LIVE! In the store NOW!! LowPi - the Low Poly Figure, and Crowd Creator Scripts
11213151718
  • barbultbarbult Posts: 26,162
    Elor said:
    barbult said:
    Yup, it was Richard they were after.
    Excellent :)
    What did you use for the dust trail, either around the horse legs or the one left by Richard ?
    @Elor I used the Trail VDB from Mega Terrain Sand Dunes
  • ElorElor Posts: 3,138
    Thank you smiley
  • TotteTotte Posts: 14,677
    The Outer Rim expansion for LowPi is out now: https://www.daz3d.com/lowpoly-crowd-creator-expansion-outer-rim
  • ArtiniArtini Posts: 10,288
    Great. Will be nice to have some more masks for the faces, if possible.
    The faces as they are, looks a bit strange to me.
    edited July 29
    Just an example render of LowPi - ears look strange a bit to me.
    1200 x 1200 - 180K
    Post edited by Artini on
    Artini said:
    Just an example render of LowPi - ears look strange a bit.
    There are a few ear morphs it will randomize with if aliens randoms are enabled ( and make sure you have latest Crowd Generator  version 1.3.0.1)
    edited July 29
    Thanks. I think, it looks ok with some covering of the ears.
    1200 x 1200 - 183K
    How to check the version of Crowd Generator?
    It's shown in the top right corner of the Crowd Generator. The update was live on June 06
  • PhilWPhilW Posts: 5,160
    A very cool looking expansion set!
    edited August 3
    My trial with LowPi in the city.
    Thanks to https://www.daz3d.com/blender-to-daz-studio-plugin I were able to import some large set to Daz Studio.
    1920 x 1080 - 401K
    Nice one @artini!
    Thanks, @Totte
    I think LowPi help a lot to fill spaces with nice characters - just need to experiment more.
  • RGcincyRGcincy Posts: 2,862
    I just started playing around with Low Pi and came here to see what was new/different. I see @barbult is her usual creative self pushing the boundaries. Good to see all the ideas!
    edited August 27
    I had two updates in DIM last night: LowPi Crowd Generator Plus Extension and Crowd Generation for FF LowPi Lowpoly Figure. They downloaded but failed to install and wiped out what had previously been installed so it's now unusable.  The online Readme shows: 2025-08-26 added Y align support. Just letting you know something might be wrong with the download package.
    Post edited by RGcincy on
  • Richard HaseltineRichard Haseltine Posts: 107,885
    FF or LM?
    The updates appear to have left files, at least, for me.
    LM
    edited September 18
    I have a small but important update sent to my tester for the very weird and very hard to find issue introduced in 1.3.1.0 regarding instances not getting PopPlus positioned corectly.
    Hopefully it gets an OK and I can submit the update to Daz tomorrow.
    Sorry for the inconvenience
    Post edited by Totte on
    RGcincy said:
    I had two updates in DIM last night ... They downloaded but failed to install and wiped out what had previously been installed so it's now unusable.  Just letting you know something might be wrong with the download package.
    Was finally able to download and install the 8/26 updates. Just kept trying every week until it worked today.
    edited September 23
    What is the easiest way to create a line with LowPi people between 2 points?
    Do not understand why the script needs at least 3 markers.
    edited September 23
    Just put the three path markers in a straight line, I guess. The script looks for Start, Middle, and End path markers.  Maybe the logic can't handle a missing middle marker. I've never tried just two markers, so this is a guess. (Or if I did try just two, I've forgotten.)
    Post edited by barbult on
    Thanks, @barbult
    Script complains if there are only 2 markers and cannot continue.
    I think the markers are for area, so that is why there needs to be minimum 3 markers.
    I thought you were talking about path markers, not border or area markers.
    Without Path Tool, use the direction markers and then Masking Markers to mask off the area yopu do not want LowPis at. This is the reason (one of many) I did the Path Tool Extension, to easy make lines....
    I have all extensions to LowPI, but still could not figure out, how to set up area needed for path tool.
    I just want a simple one line of characters, nothing fancy, so how to set up this.
    edited September 24
    LowPi in the cave.
    1920 x 1080 - 763K
    edited September 24
    You only need to place 2 LP Path Markers, I'll show you.
    First - Just place two LP Path Markers, you only need those, nothing else. One set to Start, the other to End (under Misc - >Path Marker Type
    Simplest way is to place one, set it to Start, Duplicate and then move to copy forward and set it to End. (To avoid the Start Markler not finding the End Marker along its direction.
    Now use an Area Setup and attach that to the Path, and set Path properties
    Now click Generate and you got a line. To make the line wider or more narrow, change the Path Width for the Marker from which you want the Path to be narrow (in this case the first one set to Start.
    1652 x 1120 - 263K
    1678 x 256 - 142K
    1478 x 824 - 416K
    edited September 25
    Thanks.
    I am stuck at Area Setup - where is that placed in the script?
    2562 x 1308 - 382K
    Artini said:
    Thanks.
     You have to create (save) an area setup before you will be able to select it here. It is not intuitive.There is a manual about how to do this stuff. Have you seen it?
    1006 x 592 - 73K
    How to setup Area Setups are in the LowPi Area and Slope manual
