Buy Something That Doesn't Work in Carrara? Post your Questions and Workarounds here. (please)
1…4748495153
    WendyLuvsCatz said:
    just a quick look at some of the VWD simulations
    (all done on Win7 rendered on Win10 using Octane)
    Fantastic. I may need to find an old Win7 machine just for Carrara purposes. Hmmm... like getting back into that whole HP Z802 craze!!! :)
    Loves me my VWD!!!
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,666
    OK a weird one today
    trying to load a Poser PZ3 scene into Carrara totally locked up my PC
    it initially threw an error though it all appeared in my scene outliner but when I then clicked on that the whole computer froze and task manager couldn't be clicked after hitting CTRL Alt Del
    CPU was running like crazy
    it was just a DM scene Dark Legacy from Rendo  I have loaded in DAZ studio earlier and pretty sure have in Carrara too
    I had to power my PC off and restart it
    Hmmm... maybe try opening it in Daz Studio or Poser, then save it either as a new DUF or PZ3?
    I recall a long time ago that I would have rare occurrances like that - and that's the solution I chose - and it usually worked. The exception being that I was using old Poser, not Daz Studio.
    yeah saving as dif might need to be the solution
    along with the UV wrap intick
    If having trouble running latest version of vwd then try turning off "use gpu"
    My trouble is that it errors out as soon as I try to launch VWD
    edited July 2025
    My bad guess would be its the python version. Could be worth looking at . There's a link somewhere I'll have a gander, edit see next post
    Post edited by Headwax on
    from the other place: Installed Python 2.7.11 however CarraraVWDBridge failed on input of VWD location (tried having VWD in C:VWD and ...RuntimePythonposerscriptsVWD). Installed Python 2.7.12 and it appears to have fixed that problem. Now able to save VWD location and start VWD from Carrara. (Windows10 x64)
    Thank you So Much, my firend! A life without VWD is like... well... living without! indecision
    edited July 2025
    On that note, it really doesn't bother me - that difference in time to simulate. While it is a huge change, the end result is totally worth it.
    I just hope beyond hope that Gerald just gave up and is doing well. Good guy! Hope he's okay
    Post edited by Dartanbeck on
    edited July 2025
    the python install and a separate instance of Carrara light on plugins is what seems to have fixed the bridge for me on the Win10
    sadly VWD itself mostly gets stuck mid simulation and stops responding
    it has managed to finish and send back to host sometimes but mostly not
    (on the otherhand, my Win7 install works beautifully)
    It's working great in Daz Studio 4.24
  • DiomedeDiomede Posts: 15,464
    My VWD stopped working when I removed Poser.  It is supposed to run as a stand-alone, but hasn't worked for me.  Like others, I have an older computer at the top of the clost that has a working version.  I keep the old laptop because it has software related to the last time I taught.  Should probably get rid of it for the storage space.
    edited July 2025
    I do have Poser 7 on my Win7 and no Poser on Win10
    that said it works now but gets stuck not responding
    not tested the DAZ Studio bridge, I should as Dforce is way too explosive
    no good, crashed D|S after clicking OK too
    376 x 110 - 6K
    Yes it adds another dimension, I had a show a few years ago of my 3d renders  and vwd was a dominant tool in most of the works
    Hi Ted would you mind checking your python version out of interest ?
    My version is 3.10.10
    Thanks Diomede, you could always try with Python 2.7.12 if you get a chance.
    edited July 2025
    https://www.daz3d.com/the-last-vampire-hunter-hd-dforce-clothes-and-weapons-set-for-genesis-9
    works fine clothes only converted to Blended weight, saved as scene subset, loaded on my saved G9
    more than I can say about in DAZ Studio cheeky
    just putting it here as wasted days in DAZ studio
    should have used Carrara heart
    1920 x 1040 - 416K
    That's a great catchy Jingle, should have used carrara :)
    ...shoulda used
              ...shoulda used
                           ...shoulda used
    Shoulda Used CARRARA!!!
  • StezzaStezza Posts: 9,262
    using tune from "Escape (The Piña Colada Song)"
    If you like surreal compositions
    And Carrara’s spline-based charm
    If you're into morphing meshes
    With shaders that disarm
    If you like tweaking displacement
    While the modifiers play
    I'm the geek that you've looked for
    Modeling night and day
    If you like rigging with soft IK
    And metaballs that groove
    If you vibe with particle sparkles
    And polys that you can move
    If you mesh for composition
    With light maps set to sway
    Let’s build scenes down in Carrara
    Where polygons love to play
    Yes, I love some good UV mapping
    And some shaders with flair
    Cubic projections and bump maps
    With specularity to spare
    Let’s escape to a viewport island
    Where the spline trees sway
    And we render dreams in Carrara
    Until break of day
    yessmiley
    Until break of day
    Nice work Stezza , going for poet laureat !
    ...or songwriter extraordinaire!
  • well Microsoft support for Windows 10 is ending next month and not only does my hardware not support Win 11 (TPM) but apparently my version of Octane render 4 Carrara won't run on it
    so I won't be updating
    this might mean not updating any of my software and eventually not being able to use some
    fortunately 12 year old Carrara is pretty safe but DAZ studio is likely another story
    my Ai stuff might not work for much longer too but less of an issue as can go the web based Google Collab route if needed
    (so far avoided that but in the end no dearer as local electricity costs would be offset by the online costs and better GPUs)
    DAZ studio the one worrying me which is why I posted in this thread
  • ProPoseProPose Posts: 548
    For what its worth...I recently(a month ago) undated one of my computers from windows 10 to windows 11. That computer like yours, didn't qualify for the update(TPM). I really didn't expect things to work out but to my surprise,  all my programs still work.  That list includes Carrrara 8.5 Pro Beta as well as the release version of C8.5, and Carrara 8.1, and Octane 4.05.09 for Carrara works fine as well.  All except CS4 which was causing a crash on zip and rar files,so I uninstalled that and all is well.  Although I'm really not a fan of Win11, I figured that I'm going to have to bite the bullet eventually, so I went for it.  Windows 11 iso I downloaded from Micrsoft, and instead of a clean install I opted for "update" which gave me the option of keeping all my data and apps. A clean install wipes the computer.  As far as DazStudio is concerned,  I still use 4.10 and 4.21.  I have no plans on updating those
  • I guess I am scared as no going back and heard conflicting stories on Octane
    it works so don't want to break it
    I will try and buy a new PC with the latest Nvidia GPU for DAZ Studio etc eventually but not for a couple years yet
    just keeping my D|S installs backed up until it breaks so can go back, even considering a separate Carrara computer more CPU orientated too
    Ouch - that really sucks, Wendy.  I feel some of your pain.  Fingers crossed that it works out for you.
