Can we expect more and at least WELL FITTING clothes for G3F in the near future?
2
  • jestmart said:
    The gaps were there on all clothing for all the generations of figures I have used.  Clothing is polygons, the figure is polygons, when you have polygons on top of polygons there needs to be a small amount of offset otherwise you get rendering anomalies.  The gap is usually only about a half centimeter based on DS scale, not the 1 to centimeters you are claiming, and that is what I am seeing in your image, a 1/2 centimeter gap if that.
    And that is what I mean by acceptable.  You have to cam in pretty close to make out that there is a small gap.  You focus much too much on things that will not show as flaws in your average render.  When you look at the promos of the bikini in the store, there is no visible gap.  Also, as a 3D artist, you should expect a certain amount of postwork to correct things small flaws in renders.  I know people would like their renders to be perfect and not have to touch up, but realistically, this just doesn't happen.  Not for the hobbyist or the professional.  That's why industries have whole departments or companies they go to in order to correct and enhance the 3D work that ends up on our billboards or cinema/tv screens.
  • cosmo71cosmo71 Posts: 3,609
    Well, if you have a look at 3D-Age-Clothing they fit much better also if it comes to gaps and the have the adjustments to fix this.
    Also clothes of other artists like Rhiannon or RPublishing and Hongyu has adjustment and styling morphs to fix such problems and to let the clothes look much more real
  • fastbike1fastbike1 Posts: 4,084
    edited September 2015
    @cosmo71
    Have you looked at Wear Them All (http://www.daz3d.com/wear-them-all-autofitting-clones-and-clothing-smoothers-for-genesis-3-female-s). As an experiment, I've just been using this to fit #D-Age clothes to V7. Haven't had issues including panties.
    I hadn't tried Wear Them All before this little trial, but it works very well.
    Post edited by fastbike1 on
    edited October 2015
    Can we expect some more clothes for G3F in the near future?
    Post edited by cosmo71 on
  • wizwiz Posts: 1,100
    I heard something about bikinis coming.
    And fantasy armor, because we're pretty short on that.
    We are pretty short on everything and that what we can get fits like potato sacks
    1680 x 1050 - 220K
    Must be very difficult to create fitting clothes for G3F
    It´s great, nude images are not allowed but well fitting clothes we can`t buy...fantastic strategy
    edited October 2015
    well I think I will not buy any more clothes for g3f here at the store. So DAZ, forget my question, I go shopping elsewhere not here anymore.
  • Cris PalominoCris Palomino Posts: 12,986
    Threads merged as they are the same topic.
  • RuphussRuphuss Posts: 2,631
    hey you people could encourage cosmo in trying to evolve
    the daz store garments and get better standards
    instead of giving flat replies
    like: " it was always like this
    and your expectations are to high
    and we are only hobbyists
    and i remember times when....."
    things only get better when people demand for it
    i see exatly the same issues as cosmo does
    but i am not good enough in this language to explain it well
  • VhardamisVhardamis Posts: 576
    Personally I'm amazed anyone even bothers to models clothes at all anymore because it appears there is absolutly no way to please folks. First they are too tight now they are too loose. Could the clothes use some improvement? Sure. Iray and G7 raised the game but broad drama filled statements are a very different thing from constructive cristism. I'm not even a modler and i' drepessed just from reading all of this negativity.
  • FistyFisty Posts: 3,416
    It's even harder to be one of the modelers that goes through the trouble of adding 50+ adjustment morphs to most outifts and be lumped in with all the criticism.  Yes, there are some people who rush things out and neglect even basics like an expand-all morph or leave the usually hideous auto generated one in there as a consolation prize.  I know who they are and I don't buy things from those venders anymore.  I still do 95% of my content buying at Daz because over all the quality is better here.
    So.. is it right?  No, not really..  but I can't really say much more on the subject without getting my post removed.
    My recomendation to cosmo..  look at your content, find the outfits that you are unhappy with due to lack of adjustments and/or sloppy rigging - I'm guessing they will be made primarily by 2 or 3 people.  Stop buying things from those people.
  • TheKDTheKD Posts: 2,711
    Autofit seemed like a cool idea at first, but in the end just seems to screw everything up. Vacume fit is not natural at all. I stopped bothering with buying conforming clothes and started making my own in marvelous designer.
  • larsmidnattlarsmidnatt Posts: 4,511
    edited October 2015
    I do like the genesis tech over the old Generation 4 tech. I never could get clothes to work right with Generation 4 because I don't use stock shapes. With Genesis clothes actually work pretty nicely. Sure it has some tradeoffs, but overall I thought it was a good direction. Nothing is perfect, so it's up to the user to make adjustments to the stock content to get the results they want.
