • richardandtracyrichardandtracy Posts: 8,220
    My pleasure. They were quite fun to do, and much of the time I had an 11 month old Maine Coon kitten showing me 'Flat Cat' poses to recreate.
    Regards,
    Richard
    edited March 30
    Would anyone find a DAZ House Cat pose transfer script any use?
    It may be sensible to try to get both cats to use all the available poses as there are so few for each.
    Regards,
    Richard
    Regards,
    Richard
    yesheart
    edited March 30
    OK, I'll look into whether it's possible and how difficult it would be. Also makes sense to see if the other cats in use could be added in, Eg Mr Rattlepaws, Millenium Cat and the Hivewire Cat. Some of those may be more used than others, but the Millenium Cat has a few pose sets still available. I'd expect there to be a few issues with the Mil Cat, given how old it is, but you never know.
    Regards,
    Richard
    Regards,
    Richard
    Definitely
    yes
    Regards,
    Richard
  • 3Ddreamer3Ddreamer Posts: 1,357
    I would definitely be interested.
    Is everyone aware Zeus poses work on Vyusur Cat Mars aswell
    It would also be great if AM Cat can get added to your list, whenever it is available. Can't have too many cats ;-)
    Thanks. I don't have Cat Mars, so wasn't sure the poses would work, but suspected they would. I'm not sure AM has confirmed they will create a cat. Regards, Richard
    edited March 31
    it's identical basically just a different texture and scene identification
    non dforce fur
    after leaving DAZ for political income reasons couldn't sell dforce curve fur
    I bought Mars when at Renderosity for the texture AND editable fur!
    can change the scene identification and use everything interchangeably
  • barbultbarbult Posts: 27,641
    That sprawling pose was perfect for my latest Richard Haseltine render. Thanks.
    Saw it & loved it, thanks.
    Regards,
    Richard
    I had to do a lot of searching to find Cat Zeus on RenderHub.
    Here is the direct link.  https://www.renderhub.com/vyusur/cat-zeus
    Must admit I searched for 'Cat Zeus' and 'Vyusur' on Google, and it was the top link. I am very tempted by Vyusur's Maine Coon morph for Zeus. Not really like our fleabags, but better than anything else to date. Regards, Richard.
    I went directly to RenderHub, and it took awhile to find it.
  • emanuela1emanuela1 Posts: 1,251
    I'm also very interested in the script for Daz House cat pose transfer, thanks! smiley
    edited April 2
    I'll see if I can work out equivalent bones between the two - that's usually the biggest problem. For example with V3 to G8, V3 has L & R thigh bones, L & R buttock bones and no pelvis. So when converting from V3 to G8 means that the pelvis is given a pose half way between the V3 L & R buttocks, and then the difference between the V3 R buttock & G8 pelvis is added to the V3 R thigh rotation and applied to the G8 thigh. The same sort of thing is done with the left side. It's usually just a matter of thinking it through, but there are occasional surprises, like 90 degrees bend on one character does not cause the same size bend angle as on the recipient character. Sounds odd, but it happens.
    Regards,
    Richard
    Regards,
    Richard
    Yes! Most definitely.
    edited April 9
    I have given in and bought the Maine Coon morph for Zeus. I think some extra poses will be needed . The tail length morph had to go to 300% to look right. But nice anyway. Here with standard Zeus and the DAZ House Cat.
    Regards,
    Richard
    1200 x 800 - 2M
    Gorgeous cats.
    edited April 11
    I do like Cat Zeus, and given what Barbult is doing in her art thread, I couldn't resist completing a picture with a hapless male getting told off for allowing cat food bowls to reach the 'empty' state. A dreadful state that involves the male of the species (shadow visible in the right of the shot) getting sworn at by a hangry cat and ranted at by a deeply disappointed spouse.
    I had meant to publish the food bowl freebie years ago, but never did. Tomorrow maybe?
    Regards,
    Richard
    1200 x 1800 - 527K
    Barbult had some problems with the poses with scripts. I made an error in their coding, now updated. So if you could go to the first post and download the amended poses, that would avoid the risk of an error. I do apologise.
    Regards,
    Richard.
    edited May 1
    It may be a little obvious, but I'm dotty about cats in general and our cats in particular. As a result I have come up with a few more images with Vyusur's Zeus in a Maine Coon guise. And, obviously, the Cat's particular human has to be worshipping the cat appropriately:
    If anything, Cat Zeus (Maine Coon version) is a bit small for a Maine Coon. Our two can stand on their back paws and see onto the kitchen worktop. Do really like this cat.
    Regards,
    Richard.
    1100 x 2400 - 432K
    800 x 800 - 121K
    800 x 800 - 120K
    edited May 1
    I've installed the updated script files. It looks like it is working correctly now. Thanks for the quick fix.
    Edit: NICE cat renders, too. Both the cat and his human look great.
    Post edited by barbult on
    edited May 2
    Thank you. The human is a tweaked version of Cherubit's Milan for G8. She's one of two I use pretty regularly, in this situation I thought she was easier to make look as if she's totally under the paw. Regards, Richard.
    edited September 22
    I have a few eye watering poses for Zeus, who is twisting his back as only a cat can. Five poses with mirrors.
    Zip file updated to correct directory name.
    Regards,
    Richard
    800 x 800 - 107K
    zip
    zip
    Zeus Twisting.zip
    2M
    edited September 24
    Please find attached six hierarchical poses and mirrors for cat Zeus and G8F Base figure.
    To use, load the figure, parent Zeus to the figure's root node, then apply the pose to the figure. These poses are very sensitive to differences in figure size.
    As an aside, I thought mirrors were going to be very difficult, but it turned out to be easy. With Zeus being parented to G8F Base meant that when I recursively mirrored the pose, Zeus was mirrored too. Much  easier than I expected.
    Figure details: G8F base shape body. Head is Valiona converted to G8F from G3F. Trousers are Lilflame Low Rise Trousers (Rendo) and the top is a freebie from somewhere (I think). Hair is either Nydo hair (top left & top right) or Classic Side Part Hair. Shoes, where used, from Arryn/Onnel Alina Outfit
    Regards,
    Richard
    1200 x 800 - 138K
    zip
    zip
    Zeus and G8F Poses.zip
    3M
    edited September 24
    Please find attached six hierarchical poses and mirrors for cat Zeus and a G9 figure, CB Lores. I can't bring myself to use the G9 base figure or either of the male/feminine base figures, they're just horrible, so I'm afraid there is a bit more work than with G8F to fit Zeus.
    Details: Cat Zeus, currently from RenderHub. Figure is CB Lores. Hair is Akhelloos Sofina Hair from Rendo or Goldtassel Cafe Curls. The top is a freebie from Aeon Soul, the trousers are Lilflame Low Rise trousers from Rendo.
    Regards,
    Richard
    1200 x 800 - 120K
    zip
    zip
    Zeus and G9 Poses.zip
    2M
