[Updated to V1.3 - now MacOS support] FLUIDOS: a fluids simulator plugin for Daz Studio (commercial)
1…161718192022»
  • I have Fluidos and the Spring presets. I'm using the lastest version of Daz3d Studio 4.12 64 bit. I don't understand how you would use it for animation. Basically the source is the starting point and the sink is the end. If I understand correctly no matter how many frames you select you must set the last frame of the mesh to 100%  I chose 75 as an example. It takes approximately 65 frames for the water to reach the end leaving only around 10 frames left in which to loop from. That comes off looking very choppy and certainly not very smooth like in the Spring video. What am I missing and what do I need to change? Thanks!
  • AlbertoAlberto Posts: 1,472
    Set ON the Start from preset option when starting the simulation. The preset saves you the frames needed for the water to reach the sink. Since the first frame, the water stream is complete.
  • eequihuaeequihua Posts: 5
    Hi Alvin
    I need your help to create a simulation of Daz3d fluids preset waves, I have no problem with creating the 0 preset, but even I following your PDF indications to create a simulation with 30 frames I see nothing happen.
    thx
    eequihua said:
    Hi Alvin
    thx
    Hi, Eequihua:
    Of course!
    Could you upload screeshots of the properties Domain and Mesher, and  of the timeline, please?
    edited June 2021
    I am starting super easy. I bought both FluidOS for DAZ Studio & the FluidOS Wave Presets today & installed them along with the license key. I opened one of the 7 example scenes you included. I rendered. However, I only got very lackadaisical render that really don't look so much like the ocean. I am using DAZ Studio Pro 4.15.0.14 Public Beta.
    Here is an image showing what I mean.
    1903 x 1023 - 792K
    Post edited by nonesuch00 on
    You first have to run the simulation (be sure to enable Start from preset) and then enable the meshers to see the waves. More detailed instruction are in the "How to use the preset scenes" section of the Manual.
    If you have more doubts, let me know, please.
    Yes, I prefered page 26 of the manual but I did find the PDF you wrote for the waves presets product as well. DAZ 3D needs to integrate 3rd party manuals better into the installed DAZ Studio products. I'm disappointed I can't save the waves as an ocean mesh so I can just open the ocean scene & render though.
    Thanks very much. Thery look good!
    You're welcome!
    The manual (59001_fluidos-presets-waves-manual.pdf) should be in your library folder at  "/ReadMe`s /" . Or you can also download it from this page: http://docs.daz3d.com/doku.php/public/read_me/index/59001/start
    Do you want to save the waves? No problem. The first time you run the simulation, the data files conserve the waves. Only have to enable the meshers. Moreover, if you save the scene with the waves vsible, when you reload the scene, the waves will be there.
    Or you can save the waves itself as an .obj file (export separately the water mesher and the whitewater mesher, reimport the .objs, aply the corresponding materials and save the scene.
  • Brugan said:
    To add serial number:
    On this website, go to My Account
    Click Serial Numbers and copy the serial number for the Fluidos Product
    Next go into studio
    Go to Help/About installed plugins
    Scroll down to the Fluidos Product, paste the serial number and click OK, then restart studio and you should be up and running :)
    Nope. It's not in the installed plugins even after DIM install.
    Ok that's wierd. Try uninstall/reinstall?
    Did you get a popup for a C++ install when dim was installing it?
    Next go into studio
    Be sure you installed "FLUIDOS for Daz Studio (Win 64-bit)" (or 32-bit) or  "FLUIDOS for Daz Studio (Mac 64-bit)", depending on your OS; this contains the plugin itself. When you get the popup for the C++ redistributable click in Install. If it says that the installation of the Redistributable has failed, don't worry, the redistributable was already installed, this "error" doesn't stop the installation of FLUIDOS.
  • tubbesingtubbesing Posts: 56
    DAZ continues to crash when I attempt to call the Fluidos simulator.
    I'm working through First example in the Fluidos v1.3 manual (page 2).
    I get through step 11 Call the simulator, with Continue saved state and Start from preset both set to Off (which is the default). At Step 12, when I click the Accept button, DAZ always crashes.
    Mac Studio 2022
    64 GB memory
    mac OS Sequoia 15.4.1
    DAZ 4.23.0.1 (64-bit)
    I can supply the Problem Report, if that helps. As usual, it's kinda long.
    Thanks.
    Mac Studio 2022
    64 GB memory
    Thanks.
    Yes, please send the report of the problem and the log of the simulation (it's inside the logs subfolder of the folder you chose as baked files one).
    Mac Studio 2022
    64 GB memory
    Thanks.
    Thanks for the quick reply. Here are the 2 logs. FYI, the supplied Fluidos Scene 1 also caused a crash at the same point (Edit > Run Fluid Simulation).
    Simulation Log:
    07-May-2025 14h13m33s
    Initializing Simulation Grids:
        Grid Dimensions: 40 x 40 x 40
        Cell Size:       2.5
        Constructing MACVelocityField:     0.0024
        Constructing FluidMaterialGrid:    0.0004
        Constructing LevelSet:             0.0013
    07-May-2025 14h13m33s setSurfaceSubdivisionLevel: 1
    07-May-2025 14h13m33s set CFL Condition Number 5
    07-May-2025 14h13m33s setMarkerParticleScale: 3
    07-May-2025 14h13m33s addFluidCells: 7107
    07-May-2025 14h13m33s addBodyForce: 0 -981 0
    07-May-2025 14h13m33s disableAnisotropicSurfaceReconstruction
    07-May-2025 14h13m33s enableIsotropicSurfaceReconstruction
    07-May-2025 14h13m33s enablePreviewMeshOutput: 10
    07-May-2025 14h13m33s initialize
    Initializing Simulation:
        Initializing Solid Cells:        0
        Initializing Fluid Material:     0.0142
    txt
    txt
    Problem Report.txt
    180K
    Mac Studio 2022
    64 GB memory
    Thanks.
    Simulation Log:
        Cell Size:       2.5
    Some new info:
    If I change Preferred device to CPU, I get an Error message. Changing to GPU 2 crashes DAZ. Setting Enable OpenCL to Off allowed the simulation to run correctly. Any idea why? Thanks for the answers and the product.
    tubbesing said:
    Mac Studio 2022
    64 GB memory
    Thanks.
    Simulation Log:
        Cell Size:       2.5
    Some new info:
     It seems that OpenCL doesn't work in your system. OpenCL is deprecated in newer MacOS systems (https://developer.apple.com/opencl/) and may not work.
    Anyway, as Fluidos is much more CPU-intensive that GPU, you can disable OpenCL without a substantial drop in performance.