    But I love MD as well. Lots of fun to use and makes for some nice natural looks. But I still use stock pieces a good bit cause they still have value. I just don't buy nearly as much as I did years ago. I mostly only get clothes now from pro packs. (and i only typically buy one of those per generation)
    Post edited by larsmidnatt on
    It works fine for stuff that is actually supposed to be form fitting, like leatards and stuff. For stuff that hangs, like skirts or is loose, I go with simulation. Plus I don't have to worry when 3 months down the road g4f suddenly comes out buying whole new wardrobe lol.
  • Oso3DOso3D Posts: 15,119
    Using clones and supersuit and other tricks helps immensely with fitting. Or simply not using autofit, scale and collide as necessary. The tools are out there.
    A lot of people have unrealistic or impractical demands, and ignore the long explanations about why things might not work the way they want.
    Yep, and shoes and boring stuff I don't want to model and would rather grab from a stock collection. And I agree about the benefit of using the cloths on different figures :) And you always have the ability to change the cloth to a fitted cloth when the need arises..so you don't lose any options.(i needed to use an outfit in about 20 renders, so simulating it each time was out of the question.)
    Agreed, I love autofit, much better then the alternative we had before it. I guess we could all just go back to the V4 days where the only way to get clothes to fit custom shapes was to add that morph via crossdresser or morphing clothes to EACH peice of clothing and then save it out.. I still believe everyone in this community should have a basic knowledge of modeling to help with understanding how mesh works and to realize how lucky we are that it all works together as it does. Being demanding and uninformed doesn't really help anyone and puts unneeded pressure on content creators.
  • StrixowlStrixowl Posts: 301
    Outoftouch makes some awesome well fitting clothes with lots of very nice morphs. I don't by clothing that doesn't have a variety of morphs. Expand All just doesn't do it.
    By the way, if you haven't snapped up all of Wilmap's catalog, DO SO.
    It's been invaluable and I can't wait until my next purchase cycle so I can toss some money her way. (She provides everything FREE and then accepts donations).
    https://www.wilmapsdigitalcreations.co.uk/introduction.php
  • JennKJennK Posts: 834
    edited October 2015
    Orginal post deleted by me.
    I agree I only buy stuff that has lots of morphs and there are a couple creators I don't buy from anymore because of that.
    Post edited by JennK on
    Well, as I have written before. If the result of a new technology is to use tricks to make it work this new technology is worse.
    edited October 2015
    You are right, outoftouch and also Rhiannon and RPublishing and of course 3D-Age (for V4) and Hongyu are creating really great clothing and I have tones of them, unfortunatelly for V4 and pants and panties are not working also not with converters (crotch/leg/hip) region.
    The problem is, I would buy clothes for G3F from these vendors, but there are more or less no clothes for G3F created by these vendors, I have contacted RPublishing and Rhiannon and they will create clothes for G3F and they will also create Remakes of V4 clothes for G3F but that will take a while they say because it is very difficult and much more work than they have expected.
    have you had a look at the image Chris? I guess not or you need glasses, this is not a small gap, these are huge gaps.
    You can fix it though. Clothes have gaps some times. Easy stuff to correct. Probably not noticable if she had a top on. I'm guessing this one had no morphs included to help with that?
    Just do it! Take control of the stock content and make it yours. laugh
    edited October 2015
    Well, if you have 3D-Age clothes for V4 they work perfectly and much better than a lot of clothes for G3F oh wait a moment, we haven`t got a lot of clothes for G3F to compare
    It's easy for things to work perfectly when the range of options is limited.
    Many thanks for your comment. It is really hard if you have some critical issues here at the daz forum so I am happy for your support. Most people here have the opinion that everything is fine even you have to use tricks and stuff to make something work.
    edited October 2015
    I have some 3D-Age clothes from yesteryear for V4. No they were not perfect. Nothing is perfect. They don't fit custom shapes very easily...3D-Age stuff was certainly a step above many, but not perfect. And i still had challenges fitting.
    However if you that works better for you, use it! No reason to stop using V4. Lots of people still use Generation 4.
    "Perfectly" is an overstatement.
    These aren't critical issues. If they were more people would complain about them. For stock content most of the assets sold here are good for what they are. You do need to learn and apply "tricks" when working in any medium. The content sold here and at any other Poser/Daz store are starting points to speed up the process in creating art.  They are not the end result, you do need to put in some work especially if you strive for "perfection".
