The Missed It By That Much to Get a Bacon Steak Sandwich Complaint Thread
18485878990100
  • DanaTADanaTA Posts: 13,411
    I thought I installed Daz Studio 4.8 on this computer.  Apparently, only version 4.7 is on this computer.  I want to play with Iray.
    Nice to see you around!  Are you well?  What's the prognosis?
    Dana
    TroutFace said:
    Windows 10 installed.  I had to hack my account to getin to my own laptop, Wn10 jacked up y account, but running now.
    Everything works fine, all my audio software and 2D/3D apps, DS and Brye are fine.
    Apps load faster. Windows boots in les than 30 seconds.  The Edge browser, omg omg, so fast. surprise
    Despite the bs I had to go through to get back in, using my Android phone and tablet, I declare Win10.. a win.  Win8 blew, this is the OS MSshould have shipped.
    Did you find all the privacy things that need to be changed?  Is your computer going to be used for a download machine?  (not for you, for other users?)  there are a lot of things that make privacy a piece of fiction in Windows 10.  Some are not easy to find.
    Dana
  • kyoto kidkyoto kid Posts: 42,410
    sriesch said:
    If the issue is in the display, perhaps you can use an external monitor as a temporary solution if there's a port for it.  People often discard working older monitors you could get one for free.
    ...as I have mentioned elsewhere, the display doesn't go completely black as would occur were the connection faulty, the backlight is still receiving power.  I've tried several different fix routines, and so far none of them have helped.
  • McGyverMcGyver Posts: 7,102
    I keep all my passwords hidden deep in a notebook containing old story notes... They are written in a simple but non intuitive code and the notebook is hidden with several other notebooks containing tons if other story ideas notes, and data... Good luck hacking that.
    Good luck to me even finding it half the times I've needed it.
    edited August 2015
    ...ran into another issue tonight had a BSOD that was triggered by the 0x0000019 stop code. This one seems more serious as it relates to a what is called "bad pool header".  In researching the means to fix this, I found so many different suggestions, some which I wouldn't trust myself doing (as they involve using the Win7 boot disk, system restore functions, and manually messing around with the registry) I had no idea of what to do.  Those suggestions that involve using a "free" repair tool, end up with sending you to a site to purchase said tool to perform the actual fixes after you have waited through all the scans.
    Ended up running a MalwareBytes scan instead, and had it remove a lot of stuff it isolated related to the AskToolbar which as I discovered is a vector for malware and according to many, should be removed from one's system.
    We'll see if that fixes the issue.
    I really need a personal IT tech, but I cannot afford one.
    Post edited by kyoto kid on
  • starionwolfstarionwolf Posts: 3,670
    Dana
    No, I am not well.  The surgeon will hopefully give me my prognosis on August 20.  I'll post the updates on my thread so that I can keep track of my comments.
  • ps1borgps1borg Posts: 12,776
    Good decision, bad POOL_HEADER is a catch-all for problems (re)allocating memory, mebbe related to a HW driver, and you need to really drill down into what's happening with memory allocation after that, can't assume much from it at all :)
    Blissful Sunday almost over here, had the privilege this morning of being with some infirm but still glorious heroes that kept me walking on air all day - a real gift. Back to the grinder in around eight hours, with a bit of luck this job will be over by the end of next week & I'll be back to regular complaining with a little more time at home. Be well y'all :)
    That depends on which connector, surely? Power would take the backlight but the data connector sending the pixel colours would not necessarily do so.
    There is Windows 10 ? Oscar Mike Golf I gots to get a life laughcrying
    I think not being aware of Windows 10 is probably an indication that you do have a life away from the computer.
  • TJohnTJohn Posts: 11,438
    Happy Sunday.
    edited August 2015
    'plaint - burnt my cornbread breakfast.  forgot about it in the oven, too busy yapping and jumping like a frustrated chiwahwuh cause alsace only shows iray promo.
    non'plaint - she save bucks and she play with medieval docks instead
    thinkin this might work as an exterior to mage tower?  https://www.daz3d.com/outpost-94
    laugh my draggie scroll gettin big
    Post edited by Mistara on
  • XyetztXyetzt Posts: 27,547
    edited August 2015
    640 x 302 - 18K
    Post edited by Xyetzt on
    lol  not too awful, groceries coming between 5 and 7 tnite.  hopefully the red velvet cake is not a lie this time
    clickies for your eggs
    Dana
    OK, I bookmarked that thread!
    Dana
    edited August 2015
    ...I may be able to build a system, but this kind of stuff leaves me in the dark, hence my comment: "I need a personal IT Tech".  I wouldn't even know where to begin as much less what to do.
    edited August 2015
    ...Thanks.  The cases I read didn't mention there are two cables to deal with.  They did however also mention it could be the inverter.
    In any case, sounds like something I'd need a tech to fix and that means it won't get dealt with until I have the funds to spare (which could be a long time).  Working on towers is one thing, in comparison, working on a notebook with my clumsy arthritic fingers would be like working on an old analogue watch.
  • SerpentSerpent Posts: 4,075
    So far, worth the agony of upgrading.  The touchscreen/trackpad/mouse feels more reasonable, hey don't collide horribly and throw off my typing.  EVERY program loads noticably faster.  The Edge browser is fastr than Chrome, OMG.  After some updates, everything I rely on runs - all my audio and 3D software.  DS runs fine, so does Bryce.  I have no new complaints. smiley
    ...like I have mentioned were it not for the forced auto updating, having to be a super sleuth to turn off all the privacy invading "features", the inability to uninstall "bloatware" I don't need (like personal assistants), having to pay a monthly fee not to get adverts, and having to purchase an "app" to replace the trusty old Media Centre, I probably would have gone for it.
    My internet is acting as if it is not working.
  • The "Ask Toolbar" gets installed with Java or Adobe Acrobat or some other free software.  Basically, you forgot to uncheck it when you installed the freebie.  It's nuisanceware, but not malware and certainly not intentionally maleficent or malicious.  You should be able to uninstall Ask Toolbar from the Programs (aka "Add or Remove Programs") menu.  I would do that before trying to uninstall it with any malware-remover.
    ...actually a couple sources do mention that it can be a vector for malware.
    was playing in poser hours n hours.
    mucking with shader settings for Katie7
    she's having a fashion emergency, Mike needs some help too  tee hee
    1500 x 1063 - 210K
    1480 x 1417 - 295K
    welcome back
    wistles tune to welcome back kotter
    CAKE  let us eat CAKE
    ...but where's the guillotine?
    da lil cousin is slicing bread loaf
    Who is Katie 7?
    big dentist day is tmorrow, still no ride offer. >.<
    i'se lost 4 1/2 lb the last couple weeks.  the tooth infection diet. yechie
    treating myself to diet cherry cola.  don't usually drink soda, but ruffles potato chips needs cherry cola.
    red velvet cake nibbles nibbles nibbles doh wanna dive on it with my face pacman it
    Who is Katie 7?
    she comes with poser 7.  and she's in PP12 legacy figures.
    testing out how she bends.  keeping in her limits she's a cutie
    850 x 850 - 424K
