Show Us Your Iray Renders. Part IV
18788909293100
  • Oso3DOso3D Posts: 15,085
    Wow, those floors are amazing.
  • NovicaNovica Posts: 23,923
    The set is Imaginary House Indoor pool converted over to Iray. , I used a photo of some mountains, which I used for the back ground. by setting it under the environments tab. and I used Daz Studios built in default Iray light set at infinite light sphere. thats it. a pretty simple set up for pretty a decent results. it  took about 10 minutes to render
    That is really pretty- I love the contrast of the cold mountains with the idea of swimming in a hopefully not as cold pool! The floor is beautiful and I like that the lighting is subtle. Beautifully done!
  • LotharenLotharen Posts: 282
    Ivy said:
    A pool with a view.
    Very nice looking render Ivy! I love the reflection on the floor, looks great. That mountian background fits perfectly too!
  • TaozTaoz Posts: 10,235
    DustRider said:
    fastbike1 said:
    @K T Ong
    Please consider not quoting the entire message when it contains embedded graphics. Doubly worse when you respond to a reply that quotes your message w/ embedded graphics. Makes the forum a lot harder to read.
    You can always do the user name and a small text quote to make your reference clear.
    TIA.
    Different strokes for different folks I guess. I often prefer that the image be included in the quote, especially when it isn't on the same forum page - it can be a real PITA to try to find the original image being referenced if it's a few pages back (even one page back can be a bit annoying).
    +1
  • nicsttnicstt Posts: 11,715
    Taozen said:
    DustRider said:
    fastbike1 said:
    @K T Ong
    TIA.
    +1
    +1 here too; it can be frustrating wading through the posts, but I prefer that to trying to find the original image being discussed.
  • FishtalesFishtales Posts: 6,208
    nicstt said:
    Taozen said:
    DustRider said:
    fastbike1 said:
    @K T Ong
    TIA.
    +1
    Not a good thing though for people who have to pay for there Data or only have a set amount per month. Downloading the same image three or four times soon adds up.
  • IceCrMnIceCrMn Posts: 2,319
    I've resorted to blocking off site image hosts (imgur , photobucket, and others) with host file entries so I don't see those images, only the ones hosted here on the forums.
    Basically the hosts file tells Windows the IP address of the image hosts is 0.0.0.0 ( a non-exsistant IP address) the connection fails, and the images never load.
    I know it's a bit heavy handed, but I don't have any other options for handling them.
    Running the browser in 'Do Not Show Images' mode does the same. In Opera, which I use, you can also specify which sites to block or let through. I use it occasionally if I am on a slow network as it also speeds up page downloading.
    Fishtales said:
    nicstt said:
    Taozen said:
    DustRider said:
    fastbike1 said:
    @K T Ong
    TIA.
    +1
    Normally your browser will cache it so you'll only download it the first time you view it.
    ..........and if they have the browser set to clear cache on exit?
  • IvyIvy Posts: 7,165
    Thank you I used Toms Stone Iray enhancement on them I got free at rendo a while back. and I replaced the hand railing with Toms Auto chome textures for Iray and I used Toms Blue Iray glass Shader for the pool water but i did replace the text map it self back the orignal one. I just left toms Iray settings .. I light fixtures I used Daz real lights for Iray.
    Thank you very much Novica .
    Lotharen said:
    Ivy said:
    A pool with a view.
    Thank you very much, I like to use real world exprinces for my inspations.and I have agreat Power shot camera and live in a really wonder area of the world that can provide me with some very breath taking views of th appliacian mountains .  I'm going to try to do a few renders with this set up maybe even a night time set up and see if I can improve on it a little more
    It's mildly disturbing/gory, so I'll just link to the Monster Smile:
    http://willbear.deviantart.com/art/Monster-smile-568658373
    (zombie skin, used a cutout to give him a big ol' smile, adjustments to teeth and jaws)
    This isn't perfect, it should either be a scar or a fresh bleeding wound, but... just an experiment with https://www.daz3d.com/wound-makeup-artist-geometry-shells-genesis-2-bundle
    Very easy to use, I'm happy. (Blood would have required some work to place an overlapping drip of blood. Didn't feel like it)
    2000 x 1920 - 2M
  • L'AdairL'Adair Posts: 9,479
    Fishtales said:
    nicstt said:
    Taozen said:
    DustRider said:
    fastbike1 said:
    @K T Ong
    TIA.
    +1
    The real problem is the forum software doesn't include a link back to the quoted post. Other forums I've frequented do, and it's really nice to be able to open the quoted post to a new window/tab for reference.
    You know, there are a number of products that do things I am perfectly doing myself, like AtmoCam, the hair shading stuff from Mec4D's Unshaven 2, wounds...
    These are perfect examples of how 'workflow' is totally worth money, because let me tell you, easily clicking 'apply X iray hair' is SO MUCH FASTER than what I was doing before. Totally worth it (not even to mention the actual, you know, beards)
    Trying out the Yanmei skin (on a male), plus a few morphs to make the guy look at least somewhat asian. Unshaven 2 'jet black' shader on the hair.
    2000 x 1920 - 1M
    angry
    I love the what you did to that skin texture., Awesome
    It took some work with DieTrying's morphs, because the eyebrow started really spread out and crazy, so had to tighten it up a little.
  • BobvanBobvan Posts: 2,653
    So, again, swapping things around... Felicity skin on G2M, African for Genesis morphs transferred to G2M plus ethnics for G2M, aging morphs, omri hair, unshaven 2, and this and that.
    1186 x 1920 - 1M
    edited October 2015
    L'Adair
    For posts with images you could do what I did above.
    Post edited by Fishtales on
    Bad idea if you have limited bandwidth, and browse sites with many pictures. In the actual context it would probably also mean downloading other pictures again when going back through the pages to find the missing picture.
    Latest comic: http://thefarshoals.webcomic.ws/comics/40
    Things are heating up...
    edited October 2015
     Tried out a terrain from Infinito 1.1. It is the foreground in this with a grass shader added. The background is the skydome from Snowy Mountains, I think, I started a new render and can't look ATM smiley
    Click on image for full size.
    1200 x 800 - 722K
    edited October 2015
    The background is FMSkysphere. I added some clouds from Stonemason's Winter Terrains as mist to see how it would work. Took the render time up from three hours to seven smiley
    Iray, CPU only.
    1200 x 800 - 665K
    Another application of Felicity skin, this time G2F (as intended).
    Again, enjoying GenX2 to get 'ethnics for Genesis' over to G2F (though I also added a little Saba and Wefa from Ethnics for G2F)
    1236 x 2000 - 1M
    HAPPY HALLOWEEN
    Smiling horse!
    BIG SMILE
    2000 x 1236 - 987K
    edited October 2015
    Pick Up a new G2f character today. I really love how much meat she has on her. and the skin texture is killer. I'm tying to get as much as I can out of my wishlist before daz goes to Daz Connect with version 4.9 because I'm not going with it.  So anyway this is  Natasha for Genesis 2 Female   My new fav girl
    (you really got see how great she looks all natural .( Front)   (Back) she is really beautiful . )
    667 x 1080 - 43K
    667 x 1080 - 214K
    Post edited by Ivy on
