Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
    • Creative Tools
    • AI Scene Enhancer
    • Generative Credits
    • Enterprise Tools
    • Synthetic Training Data
    • Physical AI
Download Studio
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic and dforce Togatta Hair For Genesis 8
MisarmorMisarmor Posts: 43
February 4 in Blender Discussion
Hey there!
As the title says, I'm trying to make the Togatta work with Diffeomorphic. My main (and only, really) issue is with the texture (or general color). I just can't make the color appear only on the top like it would be on DAZ studio.
At first, the hair appears all black, with no texture. That seems to be because the hair curves get imported (or exported?) without volume. They only seem to be 1 vertex thick, so each strand don't have any faces to display the hair texture on, and that's even with checking the "render line tesselation sides" like the tutorial here says: https://diffeomorphic.blogspot.com/p/hair-version-15.html.
Anyway, a few months ago I actually gave the hair some volume (I don't remember exactly how as this was months ago, something to do with converting the hair to curves and then hair curves maybe?), but the best result I got was this:
As you can see, it's blue everywhere instead of being black on the sides, and blue on the top.
Here's how the shader editor looks like:
So if anybody has any ideas, they're very welcome.
  • PadonePadone Posts: 4,405
    February 6 edited February 6
    I had a look at it. The Togatta hair includes a opacity map for the strands, which is not clear how it is used as strands don't have a uv map, also the uv map is not displayed in daz studio. Thus the hair uv map is not imported in blender and the hair is fully rendered, instead of part of it.
    This is another case where the hair conversion from daz to blender doesn't work fine and some editing is necessary by hand. You could separate the hair you want for a different color.
    447 x 274 - 41K
    Post edited by Padone on February 6
  • MisarmorMisarmor Posts: 43
    February 6
    Yes, that's what I was worried about. I figured the UV map wouldn't work in covering the head properly like it would in DAZ studio. The opacity map *is* imported in Blender though, as you can see on the texture node screenshot I sent, it's probably not used the same way because of the reason mentioned above. :(
    I suppose I didn't think of sepparating the mesh tho, this could be a great idea. I'll try doing that :)
    February 6
    update. workaround.
    It seems using "particles" instead of "hair curves" works fine. That is, in blender "particles" generate from the scalp, and use the scalp uv map to tint the hair, this way it is possible to make furred animals as tigers for example. I'm not sure if the same can be done with "hair curves", which seem to be separate objects and don't refer to the scalp uv map. Will investigate further and let you know what I find.
    431 x 261 - 33K
    February 6
    Ah yes, I suppose tracing the UV map on the scalp and building the particles from there would work, good thinking!
    February 9 edited February 11
    update. Now I seem to understand how textures work with hair curves, so togatta or furred animals can have a texture with hair curves as well. Reported to Thomas for the fix.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/2637/
    p.s. Until this is fixed, you can fit it by hand by choosing the "curves" deform and unlink the textures uvs, as also explained in the issue linked above.
    Post edited by Padone on February 11
    February 10
    Thanks. With all due respect, you're the top G.
    February 17
    update. This is fixed in the last commit, now textured hairs as togatta work fine both with particles and curves. In the process some improvements were done too. I want to stress here that Thomas is making all the code work, I just help with some ideas where I can.
    https://bitbucket.org/Diffeomorphic/import_daz/downloads/
  • Singular3DSingular3D Posts: 684
    February 17
    You both are exceptional. Daz should thank you for helping to transfer Daz content to Blender and thus extending the usability.
    February 18
    Two top Gs, then. I wouldn't have been able to explain issues and propose fixes like you have, I just don't have the 3D experience. Thanks a ton for your help :)
    April 14
    Hey there, sorry to reopen this topic so late.
    I'm having issues with the hair, still. Basically, there seems to be some randomness involved with how the UV works.
    Sometimes it works well, like here:
    And sometimes, I get this:
    As you can see, there is only color at the very end of the hair, for some reason. Note that one the first try, the hair guide also had that same issue (I had converted it as well), but not the hair itself...
    The hair materials seem to be the exact same, I even tried changing materials to the buggy hair from the normal one, and it didn't fix anything.
    Would love to get your input about that :)
    April 14
    SOLUTION: Okay, apparently you need to select the hair cap when you use "Make hair" and not "human" as the program suggests
    April 14
    I agrre "human" is not a too smart name, it means the "hair base", which can be the figure for fur or the hair cap for hairs.
    April 14
    Thanks for the clarification :)
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
