Off Topic Thread #2
1…4647495152…60
  • StezzaStezza Posts: 9,316
    was thinking of getting a month of Daz+ to see if there is anything worthwhile for Carrara but thought I'd ask here first if any Carrara users are currently in Daz+ and if they find it of any use?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,872
    I joined a month ago and no, not really
    I have been fossicking through the Outlet though at half the price and it is probably worth it for that
    I thought so.
    Not interested in anything G9 or 8
    just thought there may be a heap of free props available as I haven't been a member in a long while and one month on special price I thought may of been worth it.
    Stezza said:
    I thought so.
    the DAZ+ freebies are mostly B&W rooms and corridors
    a Martin Frost plant set if lucky
    I eyed them off here a year before rejoining and knew I wasn't missing much https://www.daz3d.com/platinum-club-freebies#index=0&filtered=1
    the $6 DO coupon offsets some of the subscription
  • Steve KSteve K Posts: 3,540
    WendyLuvsCatz said:
    and now the early 3D programs
    Maybe not as early as you mean, but I have fond memories of Bryce V.3  (1997 by MetaCreations), the first version to offer animation as I recall.  And the inspiration for one of the best 3D software books ever, "Real World Bryce 4" by Susan Kitchens and Victor Gavenda.
    "During development of Bryce 3D and 4, there was only one source for determining how Bryce "should" work! You guessed it! we used Real World Bryce 2!"
     - Brian Wagner, Bryce 4 Lead Engineer
    (Not sure about all the versions #'s, but the first one with animation is what I'm talking about - the CD with the book had a lot of animation tips/examples like cameras on hinged poles)
    edited February 27
    meanwhile in Twinmotion
    it has OpenStreetMap urban mesh generation built in
    so... I typed in a very bad island
    and it loaded all the roads, buildings and vegetation
    not terrain but that was easy to sculpt around the structures with a Google Earth reference
    might try Datasmith to get it into Unreal Engine then into Carrara
    won't be naming this island
    I probably should use Terrain Party to get an accurate terrain
    is gone crying not sure how to use Ground Control
    getting outage error on https://apps.nationalmap.gov/downloader/#/?z=16&y=18.298905793037623&x=-64.82357077301239&basemap=usgs_topo&datasets=elevation-topobathy&layerIds=elevation-topobathy-dem,elevation-topobathy-dem
    OpenStreetMap and OSM2World Java program gave me a similar result to Twinmotion in obj format
    not my preferred option as flat but only one that works
    NASA topography also not downloadable
    maybe I can use the Google Earth image to edit a rough terrain greyscale image map
    1920 x 1040 - 290K
    1920 x 1040 - 348K
    edited February 27
    Carrara Octane renders and Twinmotion render
    needs lots more work laugh
    very unhappy with terrains
    video
    1920 x 1040 - 789K
  • My first 3D program was Swivel 3D. It was in black and white. Not even grey scale. It was originally made by Paracomp then sold to Macromedia. https://en.wikipedia.org/wiki/Paracomp
    Mac seems to have been way ahead of Windows with 3D
    edited March 3
    is this what the object accuracy basically does in Carrara?
    or reading the online help PDF, is it more filter sharpness
    in any case, it seems an interesting technique
    I bought some Bertie Beetles off Amazon instead laugh
    Seeing the RES will soon be starting. wink
    Th e Res-session?
    lol Royal Easter Show laugh
    Close !
  • Bunyip02Bunyip02 Posts: 9,345
    Was watching my C drive space which was rapidly filling up leaving me with 6 GB of space. Was concerned that if I got a windows update my system would come to a halt due to running out of room.
    Downloaded WizTree, installed than ran it.
    It identified a number of temp files which were deleted.
    Now have a healthy 58.5 GB of free space !!!
    I use MS PC Manager and have it running in the backgrund when Carrara'ing etc... yes
    edited March 14
    C:\Users\Wendy your name\AppData\Local\Temp fills up and it's contents worth deleting regulary
    your Carrara tmp folder too
    often C:\Users\your name\Documents\DAZ 3D\DazTmp but you can choose somewhere else in preferences
    I had Windows Search Indexing turned on - it was using up nearly 38 gigs of space. Turned it off.
    Also had a program called PDFill PDF Writer (Free) installed. When I found an article on the web I wanted to keep track of I was printing out a PDF of that article with it.
    It was storing temp files everytime I used it, generating over 20 gigs of temp files.
    been a bit quiet here
    I admit I only briefly opened Carrara the other day to load a DAZ Studio set that needed too much work
    edited March 19
    Always lurkers I'm being out of my house for 6 months have just spent 4 days sorting mi library books are so so heavy
    Post edited by Headwax on
    Getting more and more into DS 4.24 for backgrounds for Carrara images/animations.  And really liking the one item per day for ~$2, my recent monthly credit card statement had 26 DAZ charges, most for a couple of dollars, items with a retail price of 10x that +/-.  cheeky
  • DiomedeDiomede Posts: 15,471
    I was using 3D again quite a bit back when the new year started but really fell off. Will be using Carrara again for a couple weeks then back on the railroads of America for long stretch. But when I use Daz3D products (which is becoming less frequent), I am more likely to use Carrara than Daz Studio. Nothing against Daz Studio, but Carrara's all-in-one approach is generally worth more to me than the other advances Daz Studio has made.
    Agreed.  But I am finding cases where the Daz Studio product with iRay is very nice, like I mentioned for backgrounds for Carrara animations/images.  For the attached image I have both Poser->Carrara versions and DS versions of the diner, but the DS version looks great and has all the lighting done.  The other components are Poser format items in Carrara.  BTW, the image was for a contest "Luncheon Mystery", the caption is:
    Bad Directions
    "This is NOT Altair VI. Give me a new course. You should try the burgers here, though, wherever this is."
    1200 x 1200 - 299K
    edited March 24
    in my case, https://www.daz3d.com/little-crows-for-the-rog-red-crow-inn so much easier due to extensive instancing and highpoly mesh to use in DAZ Studio
    only downside is it's not easy to animate the smoke and fire there
    I ended up using 1FPS renders with AI
    some in these videos
    but doing  a much better one with pure 3D renders as start and end image series
    IE 1-29 and 2-30 with 60 frame -120 frame  Ai video series
    (those used AI editing and AI generated 3D meshes, plus lots of AI Infinite zooming, in first video, my next one I am still doing is purely DAZ Studio renders of DAZ content, just AI Animated)
    1920 x 1040 - 2M
    and that video is now done
    hope sharing here as well as Art Studio not spamming
    especially as Carrara not used blush
    no doubt Carrara users are awesome yes
  • wsterdanwsterdan Posts: 3,662
    Steve K said:
    Bad Directions
    Ha! Fun render, good joke, thanks for the chuckle!
    Okay, I was impressed when it started with how many and how well the people were animated, then the infinite zooming blew me away. Very impressive.
    edited March 25
    wsterdan said:
    Steve K said:
    Bad Directions
    Thanks.  You should be a judge for such contests.  wink
    Post edited by Steve K on
    Nicely done, pretty mind bending, e.g. the smoke surprise  Nice music, also.
