New Year, New Sales Thread: Report Issues Here 3 "Reporting Only"
1…6768707273…100
  • joannajoanna Posts: 2,799
    It looks like Quick Grab didn't update on its own at Daz midday, so it might need someone to look at it.
  • Ron KnightsRon Knights Posts: 2,779
    edited January 5
    The montly codes are not fixed.
    I couldn't get the $6 off, or the $6 off $18 to work.
    Here's a screenshot of my attempt for the $18 deal.
    Next you'll likely say I can't get a discount on an already discounted price? Aren't all DAZ Originals 30% off to members?
    952 x 316 - 48K
    Post edited by Ron Knights on
  • Charlie JudgeCharlie Judge Posts: 13,650
    It's well past DAZ midday and Quick Grab still is not populated.
  • GolaMGolaM Posts: 120
    edited January 5
    It  seems the 80% off of wishlist items are highly stacking with the 85% of wishful artists.
    The Relaxed Curls are 97.9% off. Are you sure this is intended?
    Post edited by GolaM on
  • Richard HaseltineRichard Haseltine Posts: 111,721
    Quick Grab is now populated.
  • AnitaLeeAnitaLee Posts: 62
    The premier coupons appear to be working now in case anyone was following this thread as I was too get this info beforfe trying again.  I saw nothing so I tried and it worked ;)
    I haven't been able to get either of the monthly codes to work.
    I've gone through all the "small print." I just don't see why the coupons won't work.
    At first, I got no "message" as to why the coupons don't work.
    Now it says "coupon is not valid."
    What gives?!
  • felisfelis Posts: 6,554
    What gives?!
    What do you gave in cart and what code are you trying to use?
  • jmucchiellojmucchiello Posts: 2,374
    Nath said:
    Cris Palomino said:
    *Items must be simultaneously in cart for discount to apply.
    Items must be in your Wishlist prior to 1/5.
    Excludes New Releases and Daz+
    It would have been so nice if that last line had been there from the start.
    IME, It's usually simpler to assume that last line only to find out the assumption is wrong than it is to assume the lack of text means there are no further conditions.
    I tried using the monthly $6 off coupons.
    I tried buying numerous items.
    If you are Daz+ there is 6 off 18 that not includes new. And then there is 6 off Daz originals.
  • mrpenguin76mrpenguin76 Posts: 117
    edited January 6
    Having a problem with Monthy Coupon Code "01_26SAVE10". It will not work with Tokens added to a Cart. Example:
    My Cart is 53.98, I apply the coupon and it drops to 43.98.  Then I Add 8 Tokens, Cart throws out coupon and changes to 37.78.  I Try to use Coupon again,  "Coupon Code is not Valid" Appears.....
    So the Coupon works, as long as I don't want to use my tokens.... which, why would I do that?
    Post edited by mrpenguin76 on
    edited January 6
    What is in your cart? Do the non-new items total more than $25 after tokens are applied?
    Post edited by Charlie Judge on
  • WolfwoodWolfwood Posts: 998
    edited January 6
    That coupon requires that at least $25 of those 37.78 be not New, Outlet, QuickGrab or licenses. For example, if most of your particular cart are valid items but $13 do not, the coupon will drop.
    So, the best way to see if you are doing it right is to Apply tokens first. Then the coupon. If coupon says invalid, then use a calculator and see if after removing the not valid items you still have $25 or more.
    Post edited by Wolfwood on
    Yep that seems to be the problem, with the tokens applied the NON new release was no longer hitting 25$. Thus, no coupon! Looks like I was counting a new release as NOT still new. Thanks for the help.
    edited January 6
    I finally got the two $6 monthly coupons to work.
    I avoided any products that were new or had any percentage off.
    I'm not sure why the $6 off $18 finally worked. I know it would not take the tokens.
    The other $6 coupon finally worked when I realize it was only for DAZ originals.
    I applied a token, but it didn't reduce the price. The price was already down to $1.09 with the coupon.
  • ElorElor Posts: 4,183
    edited January 6
    Coupons should work on discounted items and tokens should work with coupons with a caveat for each coupon
    For the $6 off Daz Originals, if the price of what you're buying, after applying tokens, is under $6, you'll get that for free but you'll obviously lose a part of the coupon.
    For the $6 out of $18, you need to have $18 of items impacted by the coupon after the tokens are applied. The usual error people are doing is building a $18 cart, then they will apply the coupon, reducing their cart to $12 and only then they will apply the tokens and then they don't understand why the coupon is not applied anymore, because their $18 is now, as an example, a $16 cart.
    It should be the other way around: built your cart with tokens applied to be sure you have $18 of eligible items.
    The $6 out of $18 should have worked on the outfit for G8M you tried to buy with it. Maybe you tried that coupon at a moment the coupons were still bugged.
    Post edited by Elor on
    edited January 6
    Elor, I understand what you meant about the Lift and Haul outfit. It started at a little over $18.
    Then the Coupon and/or Tokens obviously reduced the price below $18.
    I have a hard time if I try to get too deep into calculations.
    I'm terrible at math, and I got some massive headaches trying to figure out all this stuff.
    I think they should make it more straight forward and easier.
    But then sometimes I mess myself up. The $6 off DAZ originals should have been easy... but I kept glancing past the obvious.
    I don't know if others have the same problem, but on my end, the shop's pages are stuck retrieving products informations, with swirling animations where the products' pictures should be.
  • EboshijaanaEboshijaana Posts: 576
    Aand the spinny circles and 404 sales screen return once more.
  • NathNath Posts: 3,064
    Swirlies here as well.
  • Cris PalominoCris Palomino Posts: 13,012
    Are you guys still getting swirlies? Can you give me the urls to the ones that do? I am going through and don't have swirlies. The legacy button is, as reported, oopsing, so reporting.
  • y3kmany3kman Posts: 896
    You actually lose the current discount if you add a "Bundled Up" new release.
    Swirlies are gone for me now.
    Swirlies are gone on my end, thank you :)
    I can't find the SVM product among the eligible products. Tried one from the selection and it worked. Did you get the SVM product from the approved lists?
    edited January 7
    It's from the latest selection:
    https://www.daz3d.com/latest-50-best-bundles
    When I checked, it did get a 20% extra discount with a new Bundled Up release, and an extra 50% discount with a new Bundled Up bundle. Maybe something was fixed between my message and the one from y3kman.
    1128 x 1132 - 231K
    Thanks, let me check.
  • Thomas63Thomas63 Posts: 55
    I'm only getting a 10% discount on my Gift Card, even though I have the 'CB Yara HD Character, dForce Clothing Set and Texture Expansion Bundle' in my cart. The 'Bundle Buddies' promo suggests I should get a 20% discount on the Gift Card with one of the new bundles in my cart?
